Question about Gateway MX6920 Notebook
Gateway MX6920 won't power on.
I have already replaced one power cord and that solved the problem for 6 months. It now will not turn on with the battery in place or removed with another new power cord plugged into a working outlet. I thought it may be the AC Jack. The local repair shop said I need a new battery. If that was the problem shouldn't it have worked with the battery removed but plugged into a working outlet?
  • 458 Answers
You Need To Replace The DC Jack In The Laptop...
It Is The Jack THat Your AC Adapter Plugs into....
The Jack Needs to Be Unsoldered/Removed/Cleaned And A New Jack Installed..
I Wouldn't Bring It To That Same Repair Shop To Do THe DC Jack Repair FYI...... ouch!!!
Posted on Nov 17, 2008
Laptop won't power on with ac adapter or battery
Could be a combination of things.
1) Battery is low. Not enough power to turn the laptop on.
Caused by;
2) AC adapter has a plug on the end of the cable. The plug plugs into a DC Power Jack on the laptop.
The DC Power Jack is bad.
2a) The DC Power Jack has a bad connection to the motherboard, (Cracked solder joints), and/or the jack itself is bad.
2b) Center Pin is loose in the jack's mount.
The back of the Center Pin where it mounts has become loose.
2c) The plastic body of the jack, which composes the jack's case, is cracked. This allows movement of the Center Pin.
2b, and 2c cause a bad connection with the AC adapter plug.
No charge to the Battery, no power to the laptop.
[ If this is the case the DC Power Jack needs to be resoldered to the motherboard. The cracked solder joints need to be re-melted, (Reflowed)
Entire laptop needs to be disassembled down to the bare motherboard in your hand.
(No Processor, Ram Memory, or any adapter cards mounted to the motherboard. Nada)
The DC Power jack needs to be replaced.
This entails disassembling the entire laptop, down to just the motherboard in your hand. (Same as above)
The old DC Power Jack is de-soldered, and a new one soldered in place.
Very FEW computer repair shops have the necessary skill level.
They just want to replace the entire motherboard.
IF one is available.
More Ka-Ching for them also. ]
3) The AC adapter is bad.
Not providing power to the laptop, to charge the Battery, nor give power to the laptop without the Battery.
AC adapter cord from adapter to plug, which plugs into the laptop, (DC Power Jack), may have a break in it.
May be an intermittent contact provided by wiggling the cord.
If this is the case the wires have stretched, and broken.
Wiggling causes the wires to briefly touch, and make contact.
Where this cord meets the plug itself. A lot of times there is a break in the wires in this area.
Solution is to replace the AC adapter. There are universal AC adapters you can buy, or perhaps Gateway still has some for sale.
Oct 21, 2010 | Gateway MX6920 Notebook
How do I enable wi-fi on gateway mx6920 laptop
Follow this link to get the drivers for your machine. Be careful to read for the newest udated drivers.
Mar 21, 2010 | Gateway MX6920 Notebook
I can not get my laptop to turn on
Try another power supply and battery. If not you will need to replace the system board.
Feb 23, 2010 | Gateway MX6920 Notebook
Problem with gateway-service pack 3
yes you uninstall sp3 then your problem is solve.
May 14, 2009 | Gateway MX6920 Notebook
Video card for gateway mx6920
no... laptop is only biltin card you cant replaces VGA card in laptop
Thank you
Pls give you me a rank as possible
Apr 16, 2009 | Gateway MX6920 Notebook
Compatible body parts for Gateway MX6820
Yes. the beast bet is to stay within the 6000 series.
HPmodel support link:
Jan 14, 2009 | Gateway MX3228 Notebook
Lap top will not charge
1. You need to see any bios updates for your laptop, if yes update bios.
2. If update didn't solves your problem you need to replace battery.
Apr 24, 2008 | Gateway MX6920 Notebook
Gateway mx6920
try to remove your memory then use the eraser to clean up the tip of the memory then put it back try to turn in on
Mar 23, 2008 | Gateway MX6920 Notebook
Gateway MX6920 Notebook Logo
175 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
