Question about Abit IP35P Motherboard
Not switching ON
I power my pc and he display me nothing, he don't boot, beeb ...nothng. Power led is green, so don't know is CPU maybe wrong, please help.
MB - Abit IP35
CPU - INTEL Core2Duo
  • eparigo Dec 27, 2008
    i got that problem too. mine was working fine then i went to microsoft update and during install it just went dead. the post stops at code 25.
It turned out that the bracket on my video card was too long and when i was tightening it , it was bending and stressing the video card. put in some spacers and it is working fine now
Posted on Dec 28, 2008
Asrock G31M-S No Display/Booting
First of all, check if there are any inflated capacitors, if there is even one- ditch MBO, other capacitors will soon follow. If no inflated capacitors proceed with these diagnostic steps: 1/ disconnect all peripherials (DVD, HDD, card reader...), leave only MBO, PSU and RAM (and CPU of course); if nothing happens 2/remove CMOS battery (CR2032) for 20-30 sec with power cord disconected from computer, that will reset BIOS; 3/ take out RAM sticks, then, if you have more than one stick, try with each stick separately (it might be faulty RAM); 4/power on MBO without any RAM-if speaker is present it should give BEEP signals; 5/ try with different PSU, many power supplies are faulty even when they do give power to MBO.
If nothing of above does not help than you have faulty MBO, because CPUs are so rare to fail that in my 10 years of experience in PC service I had 3-4 fried CPU-s, and even that was because costumer tried to clean PC, removed CPU cooler and than incorrectly placed it back or didn't put thermal paste afterwards. asrock-g31m-s-no-display-booting-yuc33qzjuwfqgyyin4u45syc-4-0.jpg
Dec 18, 2014 | Asrock Computers & Internet
Power supply LED (Green) turned to red and blinking and nothing works
Power Supply is bad. Plain and Simple. Replace it. Regards, joecoolvette
Aug 31, 2012 | MSI Hp Compaq Evo Ms-6541 Rev 1.0...
Pc not booting
If you hear the CPU fan turn on that doesn't mean the CPU itself is working. It can be only that the motherboard is getting power. Check all your connections such as monitor and peripherals and re-connect them. If you still don't get P.O.S.T. or ANY letters or boot options on your screen then your CPU is dead. (unless your monitor is bad)
Another easy diagnostic is using your ears. For example the pitch sound of the fan in some motherboards tends to lower and then increase because it's reading of the hard drive. This means your CPU is ok but either your graphics connection is bad or your monitor is.
Apr 22, 2012 | Intel Motherboard
Cant get computer to
Disconnect everything from the motherboard except the power supply, CPU and power switch.
Turn on the computer. You should hear 3 beeps because you removed the memory.
If you don't hear any beeps, check the power supply. Check all the connections. Did you connect the 4 pin power? Did you skimp on it? A common mistake is to get a cheap, high-power supply. Just because the box says it's 1000 WATTs doesn't mean that will carry a steady load.
Still nothing...
It's either a bad motherboard or processor. If you have another processor that is supported on that board and you know it works, try it. If it boots return your CPU for a good one.
Unfortunatly, if it doesn't boot with a known-good processor that just proves the board is bad; it doesn't prove your CPU is good. You may have more issues.
Mar 08, 2010 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
First Hello. Before few days,when I turn on my PC(but I was unpluged my machine from electricity) and on monitor displays CMOS wrong set date/time,cpu frequensy.I hit BIOS set up sittings and Windows xp...
Replacing the bios battery was the correct thing to do. Answer me this. The Asus motherboard should have a green LED light lit (Standby power LED), when the system is turned off. Also keep the power cord for the power supply connected at all times. Though it is possible the replacment bios battery was all ready low on voltage or dead. When you're system is turned off the power supply continues to send 5volt DC to the motherboard which maintains the bios 3volt DC.
If the green LED is not lit than there is no power charging the bios battery and every time you boot the system the bios will have lost its settings. If the green LED is red in color, than the problem is within the standby switch built into the motherboard. The standby circuit can not be repaired. Double check all power connectors from the power supply to the motherboard. If everything has a good connection and you're bios settings continue to reset you should consider replacing the motherboard. At this point you have nothing to loose. Install the latest bios update,
(Beta Version 1010.005). 2006/02/14 update.
Jan 23, 2010 | ASUS A7V880 Motherboard
Motherboard shuts down before booting !
You should clarify this a bit more, but please make sure all of your fans are plugged in and the no jumpers are set to over-clock the processor.Also, double check that everything is fundamentally compatible.
Dec 16, 2008 | Computers & Internet
LG Flatron ez t713sh 17" CRT Problem:
I already have the solution to that problem. It is a faulty capacitor that needs replacement. If you want you can copy and paste this link
Jun 30, 2008 | LG Flatron Ez T710BH 17" CRT Monitor
When a power supply goes out the way yours did, it's going to fry the MB 99% of the time. So you're going to need a new MB. It's possible that you CPU is ok, but that could also go too. I would replace the MB first, then the CPU if that doesn't work.
Nov 07, 2007 | ASUS A7V8X Motherboard
Power ok but No Display
see this one
Sep 16, 2007 | BenQ T701 TFT 17" LCD Monitor
Power LED on but no boot up
Its the Mother Board..I had the same problem and had to have a new MB put in
Feb 17, 2007 | Gateway (4000811) Motherboard
Abit IP35P Motherboard Logo
140 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
