Home | IBM | ThinkPad T41 PC Notebook | Thinkpad screen goes bla...
IBM ThinkPad T41 PC Notebook
Problem for IBM ThinkPad T41 PC Notebook
Thinkpad screen goes blank if I touch/move laptop and reboots.
By aboland on Nov 16, 2008
Anytime I moved my laptop, the screen would switch off. I left it with PC repair shop. They said it worked fine for them.
I took it home. Now I just have to touch the laptop (usually lefthand corner beside mouse pad!) and the screen switches off. Sometimes it reboots as well without me doing it.
When the screen switches off, if it doesn't reboot, I have to press power button to switch it off and then back on.
Now, if I power it up, and leave it on a table, I can usually keep it going long enough to check emails etc. However, if I don't use it, the screen will switch off itself after about 5 mins.
There are no keyboard strokes that will get the screen back on (tried Fn-F3; ctrl-alt-del; etc.). Connecting to an external monitor doesn't help either.
Comments:
Feb 18, 2009
- I have seached the web for answers to this problem.
Apparently there is a video chip issue. Through use the connections melt. This can't be fixed by a quick solder. It may be possible to do a repair using a heat gun; but every site that mentions this says that you need to know exactly what you are doing (requires precise temperatures) and even then still requires a lot of luck. I couldn't find any techie person who knew how to do this for me.
I replaced my laptop. I also salvaged my 120GB drive (buy an external case for about £15 and you have a perfect portable back up drive; and can still access anything you had saved on it from your sThinkpad).
Same Problem
Feb 11, 2009
-   screen will go black or starts to display "staticky" type of appearance, everything freezes up; was watching DVD and it stopped and screen did the same thing, followed by black; took laptop to office this morning, worked all day, and then was running virus scan ondemand Mcaffee, and it froze up in the middle; screen froze, had to power off with power button, and now, it is black; won't display anything but battery light and as described below; at one point, during all of this, the screen displayed a message to me, just before one of these annoying instances, that a driver was malfunctioning, and i can not remember what it said; ad--- driver or something like that; it feels like something inside is fighting with other software;
what is solution?
-   millerlee
Feb 03, 2009
-   Have aThinkpad T40. Screen can go black without any prewarning. Power and battery lights are on. Only way to restart is to press power switch until off. Same problem happens also sometimes when I start laptop. All lamps blinks once and then only power and battery lamps stay on. No initioal screen and no hard drive activity. After a few on and off it suddenly starts normal and can work for a day or days without problem. Have run chkdsk.
Any soulution? /Arne-   arnebergman
Jan 30, 2009
-   I have the same problem, if you push up on the left side it goes blank, or even if you move the screen a little, there is some loose connection somehwere, but where? No its nothing to do with monitor settings or screensavers, its very obvious the screen goes blank only when pressure is physically applied to the body. -   Guest
Jan 21, 2009
-   same problem - just blanks out when i put pressure on the left corner of the machine. makes me think its some loose connection or overheating issue.. please email jokestars@gmail.com if you've found a solution - GOING CRAZY HERE, thanks. -   jokestars
Dec 07, 2008
-   Hi Aboland. I have exactly the same problem wit laptop as you.
I am getting more and more crazy due to that, so that, please; may you help me telling me how have you resolved this problem?. Thank you very in advance.
My e-mail is: alfredocampillo@terra.es.-   alfredocampi
Solution #1
posted on Nov 17, 2008
Somewhat Helpful)
janelu
Rank: Wiz
Rating: 82%, 47 votes
Have you check Power Option from control Panel to make sure that power Scheme never take off your screen after 5 or 10 min?
Comments:
Feb 18, 2009
- for this case, it is most likely video chip or video conection problem, which need chips level technician to do some re-solder job, but that's not cheap.
What you can do, to check IBM web about your laptop feature for the video memory if it share with main memory or indppendent(there is memory in video chip), simple remove or replace memory if it is share with main memory, otherwise you have to go to chips level tech to repair.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Oct 24, 2009
Not Rated)
thebunnygirl
Rank: Apprentice
Rating: 0%, 0 votes
Push down on the center of your computer and restart it
Was this helpful?
Yes
No
Solution #3
posted on Jul 28, 2009
Not Rated)
mjchung
Rank: Apprentice
Rating: 0%, 0 votes
I'm not sure if you're still having this issue, but I was and I came across your query while searching for an answer. What has seemed to work for me was to open up my t41, give everything a thorough dusting, and placing a thin piece of cardboard below the pcmcia caddy. I've been running my laptop for about fifteen minutes now, running tests like carrying it around with one hand holding the left corner. I can't vouch for why or how long it'll work, but it seems to have resolved the issue for now. Hope this works for you too.
Was this helpful?
Yes
No
Solution #4
posted on Jul 24, 2009
Not Rated)
DannyDannyD
Rank: Apprentice
Rating: 0%, 0 votes
I have the same issue as you with a R50e thinkpad, clearly IBM have made a huge error in production!!!!!!!
Was this helpful?
Yes
No
Solution #5
posted on Feb 18, 2009
Not Rated)
millerlee
Rank: Apprentice
Rating: 0%, 0 votes
talked it over with my resident technoxpert and he took the secondary model i have here, which has the same problem, and is going to review its innerds for dirt and filth and a crack. he said a hairline crack, frequently appears in these models, and this is in the circuit board near the power bar (where the power button is with the little access IBM button and the audio volume buttons). He demonstrated that by pressing gently down on the bar and the power button simultaneously, the machine powers back up normally. taking the hacksack ball suggestion, i placed a small object in the center of the machine, under it, and exerted reverse pressure on the power bar area, and yes, that does significantly diminish the occurence of the problem. i like the idea of finding an alternative casing for the hard drive as a back-up, and just replacing the unit for a more durable unit.
any ideas on a more durable unit? I guess thinkpads aren't designed to be used 24/7 by us OCD types...
Was this helpful?
Yes
No
Solution #6
posted on Feb 17, 2009
Not Rated)
vienemo
Rank: Apprentice
Rating: 0%, 0 votes
Same issues as above, but I have found that if O prop up the back of the laptop with a hackysack ball, the issue lessens.
Sometimes when trying to reboot, I get nothing but the black screen. I found that by exerting a little pressure on the casing just to the left of the on/off, while pressing down the button, I have a boot screen and success.
The issue is getting to the point where it is beyond a minor frustration and having read of this issue over and over, it would be nice if someone at IBM could give us an answer to this obvious deficiency.
Was this helpful?
Yes
No
Popular Solutions for IBM ThinkPad T41 PC Notebook
Questions and Unsolved Problems for IBM ThinkPad T41 PC Notebook
Do you recommend IBM ThinkPad T41 PC Notebook?
Answer
Answer
I bought used ibm t41 with windows xp pro. I need picture of layout so I know what all keys do.
Answer
Have Thinkpad t41 running XP Professional. Trying to connect to netzero dialup. Get a 633 modem or... (More)
Answer
hello there how to switch the letter key back to letter type
Answer
I am trying to replace my t41 monitor. I need instructions. Can you please help? THanks!
Answer
I had this T41 for 4 years. The only thing I've changed is an additional 512MB memory which was... (More)
6 Other Users Have The Same Problem - Continued
Comment by alfredocampi, posted on Dec 07, 2008
Hi Aboland!.
I have exactly the same problem with my laptop as you.
Please, if you know the solution; may you help me to fix it?. I would be very pleased if you tell me how to resolve it!. I am in a hurry to fix it because I am getting crazy!!! =D Thx in advance.
Thank you
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For IBM ThinkPad T41 PC Notebook:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
