We need the passcode for the wireless modem - Computers & Internet
  • 300 Answers
Without the model specifics I cant tell ya what the default password is. However, most routers have a factory reset button on the back, which will take it back to factory settings. Be aware that it will erase all changed settings.
You will usually find it on the back of the router and it will be a recessed hole that you can insert a paperclip into and hold for about 10 seconds then release. When you insert the paperclip you should feel a click.
Hope this helps. Please remember to rate this information.
Thanks
Posted on Nov 16, 2008
Cant connect modem to new wireless brother printer
It is best you contact Arris support. Mark Motorola Mobility Support ARRIS
Jun 17, 2014 | Motorola Computers & Internet
Where's the wireless passcode for my new MR SBG901? How many characters must be entered?
There a great article at General Router Setup.
If you need more help post back!
Thumbs and testimonial are welcome!
Mar 06, 2011 | Arris SURFboard SBG900 (49402201900) Modem
Wpa pass phrase
Although the information you've left is very vague.
I'm assuming you want to know what the WPA passcode is so you can connect to your network to get online Xbox 360?
It will be the wireless password you use to get on the internet with a laptop of sorts. If you have a 2wire gateway/modem its on the bottom of the modem in brackets usually. I'd check to see who setup your wireless router and they'll be able to get you the passcode for your wireless.
Mar 01, 2011 | Microsoft Wireless Network Adapter Xbox...
How can i find my password for my motorola SBG900 modem
Passcode is on the label on the bottom of the modem. To configure security, default code is "admin" and password is "motorola". If you are trying to log onto the wireless signal, that is the WPA-PSK code also found on the label. There are way too many codes on this router/modem - but it works well once you have it running!
Jun 14, 2010 | Arris SURFboard SBG900 802.11g/b...
There is no internet working with the Belkin G wireless Router
How do you have your connection set up? Normally, your modem connects to the router, and router to computers, this is how yours is set up? Since your router is wireless-capable, just make sure that your laptop has its wireless turned on and you have the router's "Wireless" set up, name (SSID) is done, security method chosen. I like WEP-PSK[TKIP] for its simplicity, keeping in mind that all logins to your network will need this passcode as well.
Nov 11, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
No internet access with my Dell 1184 wireless braodband router- does the PC need software for this to operate? connection is cable modem out to broadband router "internet" then broadband router LAN line to...
Yes, the cable modem connects to the router and then you can connect wireless or by using the lan ports on the router with a cable. If you have security setup on the router you will need the passcode or you will need to push the reset button on the router to clear it to factory settings. Its not required but it is best to use the software that comes with the hardware
Aug 30, 2009 | Dell TrueMobile 1184 Wireless Broadband...
I am trying to find out my internet connection password to acess Safari on my itouch but nobody in my family seems to know the password. How can i find the password on my computer ?
All you have to do, depending on your connection. If you are wireless through your Gateway or modem, the wireless encription key is physically on the modem itself. If you use a router to connect wirelessly, you will need that WEP key, You can also go to your wireless setting or view your available network, the go to properties. If you have connect wirelessly before, you should have the passcode written down Then when you find it, turn on In settings, on your I touch, turn on wifi, then it will ask for the code. Put the number in.
Jul 23, 2009 | Apple iPhone Smartphone
2wire 2700hg-b modem
if you have posted the correct model, you cannot connect a modem to this router as it has it's own built in modem, so in effect the routers modem will not configure properly, remove your modem and try again as there is no reason why the key code numbers should not work, unless you have caps lock on when you should'nt or visa versa
Nov 19, 2007 | 2wire 2700HG-B Router (2700HGB)
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
