Question about Canon BubbleJet i550 InkJet Printer
Canon i550 printer,7 yellow flashes ''defective printhead''
I've tried cleaning the printhead & it still isn't working. Is there anything else I can try?
  • 7 more comments
  • Anonymous Nov 16, 2008
    I have cleaned the printheads several times over the last few months. When the lights started flashing, I cleaned the printhead & contacts with isopropyl alcohol, but the same error keeps flashing, 7 yellow lights followed by green.
    Could I get that reset code sequence? And what if that doesn't work?
    I couldn't find the tip about cleaning the waste pads.
    thank you
  • silvergerbil Nov 23, 2008
    amber light flashes 7 times then green,then 7 times again,over and over
  • enrol153 Dec 07, 2008
    Hi, I have the identical problem. I cleaned the heads and all points with alcohal and even used a white eraser to addittionally clean, adjusted paper thickness many times,put new cartridges in , nothing seems to help. Any ideas before I trash it. It also has 7 yellow flashes. Signed Desperate.
  • Anonymous Jan 08, 2009
    Canon i550 printer problem is rife with red and green
  • Anonymous Jan 24, 2009
    I can not find the Ink pads.
  • madisonQ Feb 05, 2009
    amber light flashing 7 times then it changes to green I try to clean the head following the maintenance procedure, but the message is "the printer is not responding" and I could not carry on the maintenance process.
    The technical help from Canon is UNEXISTING. I think the product has a design failure and will buy another printer which this time will NOT be a Canon
  • ivelev06 Feb 11, 2009
    I have 7 yellow flashes and do not how to fix teh printer. Please help
  • bahrammoosap Feb 26, 2009
    7 yellow flash
  • Glenn Rogers
    Glenn Rogers May 11, 2010
    The seven flashing lights are an error code referring to the ink absorber pads. I can get you the reset code sequence to turn this error message off. There is also a Tip on this site about cleaning the waste pads. Waste pads get full from cleaning your print heads and the error message is only supposed to run after you have run the head cleaner a specific number of times.
    Have you run the print head cleaner many times?
    Problem Solver:
  • 5 Answers
SEE SERVICE MANUAL
http://www.eserviceinfo.com/download.php?fileid=38984
Posted on Dec 26, 2008
Canon i550 yellow light blinks 7 times.
You machine probably thinks it has more than one of the same colour installed. Take them all out and re-install one at a time allowing the machine to reset between each . If it doesn't fix the problem you will find out which cartridge is at fault and replace it.
Sep 12, 2014 | Canon BubbleJet i550 InkJet Printer
Yellow light blinks 7 times
? Seven flashes: Defective printhead
Remove and reinstall the printhead.
Also, ensure that the protective cap has been removed. If reinstalling the printhead does
not resolve the problem, replace it with a new one.
Mar 04, 2010 | Canon S900 InkJet Printer
Canon i550 LED error sequence: 7 orange +1 green flash
According to Canon 7 orange flashes indicates a print head fault. Solution they recommend is to take it to one of their service agents. Problem is that replacement print heads are not cheap and it is usually more economical to replace the printer. You could try taking the print head to a cartridge refiller and have it professionally cleaned (cost you nothing or next to nothing) and see if that solves the problem.
Sep 19, 2009 | Canon BubbleJet i550 InkJet Printer
Yellow light blinks 7 times with 1 long green blink
Jennifer, According to an answer by kev1952 on 19 Sept, to my similar error condition ( "repeating sequence of 7 orange and 1 longer green flash of power LED" ) in a Canon i550 printer, and assuming that what you called yellow I called orange, then you too may have a printhead fault. kev1952 recommended to try to get it cleaned and checked at an ink refilling specialist service.
gp26, on 21 Sept 2009
Aug 17, 2009 | Canon PIXMA iP1600 Printer
Flashing orange lights
WASTE TANK NEEDS TO BE EMPTIED
GO ON LINE AND TYPE
CANON 850i INKJET PHOTO PRINTER 7 BLINKING LIGHT YELLOW
AND YOU CAN FIND YOUR HELP YOU NEED
ROD THE CANDYMANGNADY
Jan 14, 2009 | Canon i850 InkJet Photo Printer
Canon i550 printer stoipped printing
My cannon printer no longer responds to any commands. I get 4 yellow blinking lights and then 1 green blinker.
Oct 09, 2008 | Canon BubbleJet i550 InkJet Printer
Printer Not Responding, 7 orange flashes
Don't replace the print head soooo fast...
Take the print head out first and clean the gold contacts...
I used a very fine sandpaper like emery cloth...
You might get 4 yellow blinks after that.
That is because the printhead was turned upside down to clean and the ink looked low and/or out.
Just wait a few minutes after cleaning and reset...
Mine worked fine after that.... smile....
Aug 09, 2008 | Canon S900 InkJet Printer
Printhead & Waste Tank Troubles
Try this thread, it fixed mine without the need for any new parts, also note the cleaning procedure, it may fix your old printhead
http://www.fixya.com/support/t350585-waste_ink_absorber_almost_full_canon
Sep 15, 2007 | Canon S900 InkJet Printer
My canon s520
The user guide for that product says that 7 flashes means the printhead is defective and that you should contact Canon's customer care. If you've recently replaced the print cartridge(s), try putting the old one(s) back in. If the printhead is truly defective, there may be no choice but to contact Canon or replace the printer.
Aug 21, 2007 | Canon S520 InkJet Photo Printer
Canon BubbleJet i550 InkJet Printer Logo
709 people viewed this question
old marine
old marine
