Question about Kenmore 2.1 cu. ft. Portable Top Load Washer
Kenmore 110.2970090 Not spinning, motor still runs
Everything seem to work except on the spin cycle. It drains fine but then doesn't spin.
Themotor runs (I can hear humming and the lid shakes a bit) but it doesn'tspin on the inside anymore (eg: opening lid at different times showsclothes in exactly the same configuration). The tub can be moved ifmoved by hand (and the springs still pulls it back to the center).
About this model (I could provide photos if someone tells me how to upload to this site):
-Top load portable washer
-8 years old
-The "console" is at the front of the unit (and not in the back as I've seen on most pictures on this site)
-Putting it on its side reveals the following:
--There is no "panel"/sheet of metal blocking my view of the interior.
--It has a belt so I'm thinking that the motor is NOT directly connected to the transmission.
--Ican manually spin things and other things spin such as the belt andagitator (Not sure about the name but its the thing in the tub whenlooking from the top of the washer).
--The white-ish round plastic parts seem to be in good condition (no broken "teeth").
  • wb416 May 01, 2009
    my problem is the exact same as described above. drains fine but doesn't spin. I'm off now to check the belt condition as suggested. if any other solutions, I'll be lookin. thanks
  • 50 Answers
Check integrity of the belt. it is possible that it is slipping and not making good contact with the pulley to shift it in to the correct position.
Posted on Feb 26, 2009
My Kenmore washer drains after the rinse cycle but won't spin at the end of it's cycle. If I manually set it to the spin cycle, it spins just fine. Desperate!!! The lid switch was just replaced about
Possible there is problem with the timer controller unit. It seems that the stepper motor is not moving to the next cycle until you manually move it to the spin. You can use some contact cleaners on the switch and also carefully try to see if the timer moves within , replacement is a costly issue and must be debated
Nov 20, 2013 | Washing Machines
Loud noice in the spin cycle while going fast
What is the complete model number of your unit?
Dec 04, 2012 | Kenmore HE2 Plus Front Load Washer
Kenmore 110 Spin Cycle
Assuming that this is a basic top load, direct drive, neutral drain washer it seems as if the problem is likely in the timer.
The transmission and draining are controlled by the motor which gets it's power through the timer. If the timer isn't advancing once it gets to the spin cycle area, the motor keeps getting power, the machine keeps spinning and only by pushing in the control knob will the motor stop.
Here are a couple of places to look at how the machine works and parts for a basic Kenmore washer.
Sears parts site:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a number of sub catagories for the washer components.
Whirlpool Installation and maintenance PDF.
This is a public domain Whirlpool manual describing how the washer works and a good troubleshooting section.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Sep 21, 2009 | Kenmore 22642 Top Load Washer
Kenmore top loader washer - No spin - motor rattles - wtr pmp ok
Bad/broken coupler/ http://www.davesrepair.com/DIYhelp/DIY285753.htm
Sep 01, 2009 | Kenmore Washing Machines
Kenmore stackable washer/dryer 417.97802792 won't drain
its your brushes on your motor or the motor itself but my guess is the brushes replace and enjoy
Jun 23, 2009 | Kenmore 98702 Stacked Washer/Dryer
1 year old kenmore washing machine won't spin, agitator works OK and the water drains, just won't spin.
you have a bad door switch everything on a washer works fine with a bad door switch except the spin cycle
Jun 07, 2009 | Washing Machines
Kenmore Elite Washer 110.24992300 spin problems
The pressure switch is mis-reporting the water level to the ECU.
Test/replace the pressure switch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 29, 2009 | Kenmore 24032\24036 Top Load Washer
My washer will not spin in any cycles
i would still want to removehte motor and check for a craked motor coupling, if its cracked the tub willl not spin( or agitate) but will drain.
Mar 17, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore portable compact topload washer model 110 49722992--won't spin!!
sounds like a broken motor coupling( this machines equivelent to a belt. part number 285753a . mounts directly to the motor shaft and connects to the transmission, order a new one it installs between the motor and transmission,assy
Apr 03, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
Kenmore 2.1 cu. ft. Portable Top Load Washer Logo
422 people viewed this question
Fordexpert
Archaeology
Archaeology
reliableservice
