Cant find driver \lxdvcFg.xml for my newly installed 5400 printer
  • 3 more comments
  • ttg300 Dec 07, 2008
    When installing the driver from the instalation disc of Lexmark x5495 printer the computer requests a lxdvcfg.xml file which a cannot find.can You help me please?
  • lakesslate Dec 07, 2008
    what
    what is
    What is the solution Wherre is the answer
  • Anonymous Feb 21, 2009
    what's this nonsense, where is the answer, I said I have the same problem. who has the download, it's that simple
Cant find a driver lxdccnf.xml for this printer
Posted on Dec 07, 2008
Need to install DeskJet 5400 printer and do not have disk
You can download drivers directly from HP.com. Here's the link to their support page: http://www8.hp.com/us/en/support-drivers.html. The only issue I see is that I think the Deskjet 5400 is a series and not a specific printer, so you'll need the exact model number for your printer. You should be able to find it on or near the serial number, which should be on a tag somewhere on the printer. Search for that model number on the linked page above and it should get you to the driver you need.
Jun 20, 2011 | HP Deskjet 5400 Series
Install Lexmark 5400 Printer-Lost my installation CD
Hey,
The Drivers and software are available at www.lexmark.com
Click drivers and software then driver finder.
Aug 30, 2008 | Office Equipment & Supplies
Cannot install driver for HP laser jet P2015
It may be you have a problem in the printer formatter.........
Mar 24, 2010 | HP LaserJet P2015dn Printer
Brother HL 2140 printer very slow printing.
It sounds like you haven't completely removed the old print driver. To do so, you must take the following steps:
  1. Open Printers by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Hardware and Sound, and then clicking Printers.
  2. Right-click the printer that you want to remove, and then click Delete.
    If you can't delete the printer, right-click it again, click Run as administrator, and then click Delete. 18abb370-ac1e-4b6b-b663-e028a75bf05b.png If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
Another way or removing the printer driver is this:
1. Delete the printer from control panel -> printers
2. Open Services.msc and stop and start the Print Spooler service
3. Open Print Management(Open command prompt, type in printmanagement.msc or type print management in to the start menu search box)
4. In Custom Filters -> All Drivers right click the printer driver you want to remove and select Remove Driver Package
5. Install new printer driver.
Now that you've removed the printer driver, you can go ahead and manually install the new printer driver.
To manually install you must follow the prompts carefully.
Follow the instructions in this link:
http://www.vista4beginners.com/How-to-install-local-printer
At the install the printer driver section, choose have disk and locate the printer driver that you want to be associated with this printer you are installing.
This should solve your problem.
Mar 24, 2010 | Brother HL 2140 Laser Printer
I cant find hpc20155.xml
This is direct from the HP website. some files were renamed... it works!
ISSUE: During the LaserJet P2015 Series USB installation, the following error message is displayed: 'hpc20155.xml' on HP LaserJet P2015 Series CD is needed SOLUTION: The HP LaserJet P2015 EWS driver on Microsoft Windows Update and Windows Market Place Web sites is newer than the driver that is included on the product CD that shipped with the printer. Because of this. the Microsoft Windows (Found New Hardware Wizard) will install the driver from the web. Some file names are inconsistent between driver version 1.0.0.12 and version 1.0.0.10, including the hpc20155.xml file, hence the attempt for the driver to search for the hpc20155.xml file will fail, and prompts the error message. To resolve this issue perform the following:
  1. Click the Browse button on the error message.
  2. Browse through the CD to Drivers -> windows 2000_XP .
  3. Select the file hppcp504.cab , and click OK .
  4. The error message "The Software that you are trying to install has not passed the windows Logo Test " appears. Click Continue Anyway .
  5. If the error message "hpc20155.xml on HP LaserJet P2015 Series CD is needed " appears again, follow steps 1-3.
  6. The required files are copied, and the driver is installed and ready to use.
If the issue still persists then perform the following in the order listed before trying to reinstall the software.
  1. Go to Start -> Control Panel -> System -> Hardware -> Windows Update.
  2. Set the option to Never search Windows Update for drivers .
NOTE: It is important to re-enable the Windows Update function after installing the printer software, otherwise the updates for all the other software on this computer will be blocked. After disabling Windows Update, complete the following steps. Be sure to reenable Windows update after installing the software:
  1. Disconnect the USB cable and remove the device listing from Device Manager
  2. Go to Start ->All programs ->HP ->P2015 ->Uninstall , "OR" Go to Add & Remove and check for the P2015 and uninstall .
  3. Then go to Printer & Faxes . Select the HP LJ P2015 icon and press the Delete button on the keyboard. After deleting the printer icon, go to File and Server properties . Go to Drivers tab and remove any P2015 drivers if listed.
  4. Also delete the following files/ folders C:\program files\HP\toolbox Fx or P2015 C:\documents & settings\app data\tool box Fx
  5. Run the scrubber.exe . Find this on the cd X:\utils\ccc\scrubber.exe & scrubber.ini NOTE: The Scrubber utility can also be downloaded from the web if the original installation CD is not available. However, it is only available as part of the full software installation package named hp_LJ_P2015_Full_Solution_AMWE.exe on hp.com . Once the files are extracted to a folder just open the util folder then the ccc folder and the scrubber.exe file will be visible.
  6. Paste these files at the following path and run the scrubber.exe C:\windows\system32\
  7. Empty the recycle bin
  8. Turn the printer back on.
  9. Now install the printer software again. Connect the communication cable to the PC and printer when prompted during the installation.
Sep 07, 2009 | Office Equipment & Supplies
Zebradesigner for xml ''error in processing zpf and lvr files''
Somehow, the correct printer driver is not installed when setting up Zebra Designer for XML.
To fix it, clck on "Start->All Programs->Zebra Designer for XML->Add Printer".
A wizard opens, select "Next" and choose the printer you are designing labels for. Click on "Next".
Select "Update existing printer driver(s)". The driver gets updated and voilá!, now you can export your label desgins.
Mar 19, 2009 | Zebra Z4M Printer
PRINTER DRIVER SOFTWARE
Good Day,
Drivers for WinXP/Win2000 can be found at the following link, just click the orange button to download:
http://drivers.softpedia.com/get/PRINTER/HP/HP-Deskjet-5400-Series.shtml
Should you require a driver for a diffrent operating system let me know.
Hope this helps
Jul 06, 2008 | HP Office Equipment & Supplies
Driver installation problem for HP 5400 DTN
Sorry
This printer is not supported by Windows98
So HP is also not provideding Windows98 drivers
Just try to work out with Drivers for Win2000
Jun 02, 2008 | Office Equipment & Supplies
109 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
