Technics sa dv280 hard reset
Standby stays on when pressing power button it just clicks back off again but its showing the f61 wen the processor clicks in on standby mode i was told it was knocked off the shelf by accident can u help??
4 Suggested Answers
SOURCE: cuts out
Check your speakers. your speaker may be defective
Posted on Dec 21, 2007
tempo123
SOURCE: technics sa dv280 hard reset
DESOLDER THE REGULATOR AND CHECK IT OUT AGAIN IF IT'S OK THEN REPLACE THAT BIG GREY AMP PART STICK TO THE RADIAROR ON THE BACK
Posted on Dec 13, 2008
dunnbiker
  • 8546 Answers
SOURCE: what errore code f61 means
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it '*****'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Aug 04, 2011
HOW TO RESET HARMAN KARDON AVR70
Hi, Try this. Hope this helps and I have the link here to the manual.
Processor Reset
If the AVr behaves erratically after a power surge, first turn off the front-panel
main
power switch and unplug the Ac power cord for at least 3 minutes. plug the cord back
in and turn the AVr on. If this procedure doesn't help, reset the AVr's processor as
described below.
note: resetting the processor will erase all user configurations, including speaker and
level settings, and tuner presets. After a reset, reenter all of these settings from your
notes in the Appendix worksheets.
To reset the AVR's processor:
1. press the front-panel Standby/on switch to place the unit in the Standby mode (the
Standby Indicator led will turn amber).
2. press and hold the front-panel Standby and memory/folder buttons until the reSet
message appears on the front-panel message display.
3. press the memory/folder button again to reset the AVr's processor.
If the AVr does not function correctly after a processor reset, contact an authorized
harman
kardon service center for assistance.
to locate an authorized service center,
visit our web site at www.harmankardon.com.
https://www.harmanaudio.com/on/demandware.static/-/Sites-masterCatalog_Harman/default/dw409ee4c9/pdfs/AVR700NEW_OM_EN.pdf
Jul 28, 2016 | Harmon Kardon Harman / Kardon Avr 70...
Output ic for Technics model SA-DV280
You can try this site. Be wary though. http://www.manualspoint.com/document_order_init.php?search=TECHNICS DV280 PARTI RICAMBIO SCHEMI&doctype=4
Sep 28, 2015 | Technics Audio Players & Recorders
F61 Error on SA-HT930 Panasonic
As sugested by many experts.I replaced the ic no rsn311w 64d,still the error code f61 appears.Now where is the fault.?
this is for the Panasonic sa-ht 880.
Aug 28, 2012 | Panasonic sa-ht930 Home Theater Audio...
Technics sa dv280, input selection
You can try starting the music on your computer before trying to change the input on the receiver, maybe it needs to recognize some input before it will change if this doesn't help double check your connections & settings ?
Jun 25, 2009 | Audio Players & Recorders
Code f61
the f61 code is an audio code for panasonic first make sure all connections are correct and tight for spearkes...at the base if unit has base and with connections in back of unit and are fully in to connection terminal...make sure speakers are on and not on mute ...sometimes though you may have to re strip the wires to get into connection termianl in the back of the unit if that does not work call panasonic 1-800-211-PANA(7262) for more technical support
May 15, 2009 | Panasonic Audio Players & Recorders
Nov 16, 2008 | Technics SC-EH780 CD Shelf System
Technics sd player
hi i have got a technics sl-eh760 an when i turn it on it works but when i press the open button it comes up with error can you help me out
May 14, 2007 | Technics SCEH790 CD Shelf System
101 people viewed this question
 Grubhead
Grubhead
