Question about Maytag PAV2300 Top Load Washer
COLD WATER DOES NOT SHUT OFF WHEN FILLING
Cold water shut off?
  • 116 Answers
Either the cold water valve is defective or the water level switch is defective.
regards
Posted on Nov 16, 2008
Will I still have water running to the water heater if I shut off the bypass valve?
Bypass valve is to bypass the water heater. No bypass valve and always water in tank. Put a bypass valve and shut it up it is like no bypass valve.Open the bypass and shut up the input (cold water) and output hot water) no running water in heater tank but still have cold water in the rest of the house even in the hot side of the faucet.
Nov 25, 2017 | Water Water Heaters
Where is water shut off valve on Rheem Electric Water Heater?
The shut-off is not on the water heater.
The shut-off is usually located on cold water pipe that enters water heater.
See image of shut-off:
http://waterheatertimer.org/images/Low-water-pressure-2-800.jpg
If shut-off is not located on cold pipe at water heater, then turn off water to house at water meter.
More resources:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Sep 25, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Cold water suddenly shuts off during shower.
sounds like you may have "air" in the pipes and that bang has slamed the water reg valve shut hard
Mar 27, 2010 | Bosch AquaStar 2400ES-NG
Ge washing machine
does the cold and hot shut off at med. and high?it sounds like your cold water valve solinard is sticking and needs to be changed,(very easy fix,let me know more-mike
Oct 28, 2008 | GE WVSR1060A Top Load Washer
HOTPOINT WD62 FILLS WITH WATER WHEN NOT BEING USED
All washing machines have a solenoid valve for turning on and shutting off the water coming in, one for the hot water and one for cold. It sounds like one of them has a slow leak.
Try shutting off the cold water supply to the machine for a day and see if the tub fills with water. Next try shutting off the hot water supply and leaving the cold supply on. This will tell you which valve is leaking.
This solenoid valve is something you can buy from an appliance parts company. In some cases, someone handy may even be able to disassemble it and replace a washer that is leaking.
Until it is repaired, you can get by with shutting off the water supply when you are not using the machine or shutting off the supply that is leaking. For example, if it's the hot water supply valve that is leaking, just shut off the hot and do only cold water washing.
-Vince
Oct 03, 2008 | Hotpoint Washing Machines
When temp is set on hot water--hot water shuts off & cold water comes out
In the machine, you have a solenoid that the water hoses come into. That piece is controlled by a timer. The hot water during the cycle, does it shut off completely during fill or intermittent?
Mar 16, 2008 | Washing Machines
Cold water doesn't shut off
time to replace your water (mixing) valve. the diaphram tht regulates the water is wornand will no longer close causing the water to continually come in
Oct 11, 2007 | Washing Machines
Maytag PAV2300 Top Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
