Question about Maytag Kitchen Ranges
F3 error code - Maytag Kitchen Ranges
  • 116 Answers
Hi Bryan
An F3 error is a temperature sensor related problem. Check to see that the connections to the sensor is not open (or shorted). If the wiring is good then the sensor must be replaced.
Regards
Posted on Nov 16, 2008
The oven beeped, the screen said F3, now the oven is locked. It smells like a hot wire
What does F3 mean on my Frigidaire stove when it sounds ...
www.shopyourway.com > Manage My Life > Questions
My Frigidaire range beeps and flashes F3. ... 790.92413202 and when I turn on bake or broil it just shows an F3 code on the screen what does this mean?
What does fault codes "F2" and "F3" mean on a Kenmore ...
I have a Kenmore wall oven model 911.41059591 that beeps and flashes F2 or F3 and shuts off. ... The "F2" and "F3" fault codes is most likely indicating an open oven ... Next, the control panel will need to be taken off in order to measure the ...
Oven error code "F2" and how to fix it ' AskGene.com
www.askgene.com/.../oven.../what-means-the-error-code-"f2"-on-your-o...
Mar 26, 2007 - The error code "F2" will be displayed along with a beeping sound if the
Jan 27, 2016 | Kitchen Ranges
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
Tip
F5 - E0 Door Switch
Two digit codes:
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
What dose F3 code mean
Amana Appliance Fault Codes - PartSelect
www.partselect.com/JustForFun/Amana-Appliance-Fault-Codes.aspx
Fault codes for Amana ovens, range, stoves including dual convection wall overs and 'big ovens'. ... F3-1 - Oven Temperature Sensor/Circuit Failure - Check wire connections and ... what does it mean when the oven turns off and f3 shows ... My Amanaagds902ww gas range flashes "Door" when attempting to light the oven.
Amana Gas oven Fault Code F3 - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges-cooktops/143114-amana-g...
Nov 17, 2010 - 2 posts - ‎1 author
Have a Fault Code F3 display on oven when trying to set oven ON. Researched ... Yes, your F3 code would indicate a sensor circuit problem, Jenn-Air Electric Range Code F3
Mar 15, 2011
Range keeps giving error codes E0/F3 and E4/F3 and the ...
Nov 22, 2010
Replaced Sensor Still Getting F3 Error
Sep 20, 2008
F3 Error code on whirlpool Range
Sep 10, 2007
More results from forum.appliancepartspros.com
Amana Fault Codes - Appliance Help O
Dec 25, 2015 | Amana Kitchen Ranges
Samsung dishwasher dms500trw. what does error code f3 mean. i just replaced the hose after e2 code now 2 weeks later i have f3 code?
Samsung DMS500TRW - ProductReview.com.au
www.productreview.com.au > ... > Dishwashers > Freestanding > Samsung
Rating: 2.4 - ‎49 votes
2.4 out of 5 stars for Samsung DMS500TRW in Freestanding Dishwashers (page 2). ... The machine gives an E2 error and will not pump water out. I have to manually cup it out. ... F3 Error. 1 out of 5, reviewed on Sep 30, 2013. Purchased dishwasher in Jan 2012. First broke ... F3 what dose this code mean? Dell asked on ...
Nov 26, 2015 | Dishwashers
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
KitchenAid KHMS155LSS when press "bake potato" button,start flashing error F3
Question: Error Code - Oven - F3 Error Code - F3 E0 Answer Product Symptom:
Error Code/Message - Oven - F3 Error Code - F3 E0
Control displaying F3 E0:
There may be a problem with the Oven Temperature Sensor, or the associated wiring.
Power unit down by turning off the circuit breaker(s) for one (1) minute.
Power unit up by turning on the circuit breaker(s).
Monitor the oven for one (1) minute to ensure the error code does not display again.
Verify oven operation.
Jul 31, 2014 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Whirlpool GR396LXGQ oven comes on by itself & goes into clean cycle, code reads E2 -F3-
Whirlpool F3 faults relate to temperature problems in the oven. In the case of the error E2-F3, F3 is the general fault code and E2 is the specific error code. An E0-F3 error indicates that the oven's temperature sensor is open; E1-F3, that the temperature sensor is shorted; E2-F3, that the oven temperature has exceeded the maximum rated 575 degrees Fahrenheit in "Cook" mode; and E3-F3, that the oven temperature has exceeded the maximum rated 950 degrees Fahrenheit in the clean mode. Here is the probe to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 07, 2012 | Whirlpool Ovens
Gives codes F-2 &F3 what is the problem jachin2145@comcast.net
Hi, Error Code F2
An F2 error code indicates a failed connection with the keypad. Ensure that the connection between the keypad and control board is tight, and press the "Cancel" key. Wait one minute to see if the error code returns. If it does, the keypad is defective and needs replacing.
Error Code F3
F3 error codes are triggered by problems with the oven temperature sensor. You cannot tell whether the sensor has shorted out or has simply failed to generate a reading if your Whirlpool range only displays two-digit codes. On a Whirlpool range with four-digit error codes, the F3-E0 code represents a failed temperature sensor and F3-E1 represents a short in the sensor. Regardless of which code is displayed, replacing the temperature sensor is the only way to correct the problem.
Hope that helps.
Thanks for using fixya...
Oct 27, 2010 | KitchenAid KESC300 Electric Kitchen Range
Ge microwave jvm 1430 error code F3
F3 Key panel (touch pad) shorted This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
Jul 17, 2009 | GE JVM1430 Microwave Oven
Kitchen Ranges Logo
227 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
