Question about JVC AV-48WP30 48" Rear Projection Television
IC's for JVC AV-48WP30
I know I have a convergence problem and I want to replace the IC's but I cant find which ones to get online. Anyone have a link of one that would work?
Thanks
  • chunalt787 Nov 16, 2008
    I have found instructions online to put them in myself and I work with electronics, boards, and such at work so I know how to do it I just need the specific part.
    Sergeant:
    Champion:
  • 346 Answers
You need to get the exact ICS that came out of the tv. you do need a qualified tv technician to solve these problems
Posted on Nov 16, 2008
  • cyriacus joseph Nov 16, 2008
    the ics are mounted on heat sinks on the circuit board they could be stk392-110 for example.
    cathray has good parts 416-241-1106
    check also small ohms resistors in front of ics .they normally go bad
2 Suggested Answers
  • 8457 Answers
SOURCE: JVC AV-48WP30 convergence went out, replaced chips, still probs
Change all the resistors?Resolder all the heat sinks?
Posted on Nov 26, 2009
Replaced IC chips, but can't fine-tune convergence.
U know how to use a multimeter right?Check and replaced all the resistors near the 2 convergence ICS.Most resistors are big and blue core in colors.
Feb 15, 2010 | JVC AV-48WP30 48" Rear Projection...
JVC AV48WP30 convergence ic
I'm in the process of trying to replace both convergence IC's in my JVC also. I was able to buy both IC's (they look like black semi-rectangular components with 20 pins sticking out...like a computer chip only much bigger) at a TV repair shop for about $15 each. They were clearly labed STK392-110 (but could be 150 or 180 if you wanted to upgrade).
Jan 18, 2009 | JVC AV-48WP30 48" Rear Projection...
you need two STK392-110 convergence ICs. You can get them at the following link with free instructions on how to replace them. They actually have the repair kit for your model which contains both convergence ICs and the convergence resistors.
Heres the link.
http://servicemanuals.vstore.ca/
Nov 16, 2008 | JVC AV-48WP30 48" Rear Projection...
Convergence problem with my jvc model av 48pro
Is replacing the ic something I could do myself? Is there more than one ic that I would have to replace?
Jul 19, 2008 | JVC AV-48WP30 48" Rear Projection...
Av-48wp30
If the convergence Ics and resistors are good its most likely related to the velocity boards that are attached to the Red CRT convergence yoke. Its the small board about half way up the neck of the CRT. If you need one let me know as I have a source for JVC boards for that model.
Jun 28, 2008 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP30 48 in. Rear... Problem
Your convergence I.C's ( integrated circuits ) Have failed. Replace Both I.C's with Stk392-150's. The unit is equipped with 110's. These are large IC's pn the convergence board located near the front of the unit. You need soldering/desoldering experience to do this job. I would recommend seeking professional assistance.
Jun 04, 2008 | JVC AV-48WP30 48" Rear Projection...
Remote LOST - need info on what button to press...JVC AV-48WP30
There might be some features that the universal remotes aren't able to do. To perform the convergence alignment you should have the original remote.
Do you have the user manual or service manual?
The service manual will explain this process better.
Apr 10, 2008 | JVC AV-48WP30 48" Rear Projection...
Jvc av-48wp30 convergence problem
1. if the 1.5 ohm resistor was open, then you may have fried your new convergence ic's. Sorry
2. bettween a 1.5 - 1.9 ohm resistor will work
3. press sleep button, set to 30
hold down video status button and press display on remote
select convergence from the new menu and hit OK.
Do fix the convergence before you try to align the convergence or it will look horrible after you get the circuit fixed and will be harder to align.
The white button is there because the DCU (digital convergence unit) can be erased by holding that button and turning the set on.
I WOULD NOT RECOMEND THAT AT ALL!!!!!!!!!!!
Hope this Helps.
Mar 16, 2008 | JVC AV-48WP30 48" Rear Projection...
Av-48wp30
check for loose connections on convergence amp ic and crt boards
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Jan 27, 2008 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP30 48" Rear Projection Television Logo
62 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
