Question about Hannspree HANNS-G 19" Widescreen Monitor
No XP driver for Hannspree New york 19 inch monitor
I need a driver to enable me to adjust the resolution to remove the horizontal stretching of the display. The Hannspree website only supplies Vista drivers.
  • 3 more comments
  • davidharding Nov 17, 2008
    Michael = Thanks for response.
    I think that the video card may be the problem as the motherboard has an embeded 256 bit 3D AGP Graphics accelerator (the motherboard is made by PC DDR266, the literature says it is a M810DU Socket A) The4 PC was built by a local shop approx 4 years ago.
    Is the way round the problem a sparate graphics card?
    Thanks for your help.
    David Harding
    Michael
    Many thanks for your help.
    I am going tomorrow to get my computer upgraded by having a suitable graphics card installed. No doubt this will cure the monitor (and other) problems. Together with an increase in RAM I am sure it will result in the PC working much better.
    Thanks again for your help.
    David Harding
  • omtech1 Dec 01, 2008
    I bought the hannspree 22" model (HF229H) from Best Buy on Friday 11/28/08. Same problem, NO XP drivers included, only VISTA. I wrote to Hannspree support explaining that millions are avoiding Vista and WE XP USERS NEED the proper drivers. You can write them too at: webservice_us@hannspree.net John
  • Anonymous Feb 18, 2009
    I have my ps3 hooked up using hdmi cable to my hannspree 19' newyork lcd monitor.
    However, the picture is not exact on the monitors picture it is like the picture is zoomed. The bad thing is there are no option on the monitor to shirnk the size vertically nor horizontally. Can yo uhelp me with this problem?
  • Michael950 May 11, 2010
    Hi David Harding,
    What model of computer do you have as well as what type of video card (if you know)...It's very possible that your video card is not designed to do wide screen but will know when you give more details.
    Thanks,
    Michael
    Scholar:
  • 44 Answers
Hi David,
Thanks for the comment regarding what type of computer equipment that you have. The integrated video card that you are using definitely is not designed for the widescreen monitors and will not work properly with the widescreen (as you have noticed). The solutions that you can use would be to get a non-widescreen standard monitor or install a new video card that has widescreen capability.
Hope that helps,
Take care,
Michael
Posted on Nov 17, 2008
Stretched monitor? I have a 19 inch LG and it looks stretched. Please help.
Hello Rbeaudoin, Hi! the stretch thing is caused due to improper computer configuration, you need to load the VGA device driver for your PC. A properly setup device driver for your VGA will produce a resolution properly for your monitor.
explanation, you see, without the device driver, windows assumes several resolutions, most of the time, this does not match the monitor resolution, so the device driver when loaded, talks to your monitor, and identifies it, then sends the proper resolution info to the VGA and windows, so that windows can create an option for that resolution. using this proper resolution the monitor can display the video properly.
Mar 11, 2010 | LG Flatron L1750S 17" LCD Monitor
Hannspree 23 inch monitor - driver problems
In my experience, monitors do not need drivers. Video cards do. Make sure your video card drivers for your computer are up to date. The card is what makes the picture on the monitor.
Jun 21, 2009 | Hannspree 22" widescreen LCD Flat Panel HD...
NEW WIDESCREEN TOOOOOO WIDE
Use menu button on monitor.
select menu.
select image setting
select aspect ratio
change aspect ratio to "Fit"
Jun 21, 2009 | Hannspree HW191D LCD Monitor
Adjusting the horizontal & vertical to be proportionate
You need to set the correct resolution for your monitor,
To do this, minimize all windows, and right click on your desktop (not on an icon). Select properties, and go to Settings on the tabs on top.
Drag the slider until your resolution matches that of the monitor. I use mine on 1600 x 1050. However if your card doesn't go that high, try either the next ones down until it looks normal, or try a driver update for your graphics card.
Mar 05, 2009 | Hannspree Computers & Internet
Native Reolution?
first, check outlet, make it sure that power is on the appropriate voltage. then your UPS and voltage regulator also. try to check all button switch and your video card
Sep 29, 2008 | Computers & Internet
Hannspree 19" Widescreen resolution available
I have the same problem. i downloaded a generic driver that allows 1600 X 900 resolution. this is better..things are taller rather than wider (with the 1280X1024 resolution). i dont understand why there isnt a 1440X900 driver available for XP systems.
Jul 30, 2008 | Hannspree 19" Widescreen LCD Flat Panel...
2 problems: 1. Is there a way to make the images on my 19 inch acer lcd monitor not appear stretched? 2. How do I get a screen resolution of 1440 x 900 (It's not one of the options in my display...
1. The only way to avoid stretching of images is by increasing the resolution. Many 19-inch monitors with conventional (4:3) aspect ratios have 1600 x 1200 pixel resolution. The 1600 x 1200 resolution is ideal for graphic artists and those who work with photos, since it's close to the resolution of a 2-megapixel digital photo.
2. You can double check by going to the display properties - Settings- Advanced tab below the screen resolution slider, choosing the Adapter tab, click List all modes and that will settle it once and for all. If 1440 x 990 isn't listed you're likely going to have to buy a graphics card that can reproduce that resolution.
Also try and update the driver for your graphics card.
Jul 06, 2008 | Acer Computers & Internet
My new 19 inch 1952 LG monitor stretched my display picture from what I use to have on my 17 inch. How do I adjust the height to width ratio for a picture that isn't distorted?
Right-click your desktop, click properties
go to 'settings' and select the 19 inch monitor
now change the resolution to the format you want to use.
Set it to something like 1600x1200, or 1024x768
Apr 04, 2008 | Computers & Internet
Hannspree HANNS-G 19" Widescreen Monitor Logo
1,183 people viewed this question
Top Hannspree Computers & Internet Experts
richie46
 Chuck N
Chuck N
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
