Question about NetGear : WG111 54 Mbps Wireless USB 2.0 Adapter, RETAIL (DSNGWG111)
Re: No internet on Wireless home network
Thanks for suggestions, Nick, and thanks for inviting follow-up. Tried all your suggestions, but so far no luck. The problem machine can see files on other networked computers and vice versa, but still no internet. The machine also shows up as an attached device when I access the hub (using the web interface). Any other ideas?
  • 1 more comment
  • namesink Nov 17, 2008
    Thanks for further diagnostics. I can ping the White House. Win Firewalls off on both sides, and I also tried it with disabling my Norton Security firewall. DNS server set to obtain address automatically. All this makes me think the problem may lie with how the Network router is configured, but I can't see what's wrong there either.
    Router is a Netgear Ruckus WPN824 v2
  • namesink Nov 18, 2008
    Thanks, but still no luck. Plus, I've had a couple of flaky things happen that may either help identify the problem or make it more intractable.
    1) Just had a message flash on the problem machine that said something about conflicting IP addresses on the network. That may be because I've been trying to tweak addresses in the Internet settings, although when something doesn't work, I've been undoing it.
    2) I've had to re-boot and re-enter the WEP key on the machine to keep the connection up.
    Any more ideas, or should I pay for service. Either way I very much appreciate the help.
    Novelist:
  • 93 Answers
On the machine in question, let's try reaching an external IP address. Go to:
Start > Run > and type CMD (you will get a command prompt)
Then type "ping www.whitehouse.gov" (or a website of your liking - doesn't matter, really). You should get a response back, if you are communicating outside of your LAN. If not, the ping will respond with "no response".
You say you tried all the suggestions, but didn't mention firewalls. What are you running as a firewall? If it isn't the Win Firewall, do you have the Win Firewall disabled?
Also, let's look at this:
Network Connections > right click on Local Area Connection > Properties
highlight Internet Protocol (TCP/IP) > then Properties
Make sure it is set to "Obtain an IP address automatically" and
"Obtain DNS server address automatically".
If they aren't set that way, then do so.
Again, let me know how it goes. The more info I have, and the more possibilities we eliminate (unless one actually fixes it), the closer we are to finding the culprit.
Cheers
Nick
Posted on Nov 16, 2008
  • Nick Nicholson
    Nick Nicholson Nov 17, 2008
    We are getting closer, at least. You are connected to the internet on the system in question. The problem is, traffic is being blocked on a specific port - port 80, which is the html (ie, web) port. BTW, "ping" ignores port blocking, which is why it went through.
    Two ways your port 80 traffic can be blocked:
    1) In the router, or
    2) In your security software (Norton, etc)
    Tell me what sort of router you have, and I can give you specific instructions on what you need to check.
  • Nick Nicholson
    Okay....
    Go into the web configuration utility for your WPN824 router. Go to the menu item (listed on the left) where it says Block Services. Make sure you are NOT blocking HTTP (since that is essentially what is happening). It can be set for every IP (which is not the case here), or a specific IP.
    If this doesn't work, one other thing in the router to try is putting the machine in question in what is called the DMZ. There, you specify the address of one machine that will be outside the firewall and other protections of the router. Also, it wouldn't hurt to disable SPI in the router completely, if you are running a separate software firewall. DMZ setting should be located under WAN settings. A system in the DMZ has completely unfettered access in and out, and if that doesn't do the trick, then you will know it is not the router with the problem. Still, before going that route, I would try the Block Services and Port Filtering options first.
    Cheers
    Nick
How do i connect my luxor tv to the internet wireless
As far as I know there is only one Luxor TV model that has Internet access (Smart TV) and it comes with a wireless adapter/dongle. Plug the dongle in the USB port of the TV set and follow the instructions in the user guide on how to set up a network connection. Usually, from your remote, go to Menu, Settings and then to Set Up Network Connection. Please be aware that you need to have a wireless modem/router for your home network in order to be able to connect your TV to the internet.
Hope this helps.
Nov 19, 2014 | Computers & Internet
I have an Acer 7741G-3449.. I am having problem activating it's wireless connection.. I tried going to internet connections and tried to set up a wireless connection but for some reason the wireless...
First Check to see if the wireless card driver is installed working and enabled.
Next Check your router's wireless settings ie the SSID, WPA or WPA2 encryption setting, these setting need to be applied to the wireless card on the Acer so it can communicate with your wireless router.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jun 18, 2011 | Acer Computers & Internet
Need a pc card for wireless internet connect.Have tried netgear does not work in computer. any suggestion. model of computer 570e imb thinkpad. old computer work great but need internet connection. thanks
You can order pretty much any PCMCIA Wireless network adapter. If the machine is older, you may want to try the "802.11g" or "802.11n" wireless notebook network card.
Try Belkin F5D7010, it uses the "g" signal band.
Apr 28, 2010 | IBM ThinkPad 570E Notebook
Missing drivers after reinstall
Yes :c)
Go here and select the type of notebook you have, whether it's an intel processor or an AMD processor. Follow the links to download your audio, network video, and wireless adapters as well as the motherboard drivers. Run each download and it will tell you step by step on how to install the manual ones and most of them will install automatically.
Thanks and please take a moment to rate as fixya.
Nov 08, 2008 | Compaq Presario R3000 Notebook
HTC will not connect to wireless at home
Hello Devin, give me a chance too! may be my technician help you to fix this issue. Dial our company customer care number +1 (844) 355-5111 (toll-free). We surely help you!
Thanks
John
May 08, 2017 | HTC Touch P3450 Smartphone
I am having problems with my wireless connection. When I try to connect to a wireless connection such as an airport, coffee shop, etc. I get a connection to the network but am unable to connect to the...
tht is becasue u odnt have heir WEP or WAP password if it has a password then ur adapter will seem to connect to it but wont give u internet access to the router which means no intenet
Sep 25, 2008 | Computers & Internet
Setting up wireless internet connection , my new acer laptop
hi there i have a problem connecting my new acer laptop to the internet..I've tried your suggestion but i can't still connect to the internet..can u help me to connect my new laptop to the internet? is there a program or a disk for me to open the internet connection of my laptop...thanks a lot and i hope u will help me
Jul 11, 2008 | Acer Aspire 5610-4648 Notebook
Wireless help
Hi Hilton
Have you:
               enabled security on your router? If so, the card should be configured the same. Sometimes disabling the Windows firewall helps, but do enable it again after finding out if that's the prob.
               entered the correct username and password?
               tried using  the ethernet cable to try to access your Local Area Network, remembering to enable your nic card?
                tried disabling, then enabling the wireless card? Sometimes that helps.
  Hope the above helps
  Noel Gordon
Oct 24, 2007 | NetGear : WG111 54 Mbps Wireless USB 2.0...
NetGear : WG111 54 Mbps Wireless USB 2.0 Adapter, RETAIL (DSNGWG111) Logo
104 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
