Question about Technics SA-EX110 Receiver
I have a Technics SA-AX610 receiver that says overload .
After a few minutes it says overload and shuts off.I noticed the fan seems to be running for a second then shuts off and turns back on and so on.
  • Anonymous Nov 30, 2008
    I have EXACTLY the same problem! I'm wondering if it's worth repairing or just ready for the trash.
  • jim_gonzales Feb 01, 2009
    I have the same problem so I disconnected the speakers as a test and would still occasionally have the overload error.
    Help!!
From the manual pg 27....... "The protection circuitry has functioned because the positive and negative speaker connection wires are "shorted," speaker systems with an impedance less than the indicated rated impedance of this unit are used or under severe use, such as loud volume, excessive power and in an excessively hot environment."
Posted on Jan 17, 2009
My Technics sa GX350 tuner keeps going into overload. It's the only thing plugged in.
Hi mate, had the same problem with my amp.. Take the top off and there is a fan at the back, there are 2 piece's of copper flat wire that touch together and these do not touch anymore so when its turned up or the bass gets stronger it cuts off as the fan should kick in at this point. If you can get these to touch again (bend them) then the problem will be gone!! I have had to do this a few times now though so this is not a long term fix.. I may try soldering!
Jan 01, 2011 | Technics SA-AX910 Receiver
My Tchnics Sa-Da10 shuts down on what appears to
Ahh technics. Technics always had overheating problems, trust me. Every since they started, their amps would get so hot they would hurt to touch. The reason the fan is not coming on seams to be something inside the circuit board. I'm sure that technics could fix this. If the fan works out of the receiver, then it must not be the fan. ;P
I would maybe get a computer fan, and just put it on top of the receiver and turn it on, or send it in for fixing. Also, do you have to crank the volume to get the speakers to play at your volume, and does the impeadence match the receiver. Because you may be pushing the receiver too hard.
Oct 11, 2009 | Technics SA-DA10 Receiver
Overload at medium (4-6) volumes. Can you adjust or disable the overload protection on these Technics amps??
try this mate:
http://www.electronicspoint.com/googlesearch.php?cx=002919058480771089906%3A03mranmmdze&cof=FORID%3A10&ie=UTF-8&q=Technics+SA-GX550&sa=Search#862
May 23, 2009 | Technics SA-EX400 Receiver
SAAX7 Technics stereo receiver stops broadcasting after 20-30 min
Ron- The fan does not turn on when the receiver is first powered on, it will run when the amplifiers begin to run HOT, they are kinda controlled by a thermo switch, if the fan does not turn on usually the receiver will shut down and display a OVERLOAD message in the display panel. My advise is to keep the unit well ventailated with plenty of breathing space around the top vent closure, this will allow air flow when loud volume output is used. Also use the rated ohm speakers with the SA-AX7,
Jan 25, 2009 | Technics Audio Players & Recorders
Overload protection
Doe this always go into overload independent of the volume level? Try disconnecting the speakers completely and running the set. Does the set shutdown then too?
Thanks,
Dan
Jan 16, 2009 | Technics Audio Players & Recorders
SA DA -10
If all the speakers are connected proper and it still says "Overload!!!!!"
Your output amplifier module is most likely failed.
Mar 08, 2008 | Technics SA-DA10 Receiver
Technics sa-ex300 says overload ?
it could be overheating - try aiming a fan at it for a while, see if the problem stops.
Nov 30, 2007 | Technics SA-EX300 Receiver
Technics SA-DX940
Ratnesh, I have this same receiver and the fan only comes on at certain volume levels. Unfortunately I now live in an apartment and can very rarely listen to it that loud. I had the same problem for a little while until I thought about moving the receiver to the lowest shelf with nothing on top of it. This seems to have worked so far although it does still get quite warm. Good luck!
Aug 04, 2007 | Technics SA-DX940
Technics SA-DX940
overload, usually means that is overloaded. i've had the receiver for about 4 or 5 years now and never had problems with it. It was sitting ontop on my tv for those 4 or 5 years, and i haver noticed it untill just recently, (when i bought a new tv and i had to get a stand for it, and i had to stick the receiver in it)that is runs very hot, very quickly; Maybe that is the problem you are having now, that the thins is older and maight be able to handle it as it id b4. Maybe you made some changes to your set up: new speakers, etc.
Jan 25, 2007 | Technics SA-DX940
Technics SA-EX110 Receiver Logo
1,196 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
