Question about HP Compaq Presario V2000 Notebook
USB Ports crashing system
Hi I have a Compaq Presario V2000 notebook and everytime I plug in a USB device the system freezes. I think the problem started after I installed Limewire. Since then, I have uninstalled the program. I have tried system restore, reinstalling the usb drivers, windows updates and the windows chkdsk utility. I have also booted the system in safe mode to see if the usb ports work. Nothing I do seems to work - anyone have any ideas?
  • modernes jones Nov 30, 2006
    I don't think that it is limewire that is freezing the system though. It was uninstalled and the system restore was set for before it was installed. Whenever anything is plugged in to a USB port the system freezes and I have to hit the power button.
    Also, I've checked the USB drivers in the device manager and it appeared that everything was working correctly(ie. there were no yellow exclamation points). Is it possible that it is a hardware issue?
    President:
  • 2,961 Answers
If you have done a system restore you have probably restored your problem with limewire also, although what it is that's related I don't know, it's more than likely a dial up or connection problem that is causing limewire to freeze yur system. Check your usb ports in device manager see if there is an exclamation mark or a cross, then refer to this solution for further checks. http://www.fixya.com/support/t125452-another_device_installation_underway
Posted on Nov 30, 2006
  • andrew pester
    andrew pester Nov 30, 2006
    Hi, did you look at the last comment on the post i gave you as previous fix about checking in the services.
    Did you also install the drivers that the motherboard manufacturer reccomends for USB2 and have you put on XP SP2
The usb ports on my v2000 no longer work. When I plug in any usb device it is not recognized.
Try reinstalling the usb drivers for your computer. You can also check to see if its a hardware issue by pluging a usb powered device like a cooling pad in the usb port. If it gets power, chances are its a software issue. If no, then its a hardware issue.
May 21, 2010 | HP Compaq Presario V2000 Notebook
Compaq Presario V2000 PC Notebook: All ports are "in use" with nothing connected. I c...
Click on start. Then click on Run.
Type in MS config.
Uncheck load startup Items.
click on ok and then click on restart.
Any application which turns on and starts using your port when the computer turns on would stop loading on their own and you will have free ports to use.
May 17, 2010 | HP Compaq Presario V2000 Notebook
Port problem
there are many devices you can get to add usb to an existing device....ext keyboard connection.pmc slot,com ports ,printer ports even usb ports to update usb 1 to usb2 (of course that ones no good for you)
these are all plug and play devices
you could also install one to pci (easy in desktop)
Oct 30, 2008 | HP Compaq Presario V2000 Notebook
Compaq V2000 notebook freezing
you dont have much memory for your notepad. you must have at least 20% to do anything like that.
to check to see if you have at least 20% you need to do a disk defrag and than that should help.
Jul 29, 2008 | HP Compaq Presario V2000 Notebook
Compaq presario V2000 notebook freezes
Did you reset your BIOS? sounds like your usb is not configured properly
Jul 25, 2008 | HP Compaq Presario V2000 Notebook
Compaq Presario v2000 w/ dead USB ports
Does 1 Usb port work on your computer? Sometimes they can go out. Do you have a USB hub you can use?
Jul 19, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq Presario Desktop USB Problem
Go back in to th device manager
Look for the yellow and re-install them
Let me know
Jaywizz
Nov 19, 2007 | HP Compaq Presario V2000 Notebook
I have the same problem with my Compaq Presario V2000. Lost both USB ports and HP tells me that the motherboard has to be replaced at $300 +..I searched and found a PCMCIA card with two USB ports for $10. No problems with the USB ports on this card..great and cheap solution.
My belief is that the compaq usb ports do not have power limiting circuitry therefore allowing you to overload the output power on the ports. My ports failed after I downloaded into a burglar alarm system I was programming.
Oct 17, 2007 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V2000 Notebook Logo
189 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
