Question about Refrigerators
Conquest refrigerator/freezer not working
I woke up to water all over my kitchen floor. Noticed water running down the freezer door.Opened the door to find that the ice was melting and everything in it was defrosting. Opened the refrigerator to find that it was not cold. Lights and fan is working. I can hear a clicking noise like something wants to turn on, but after a few seconds, it clicks off again. My husband says that it probably needs free-on. We purchased this back in 2002 and it is no longer under warrantee. My last refrigerator lasted at least 20 years before anything going wrong with it.
  • Refrigerators Master
  • 3,197 Answers
FREON would be a WORST CASE scenario...
Not actually likely mfgomes... Hello,
If it were FREON the refrigerator would be trying to run...
just not getting anywhere...
My 1994 Amana needed a control board after
about 20 years... It is counter depth, stainless
with all the bells & whistles...
I Fixed it and I am DELIGHTED...!!
Expecting another 20...
Take a look at your control board... WATCH the VIDEO..
check the price...
I think you will like what you see.
(there are many part houses... This is just my favorite
SEARS... was my least... but they got a little better))...
also see partselect & repairclinic
(avoid 1stservall... like I still avoid SEARS (shame on me)).
GE WR55X10942 Main Control Board AppliancePartsPros com
Carnac the Magnificent
Posted on Apr 30, 2017
    Top Expert:
  • 44,040 Answers
Purchased in 2002? Dump it. Not worth repairing.
  • 116 Answers
SOURCE: Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Posted on Mar 11, 2007
SOURCE: Amana AFD2535DEW freezer/refrigerator with intermittent tempurature swings
I had the same issue. It was the relay overload which essentially provides the extra boost to get the compressor going. The switch tries for about 10 seconds before giving up and then retries 3 - 4 minutes later. In the early stages of failure, eventually it will work and the compressor will kick on. But eventually the switch will fail and will just cycle through the 10 second attempt every 3 to 4 minutes. The part is about $35 - part number 67005560.
Posted on Jul 10, 2008
docjohn174
  • 943 Answers
SOURCE: freezer floor has ice and spills out on defrost cycle
HI thanks for your question. yes that drainage hole must be cleared. unplug fridge for at least 24 hrs, pull fridge from the wall. remove back plate. clean all coils. locate the drain tube by the drain tray. put a small hose up the drain tube and blow to clear the debris. thanks the appliance doc. please rate my answer. thanks
Posted on Oct 14, 2008
localwonder
  • 6784 Answers
SOURCE: Kitchen flooded from whole freezer thawing out overnight..
hi, this is a control panel board failure. this will unfortunately have to be repaired by the whirlpool tech. the main sign for control panel failure is the uneven temperature that you are experiencing in the refrigerator.the control panel has lost its ability to maintain proper temperature. i would take a look at the thermostat as well. it may need to be replacing.
Posted on Mar 06, 2009
  • 72 Answers
SOURCE: Our freezer is not cold, food is defrosting, ice
Look at the back of the freezer wall from inside the freezer. Is there frost on it? If there is, you need to replace one of the components of the defrost system. If there is no frost then you need to have a repair made to the sealed system, it is either out of gas or the compressor is running inefficiently
Posted on Jun 20, 2009
Defrosting issue or need to replace refrigerator?
If your refrigerator was manufactured in 1999, it is way overdue for replacement.
Apr 05, 2017 | Magic Chef CTF2125 Top Freezer...
I have a Jenn-Air refrigerator, Model JCD2389DE, and in the last two weeks we have noticed water puddling on the floor in front of the "freezer side" door. We thought maybe the water dispenser...
Mine did this a few years ago. I had to call service out to replace the system board. I guess it's a common problem. Something on the board fails and the defrost operation does not work properly, resulting in rapid meltdown of ice build-up and puddles on the floor.
Nov 14, 2010 | Jenn-Air Refrigerators
Kenmore side by side. Noticed water dripping out
please do not use hot water.........only clean drain hole with copper wire with very small cloth on
end.sounds like you left door open? adjust feet to allow door to close itself..if left ajar.
fully defrost.clean drain hole.adjust feet. switch on ...
this freezer works best full....
Feb 04, 2010 | Refrigerators
I have a GE side by side.. When we got home last night I noticed some water on the the floor and the power was on inside the refrigerator but the cooling apparently stopped working. I moved the fridge and...
The defrost timer will turn off the compressor and its cooling fan. At the same time it turns on the defrost heater, and usually leaves the freezer fan running. Defrost can take half an hour, easy. As soon as the defrost thermostat is satisfied, the defrost heater is supposed to turn off, and the compressor may come back on. The defrost timer is about the size of a cell phone, with about five wires going to it in a plug. It has a small dial on it that only goes one way. You can mark it and wait a half hour to see if it moves.
Apr 14, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Bottom freezer door dripping water on kitchen floor
you can take a ook into the freezer sect its possible that the line has frozen, nad no longer is defrost water going into the drain but rather falling on to the floor of freezer and evnetually out the door
Jan 11, 2009 | Freezers
Running continuously
Hello bxrjer,
Welcome,
You said, you have a FFU20FC6AW2 freezer that I have noticed is running continuously. Explains my $400 electric bill.
How old is the freezer?
The thermostat may be faulty.
But check out this list first.
If the black tubes running back and forth that carry the freon is under the freezer and behind the plastic grill down near the floor you may want to remove the grill cover and gently run a refrigerator brush across the coils. Ive seen them never cleaned and full of lint and dust 2 inches thick.
This is not good for the freezer or any refrigerator too!
They need to be clean so air can run across them or they over heat and get hot.
Room or outside weather is hot. It is normal for the freezer to work harder under these
conditions.
Reasons why Freezer may run too much or too long.
1.Freezer had recently been disconnected for a period of time. Freezer requires 4 hours to cool
down completely.
2.Large amounts of warm or hot food have been stored recently. Warm food will cause the
freezer to run more until the desired temperature is reached.
3.Door is kept open too long or too frequently. Warm air enters the freezer every time the door
is opened. Open the door less often.
4.Freezer door may be slightly open. (Freezer is not level. It rocks on the floor when it is moved slightly. This condition can force the cabinet out of square and misaligned the door.Freezer needs to be leveled if this occurs.
Floor is uneven or weak. Freezer rocks on the floor when it is moved slightly. Level the floor by using metal or wood shims under the freezer or brace floor supporting the freezer.
5.Temperature control is set too cold. Turn the control knob to a warmer setting. Allow several
hours for the temperature to stabilize.
6.Freezer gasket is dirty, worn, cracked, or poorly fitted. Clean or change gasket. Leaks in the
door seal will cause freezer to run longer in order to maintain desired temperature.
Let me know what you find
Huuum
Please remember to leave a rating before you leave.
Aug 18, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Water leaking onto floor
unplug it again , sounds like your drain line has frozen, instaead of defrost water going down the tube and under refrig in drain pan, becuse tube is frozen its draining into freezer compartment and eventually spilling out through front of unit. totally defrost unit and behind back wall of freezer youll see a metal trough designed to catch water, in the center (under the ice is gonna be the drain hole, pour boiling water down until it runs freely
Feb 23, 2008 | Kenmore 71279 Bottom Freezer Refrigerator
Angels, sounds like your defrost drain is frozen over. When the refrigerator is going into defrost it's draining through the front instead of the drain pan. You can remove the shelves and peel off the back cover and clear the drain by pouring hot water on the frozen drain hole. If you have a baster of some sort you could try to squirt the hot water through the venting on the bottom of the panel. Another way to to point a hair dryer on the drain hole. The best method is to remove the shelves and panel and make sure the drain is clear. Catriver..post back.
Dec 22, 2006 | Maytag MZD2766GES Side by Side...
Refrigerators Logo
70 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
