Dear Sir:
Please LUBE the machine, you have a lack of maintenance, in according with the instruction manual, Produce enough friction between deck vs deck belt, may the deck belt is worn. By that reason Shut down for to protect the electronic system.
2) Test the input voltage for main motor if there voltage, the motor need repair.
3) Test the main motor board for output voltage for input in the main motor , if there are NOT the board is faulty.
4) Check the rollers bearing LUBE.
sincerely. God bless you
SOURCE: Request manual for treadmill.
I have a manual for this exact treadmill. Don't have a scanner though. I checked with my local print shop ans they said they could scan it and save as a pdf for $10, if you are interested.
This condition is when the treadmill operates normally without a person on the belt and then slows down when someone steps on the
belt or when the treadmill operates normally for a given period of time
with someone on the belt then abruptly begins to slow down.
There are four typical causes for this problem (listed in order of our experience:
1) The walking belt and/or deck are worn. (85% of the time)
2) The walking belt and/or motor belt are too tight- if you have adjusted either recently. (8% of the time)
3) The motor has lost torque and needs brushes or has demagnetized. (5% of the time)
4) The controller is dropping output. (2% of the time
Test every step.
http://www.youtube.com/watch?v=38w4PkiWIBY&feature=related
http://www.youtube.com/watch?v=-oeXTKqWECw&feature=related
http://www.youtube.com/watch?v=GPI6dFJCUA4
