Question about Zanussi WJS1265W Front Load Washer/Dryer
Water left behind in filter reservoir
About 12 months ago we replaced the water pump in the machine. Now everytime it is used about 1/2 litre of water is returned to the reservoir where the filter is positioned - bottom right hand corner. I have to soak up this water manually othherwise if it is left it becomes very smelly and subsequently washing is smelly. I have investigated this myself by removing the filter and looking into the area near the end of a cycle. It appears the water is draining away totally and then when the machine stops a whole load of water is returned through the drain hole. I am not sure whether it would make any difference but the dryer hasn't worked for some time. I tend not to use it preferring to dry outside or on the radiators.
  • 26 Answers
There is always water left in the filter at the end of the cycle. Tjis is unlikely to cause the smell problem though.
If you do a lot of 40 degree washes and use a biological detergent you can get a bacteria build up in the appliance which is very unpleasant.
To rectify this, run the appliance on a 90 degree wash with two spoonfuls of washing soda in the soap drawer. Allow the program to complete the cycle( no clothes though) and repeat once more.This should help clean the appliance.
Several appliactions may be required if smell persists.
Posted on Nov 19, 2008
Water left on washer
If you mean "Left in washer"
This could be a blocked/air-locked filter. (a common occurrence not a fault.)
easy fix if so.
First. switch off the Machine at the socket.
Check your washing machine user manual for the location of the pump filter access screw. (Normally situated behind a front bottom clip out panel) ensure you have a few towels and a couple of pans/dishes at the ready before releasing the access screw, expect 2 or three litres of water to drain... and whatever is blocking the filter. (could just be an air blockage or a small object) replace the filter screw and clip off panel, switch on at mains.
Hope this helps.
Aug 26, 2014 | Whirlpool Washing Machines
Where is the pump filter on an lg washer?
The PRIMARY filter for discharged water in most front loaders is located under the opening of the washer behind a small 'door'. There is usually a small tube which you will need to pull the plug from and drain about 2 cups of water into a bucket BEFORE you remove the filter to clean it.
After you unscrew the filter which is mounted from front-to-back and clean it out, replace both filter piece and plug and replace the small drain tube.
Close the access door and operate your machine.
* Clean this filter every month or especially after washing heavy lint-producing materials.
Jul 21, 2014 | LG WM-2277HW Front Load Washer
Need a descaler
instractions are from manual HD7810/00
Use the correct descaling agent
Only citric acid-based descalers are suitable for descaling the SENSEO
machine. This
type of descaler descales the machine without damaging it. For the correct amount,
see under 'Descaling procedure' below. Each descaling mixture can be used only once.
After use, the descaling mixture is no longer active.
We advise you to use the special SENSEO
Descaler (HD7012/HD7011/HD7006).
Read the instructions on the package of the descaling agent.
Never use a descaling agent based on mineral acids such as sulphuric acid,
hydrochloric acid, sulphamic acid and acetic acid (e.g. vinegar). These descaling
agents may damage your SENSEO
coffee machine.
Descaling procedure
1 Mix 50 grams of citric acid with 1 litre of water in a measuring jug. Stir until
the powder is completely dissolved.
2 Fill the water reservoir up to the MAX indication with the descaler mixture.
Then put the water reservoir back into the coffee machine. (Fig. 3)
Note: Not all SENSEO
machine types have a water reservoir with a capacity of
1 litre. If you have a SENSEO
machine with a smaller water reservoir, repeat steps
2 to 6 with the remainder of the mixture without filling the water reservoir up to
the MAX indication.
3 Press on/off button 3. (Fig. 10)
The machine is ready for use when the indicator light lights up continuously.
4 Place the 1-cup holder h with a used coffee pod in it in the coffee machine.
Close the lid and make sure it is properly locked.
Note: Always put a used coffee pod in the pod holder when you descale the
machine. This pod serves as a 'filter' to prevent the sieve or hole in the pod holder
from getting clogged with scale residue.
5 Put a bowl with a capacity of at least 1500ml under the spout to collect the
descaling mixture (Fig. 8).
6 Press the 2-cup button hhand let the machine operate. Repeat this until
the water reservoir is empty. (Fig. 25)
Never interrupt the descaling process!
7 Repeat steps 1 to 6. Replace the used pod with another used pod to filter out
the scale residue.
Note: To descale properly, you have to use 2 litres of descaling mixture.
Never descale the SENSEO
coffee machine with the lid open. Make sure the lid is
properly locked.
8 Rinse the water reservoir with tap water. Fill the water reservoir up to the
MAX indication with tap water and repeat steps 3 to 6.
Note: Do not refill the water reservoir with used hot water or the used descaling
mixture.
9 Fill the water reservoir with fresh tap water up to the MAX indication again
and repeat steps 3 to 6 once more.
Note: Always rinse the machine by letting it empty two full water reservoirs.
10 Remove the used pad and clean the pod holder after descaling to prevent the
sieve or hole in the centre from getting clogged.
Mar 30, 2014 | Philips Senseo HD-7810 Coffee Maker
I have a 1hp sta-rite above ground pool pump. The pump model number is MPRA6E-147L The pump is about 4 years old, and during our summers it runs about 12 hours a day (May through September) and during...
It sounds like there was a lack of water to the reservoir, which is, I assume the inlet reservoir with the basket strainer in it.
1. Is your water level in the pool high enough to keep the reservoir full?
2. There is an o-ring or gasket on the reservoir cover, is it there and lubricated so there is no air leakage?
3. Put a garden hose into the open reservoir to see if the pump moves this water out.
Do all of this with the filter set to just go back to the pool so you can see the results.
Try this and comment back.
Good Luck,
Gary
Dec 11, 2010 | Sta Rite Pool & Spa
How do you clean the filter?
There is a fluff filter on the front of the unit in the bottom left or right hand corner behind the service flap. Have a small tray, like a baking tray underneath it and open the flap with some sort of flat lever,coin or screw driver. Turn the tap about 1/4 of a turn and collect about a litre of water from the unit. When it has stopped draining unscrew the tap all the way out and clean the fluff filter which is the tap in your hand. Also have a look in the hole and you will see the drain pump at the back. Make sure this is free of any foreign particles and can turn. Then re-screw the tap back making sure it is tight. This should be done regularly every 2-3 months to avoid the unit from not draining.
Aug 20, 2010 | Whirlpool Washing Machines
Water left behind drain plug at end of run
C ould be elsewhere or damage to pump impeller/ blades..Check pump loose blades....
Oct 01, 2009 | Washing Machines
Blocked filters/dodgy pump?
The problem you are having could simply be the inlet valve.
The inlet hose is attached to the inlet valve on the machine. Where it screws on that is.
You can get a valve from an appliance parts shop and they are inexpensive.
Jun 18, 2009 | Hoover HTC243 Top Load Washer
B60 special edition clear water surge last couple ounces
Have you tried Descaling? In the manual, it recommends Descaling every 2-3 months, even though you mentioned that you've had yours only 1 month. Worth a try, anyway.
I know they carry a water filter thru Keurig.com for less than $18 that you install right on the water pump in the water reservoir if you live in an area where the mineral deposits are heavy. It lasts 2 months and you can buy 6 replacement cartridges for $25. I just put one in mine today and it took less than 6 minutes to install (5 of those minutes were spent just soaking it in clean water).
If that doesn't help, you can call their Support Team @ #1-866-901-2739 between 7AM-12 Midnight EST. Make sure you have the serial # of your machine before calling. It's located either behind the drip tray (just pull it out) or on the bottom of the unit.
Jan 25, 2009 | Keurig Special Edition B60 Coffee Maker
GE 169164 Coffee Pot Not Brewing
Loosen the charcoal filter. You only need to GENTLY place it in. Your problems will all be solved. I just did it 5 minutes ago and i just brewed a 6 cup pot of coffee completely.
Jan 07, 2009 | GE 106591 Coffee Maker
HOTPOINT AQUARIUS CONDENSER TUMBLE DRYER CTD40
There are three water reservoirs - one at the bottom behind the condenser, a second at the back bottom of the machine and then a third at the top which is the one you would normally pull out to empty.
There is a hole at the bottom of the filter in the first reservoir (at the back of the condenser) which leads to the second reservoir at the back. If the hole gets clogged up with lint/muck then the reservoir at the back does not fill up.
So to solve this, unplug the machine, take out the condenser (front left bottom of the machine) reach through to the back and mop up the spare water with a towel and check that the hole to the back reservoir - you can feel this it is towards the right side at the back of the machine is clear from muck.
Once you have cleared it, water will flow to the second reservoir and then (once you switch on the machine) up to the main removeable reservoir at the top.
Hopefully this helps. GB
Jul 09, 2008 | Dryers
Zanussi WJS1265W Front Load Washer/Dryer Logo
153 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
