Whirlpool top loading washer doesn't agitate
My washer isn't agitating all the time anymore. What's the problem? Is it something i can fix myself or do I have to call the repairman?
  • Donna B Nov 17, 2008
    could it be the agitator dogs?
  • 370 Answers
The agitator dogs only make the top part of the agitator work. you can check the dogs by grabbing the top of the agitator and turning it right then left. If it doesnt lock when turned back the other direction they are bad. If thats not it, it could be your drive coupler. But its only the drive coupler if it doesnt spin. Also check the lid switch. But if its the lid switch Your washer will stay full of water and not drain out. But check your dogs. There are cheap and thats probably your problem.
Posted on Nov 18, 2008
Whirlpool ultimate care II agitator seems as if it is not woking properly
this is for the whirlpool washer,if you grab the top of the agitator can you spin it both ways without it grabbing,it should only spin one way,if you can spin it both ways you have bad dogs,the agitator cam kit part number is 285809 and it's around 13 dollars.pop off the center cap of the agitator,remove the 7 1/6 inch screw in the middle and pull off the top of the agitator to get at the dogs,you'll see them there are 4 of them,they waer down and the top of the agitator doesn't work.watch this video.
http://www.youtube.com/watch?v=ensJz0h6wLM
Jan 10, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
The agitar isn;t working right. Is there
The part you need is FSP# 80040 dog kit goes inside the upper agitator. installing them dawgs: You sit the agitator on the floor, put you feet on the base and snatch the top portion off of the bottom. You put all the dogs back in the cam set them up into the upper portion with a piece of pvc pipe or equivilent and invert onto the base, lining up the tabs on the bottom with the holes in the upper portion being careful not to smash the tabs on the base that hold the upper portion onto the agitator. Snap it all into place and gently re-install it being careful not to over tighten the nut. Watch this video:
Jun 06, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore washing machine Model 110.4767292, squeaky agitator
I can't seem to get the Sears Parts site for your washer model number.
Can you verify that it's correct?
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
In the interim, here is the Whirlpool Service manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Following is a procedure for removing the agitator(s) on top load washers.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136
If you take the agitators out, I'd make sure that any "gunk" is cleaned off and check the splines inside the agitator and on the transmission agitator shaft.
It's probably not a serious problem.
Nov 04, 2009 | Kenmore Washing Machines
My Maytag Ensignia washer is not spinning well. It bangs side to side with even the smallest loads. It seems like something is loose. Is this something I can fix myself or do I need a repair mans help....
Try leveling the washer... If the washer is level, then don't wrap the clothes around the agitator...drop the clothes straight in, on top of each other evenly around the agitator. The Ensignia washer has a Dual action agitator... That means the clothes roll over them selves, instead of moving side to side, as with a traditional agitator. wrapping the clothes around the agitator will cause the load to be un balanced and then cause the "banging" noise... this should take care of the problem...
Jul 31, 2009 | Maytag Ensignia MAV4758AWW Top Load Washer
I put a down comforter in my Whirlpool Ultimate Care II washing machine (I have done this at least 50 times). Last time, it got hung up around the agitator and started making a funny sound. The agitator...
Pull the agitator off and check the plastic drive hub at the top of the agitator shaft. It should not be split, or have it's internal splines sheared off. If this all looks ok, then likely transmission problems or a slipping drive belt (motor to transmission). Good luck!
Jul 12, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Imperial Washer LA9200XWN1 Does not agitate like it did
HI, this will happen over a long period of operation time. This is repairable and, you will need to purchase an agitator kit from whirlpool or, an aftermarket circuit. installing a new agitator kit will fix this issue.
one or more of the main agitator components have become stripped or, damaged.
Jul 09, 2009 | Washing Machines
Whirlpool LXR9245EQ2 top loading washer tub won't fill
try taking the knob off and see if the nut is tight on the timer,it might if came loose
Jun 18, 2009 | Whirlpool Washing Machines
Washer will spin, but won't agitate
not a motor as it is spinning
at the bottom there is a solenoid actuated lever that engages the drive for the agitator
that lever can break or the solenoid can burn out
May 09, 2017 | Whirlpool LSR5132PQ Top Load Washer
Whirlpool washing machine agitator removal
my whirlpool washing machine's agitator bottom is working but the top is not. How can I fix this myself?
Thank you,
Ann
Nov 24, 2008 | Estate TAWX700JQ Top Load Washer
Washing Machines Logo
74 people viewed this question
Top Washing Machines Experts
