Question about Marantz Audio Players & Recorders
I have a nice vintage Marantz 1250 Integrated Amplifier in which the left channel cuts out after a half hour of playing music. Tuner cleaner/lubricant of the channel slider doesn't fix it. Any suggestions on what could be wrong? Thank you.
  • kuww Nov 16, 2008
    Thanks very much for the suggestion. I will take it in for service. Found a local specialist for vintage equipment. Best regards.
  • 905 Answers
The power amplifier IC will need to be replaced , after it heats up is when it fails completely
Posted on Nov 16, 2008
  • jason Nov 16, 2008
    your welcome, and thanks for using fixya
    electech
Fuzzy sound out of one speaker, goes off after it warms up
If i were you i would double check wiring and connection for that speaker in particular. then user process of elimination to make sure its the speaker/wire or the port that is distributing the music. you can do this by switching speakers of the ones that are functional and test them. this will help you narrow down your answer
Nov 03, 2015 | Marantz Vintage 350 Stereo Amplifier & Mt...
How to change the jack with new one??
Cut down the old jack.
Remove the cup from the new jack and pull up to the on the cable.
Clean up the wire about 1 cm long. There should be 1 common ground, one for Left and one for right channel.
Solder the Left channel's wire to the inner point.
Solder the Right channel to the middle point .
If you have two independent ground just spin together and solder them to the end point of the jack.
With plier press together the jack end, thi swill hold the wire
Pull down and twist the cap.
Feb 10, 2015 | Juster Vintage Active 95a Multimedia...
How do I check the internal wiring for input voltage on a Marantz 4060 Quad Amp?
The only way would be a voltage selection switch on the back of the unit, or changing pigtail leads on the primary side of the power transformer.
Apr 30, 2014 | Marantz MA-9S1 2-Channel Amplifier
There is a crackle when i turn the volume knob.
First unplug it. Sounds like you need to spray some tuner cleaner in the pots that are crackling. Pull the knob off and you should be able to use a spray can of tuner cleaner with the straw that comes with them to spray into the potentiometer , then rotate the pot several times while it is still wet. After cleaning them all, wait 10 minutes and then try.
Jan 09, 2014 | Marantz Vintage Model 2220b Stereophonic...
I am thinking of replacing my now very old JVC AX 330 amplifier with a Marantz PM7003 amplifier and want to know if this is a suitable replacement in terms of power output etc.
You, sir, are a rare adherent to stereo-only electronics. Are you replacing it for cause (showing its age)? The PM7003 is only 2 x 70 watts like the JVC but it also has separable preamp/amps so you COULD upgrade or augment the power output with external amps and still control it all locally.
Of course, any current AVR's do that too and bring digital sources and multichannel audio to the mix for as little as the PM7703 may cost.
Jun 23, 2011 | Audio Players & Recorders
I have a Technics SU-V460 integrated amplifier, and the left channel (speaker) keeps "dropping" out . I have to turn the volume right up in order for it to "kick" back in. Would this be...
There are three possible problems with your system. The first, and cheapest to fix, is that the wire connecting the left channel is faulty. To test this, unplug the wire from the back of the amp and put a new one in, then play some music BEFORE putting everything back into it's respective place. If the speaker doesn't cut out anymore, problem solved! Speaker wire is very cheap too. If the problem persists, try connecting one of your other speakers that you know works to the input. If that speaker cuts out as well, then the amplifier is the faulty component. That will cost some money to repair (between $50-$150 depending on where you go, excluding the price of a new amplifier). If the speaker you know is not faulty works when plugged into the left channel, then the only other option is that the original left channel speaker is faulty. This could cost between $25-$100 to get repaired, excluding the cost of a new speaker. It will not be as costly as a new amp, but will definitely cost more than a new speaker cable.
Mar 03, 2011 | Car Audio & Video
Marantz Pm-7200 left channel weak compared to the right
hmmm. Let's start by swapping the wires you are using for your speakers. Double check the wire connections first, then take the left and place iton the right and vice versa.
May 05, 2009 | Marantz PM7200 2-Channel Amplifier
Heat in operation of marantz pm 74d
Sounds like your left channel output transistors are getting weak.
Jan 17, 2009 | Marantz PM-68 Amplifier
Vintage Stereo Connection ???
Hi spanky
Where to start :) I am excited thinking about them :p You got 2 totally cool pieces of classic vintage gear there in the C2 and the Marantz. I have a C2 preamp myself (gathering dust but wont sell it cos its excellent) and the marantz would be totally cool to have(but then I am a little biased towards 70's vintage marantz). They ruled the roost in HiFi amps throughout that decade.
Because they are both integrated amps, you could use them as standalone systems with a pair of speakers, and just plug your favourite gear into them. If you just wanted to run up a nice sounding HiFi, I would sell the kenwood gear and just keep the Marantz. The Kenwood kr1100 has the edge in power, so if it is grunt you are looking for use that. Because vintage sound is all about stereo, you only really need an integrated amp to get great results.
the specs are
# Kenwood Model Eleven G (KR-11000G) Receiver
120W per channel min RMS, both channels driven, at 8 ohms from 20 to 20.000 Hz with no more than 0.03% total harmonic distortion.
Dynamic power output 440W at 4 ohms
Power bandwidth 5 Hz to 70.000 HZ
Frequency response 5 Hz to 100.000 HZ -1.5dB
Signal to noise ratio 115dB
The marantz is a little lower in power at 75rms a channel, but will have the sonic edge in vintage sound over the kr1100. Look them up on ebay and you will find that they do have some value to collectors and people seeking nice tone. There is an 1152 for sale here for AU$900
Best bet is to fire up the 2 integrated amps,and see how they are going. Run them for several hours to be sure there is no strange noises and crackles. Then decide if you want power or finesse.
You could also run both amps from the C2 preamp by connecting to the Amp in connections to the rear of the integrated amps.
happy to talk to you more about it, hit me with a Fixya if my advice was helpful to you. I would keep the marantz, use that and sell the rest and buy some nice speakers:)
regards
robotek
Jul 20, 2008 | Audio Players & Recorders
Marantz SR-5200 - Analog inputs only play the right channel
please invert your cable and watch if the problem moved the problem in your cable change it with new one.from any radio shack near you or any electronic store.
Jul 05, 2008 | Marantz SR-5200 Receiver
210 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
