Question about GE 106591 Coffee Maker
Coffee maker clicks but does not brew
Ge model 169164
  • 15 more comments
  • nocoffee4me Dec 27, 2008
    We just got it for Christmas. It worked one time and now will not work. We can hear it clicking but it will not brew.
  • elKabongXXI Dec 28, 2008
    Uh-huh. I ran water through once with no coffee just to 'clean' it out. Now I have the same problem. I unplugged it last night, thinking I'd have better luck this morning. Still nothing. Just clicking on/off. I get 2 beeps after turning the brew button on as if it has finished brewing.
    I wonder if it's stuck in the cleaning cycle? I did actually push the 'clean' button last night in a desperate attempt to find something that would work. But... why isn't the water going through?
    I just read in the manual, under the auto cleaning function, this note:
    "The cleaning process takes 60 minutes to complete. You cannot cancel the cleaning process before it is complete. Unplugging the machine only delays the cleaning process."
    Great. What sadistic a**holes wrote THAT into the program? They probably drink caffeine-free herbal tea or something like that. I don't have an hour to wait for this. Looks like there's no coffee for me either this morning. Grrrrr... :(
  • Anonymous Jan 04, 2009
    I am having the same problem. You would think a company like GE would post some "Fix its" themselves. Time to buy from another company.
  • Anonymous Jan 17, 2009
    I have the same problem. It just happened to me yesterday. And now it's stuck on the cleaning function. Ugh. AND I think I actually have a different model then the ones you're talking about.
  • studydude Jan 23, 2009
    Yeah, mine quite also with clicking. I think maybe the calcium built up in the piping? I just got laid off from my job and cannot afford another coffee maker.
  • Anonymous Jan 28, 2009
    Same as the rest of you.I pulled the bottom off of it after figuring out how to get the tamper-proof screws out....I found a broken wire going to part of the warming surface.I repaired it the best I could and it seems to be working now.I'm not sure how much I trust my repair,so I will leave it unplugged when not in use-don't want to risk a fire.
  • tinamg682 Feb 07, 2009
    I have the same problem! I cleaned my machine yesterday. Followed the manual's instructions to a T and now the stupid thing won't get off the "clean" mode. ARGH!!! It's only 3 months old too.
  • lmno2802 Feb 22, 2009
    Power went off & now my coffee pot wont brew. Simply clicks but never brews. Does any one know of a reset button or anything?
  • Anonymous Feb 23, 2009
    my coffee pot turns on but it wontmake coffee
  • free1_06 Mar 09, 2009
    I am having the same problem, I bought the pot yesterday and made one pot of coffee without problem this morning. When trying to make a second pot the coffee maker wouldnt do it, it sounds like it is beginning a brew cycle then beeps twice (signaling end of brew cycle) then stops without brewing any coffee at all.
  • Scoobs694u Mar 10, 2009
    Same prob as the rest of you..might try taking the bottom off and repairing it myself. It's worth a try I guess. Will let you know what I find out..if I find anything out lol
  • pattersonst Apr 03, 2009
    Product keeps saying clean....won't brew or anything...left in clean cycle for 8 hours yesterday and nothing happened......will take back to store and request another brand. It seems that these are not very good coffeemakers because I notice alot of the same type problems being reported.
  • Anonymous Apr 13, 2009
    click on the power to brew and nothing.... I came home from work after letting vinegar sit in it and still nothing. Clean light comes on and I can't find the manual...was hoping to find some answers on line.
  • Anonymous Apr 19, 2009
    Brewed half a pot, then stopped. Will not brew anymore. On/off button makes a 'click' and that is all.
    Nice screws they use - need a special screwdriver.
    Same "clicking" problem here. The first one worked for a couple of months until the problem began. We got a second one, and it worked for a day before the problem began again. I made the same mistake of starting the cleaning process. Now, the cleaning cycle will not stop.
  • Anonymous Apr 21, 2009
    I have the same problem - click but no brew. The cause is a failed Microtemp fuse for the heater, though I can't find the part number or specs on the fuse.
  • Anonymous Mar 27, 2014
    What does tsb stand for on ge coffee pot model# 169164
  • 34 Answers
This information is for the GE model number 169164 12 cup digital coffee maker.
The Micro fuse is shorted open. There are two underneath the housing. They are made by MICROTEMP® and are the G400 series rated at 216 Degrees Centigrade.
You can check these with a Ohm meter to see if you have continuity. Checking across the leads of each one they should show infinity. If not you've identified the bad one. You can pick up a new thermal fuse at Radio Shack. The closest one to the specs of the Microtemp is a Radio Shack part number 270-1321 rated at 228 Degrees Centigrade. Before removing the old one notice which way the hat end faces.
Use a heat sink when soldering the new thermal fuse in place by using alligator clips or a pair of pliers.Reassemble and your back in business as a Barista.
Note: There are four Phillips head screws under the rubber pads. The three unusual screw heads may be removed/installed with a small screwdriver installed in just one of the slots.
Posted on Apr 22, 2009
  • King Jul 07, 2012
    They shouldn't show infinity, infinity means an open (incomplete) circuit, its open as the blown fuse has broken it. Electricity needs a closed circuit to flow, a good fuse will show as 0, or maybe a very small amount, if your multimeter is accurate enough to show the resistance of its own cables had it not been calibrated prior to use.
    The fuse that reads infinity (0.L) is the bad one. The resistance to the electrical flow is infinite because the fuse has blown and broken the circuit just like it was designed to.
    Thermal fuses are not polarised, meaning it doesn't matter which way round you fit it.
    Other than that your post contained great info for the less initiated machine owners :)
  • King Jul 07, 2012
  • 4 Answers
Your coffee maker might be defected try calling GE to solve the problem or return it to walmart.
Posted on Mar 09, 2009
3 Suggested Answers
SOURCE: new charcoal filter for GE COFFEEE-MAKER MODEL NUMBER 169164
Call your local Wal Mart Stores..... even if you have to call 2 or 3 stores..... after several attempts to call the customer support phone number (what a joke) I did not want to waste my time on hold.
I decided to call all of the local Wal Mart Stores in my ares.and I found the filters for the 12 cup digital coffee maker model number 169164.......... (they come in a pack of 2) at the Wal Mart store in West York PA.....
I may end up purchasing 2 packs.........
I hope this email with help you with your search.............Good luck. They are out there, it just takes alittle searching and with no thanks to our wonderful GE help line.
Barb
Posted on Feb 07, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: past 2 mornings, coffee maker only brewed 10 out of 12 cups.
It's probably time for a good cleaning. Follow the procedure in the manual, or get some commercially available coffee maker cleaner. When the minerals build up enough, the water flow and heating is reduced enough to keep it all from passing through.
Please take a moment to rate this solution if it's what you needed, and thanks for asking here!
Posted on Feb 24, 2009
Broke glass carraffe, need to replace model 169164
I replaced my broken carafe on model: 169164 by purchasing a RIVAL 12 cup coffee maker PIL-HC08104 from WalMart for $10.24 and simply put my black handles on the new pot whaic had white handles. The pot appear to be exactly the same.
Nov 01, 2009 | GE 106591 Coffee Maker
Need a carafe for a general electric coffee maker model #169164
Walmart sells replacement coffee pot. You can buy online and have shipped to you.
Jun 17, 2009 | GE 106591 Coffee Maker
GE Model 169164 stops brewing
A couple of people on here mentioned he filtration system, or charcoal filter that is in the
water resovoir as being problematic. We removed it. This morning the pot brewed entirely.
Not sure how that all is inter-connected, but it worked.
Feb 04, 2009 | GE 106591 Coffee Maker
Past 2 mornings, coffee maker only brewed 10 out of 12 cups.
Jan 27, 2009 | GE 106591 Coffee Maker
Looking for a Carafe replacement for my GE coffee maker
I've replaced my coffee pot from my local Ace Hardware!
I'd call first!
Good Luck!
Jan 18, 2009 | Coffee Makers & Espresso Machines
GE 169164 Coffee Pot Not Brewing
Loosen the charcoal filter. You only need to GENTLY place it in. Your problems will all be solved. I just did it 5 minutes ago and i just brewed a 6 cup pot of coffee completely.
Jan 07, 2009 | GE 106591 Coffee Maker
GE Model 169164 Paper Filter Size?
# 4 coffee filters made by militta. I have the same maker and i hate all the coffee grinds in the pot
Oct 20, 2008 | GE 106591 Coffee Maker
GE Cofee MAker Model: 169164
Most failures of coffee makers are related to thermal fuses which have opened and interrupted the current flow to the heating element.
Often, they failed for no particular reason but replacing the fuses would probably cost as much as tossing the whole machine.
Yeah, I know, I don't like it either.
Before retirement, I earned my living fixing stuff we can now buy cheaper new.
May 21, 2008 | GE 106591 Coffee Maker
GE 106591 Coffee Maker Logo
1,795 people viewed this question
Top GE Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Eric Taylor
Marvin
Marvin
Are you a GE Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
