Question about Epson Stylus CX9400 Photo Printer
Printer is Not using all the colors when printing?
I have new ink cartridges in the printer. When it prints the red, yellow and black are the only colors that print and there are about 1/8 inch thick lines about an inch apart  across the whole page from top to bottom of the color area.
How do I fix this?
  • Epson Master
  • 541 Answers
If you download the ssc you can do a power clean if you dont have this tool let me no
Posted on Nov 17, 2008
Why won't a new tri-color cartridge print red?
Tri color cartridge contains Cyan,Magenta & Yellow color inks, mono cartridge contain black ink, combination/mixing with these inks desired color out put will prints on paper.. If any one or more inks are missing/dried, result mis matched print outs on paper.
In your case I feel it's Magenta ink is not firing..,nozzles may clogged, try to clean the nozzles with solvents & try it...If no result ,. replace the color cartridge..
Mar 28, 2015 | HP PSC 1315 All-In-One InkJet Printer
Black and white prints are not black
Sorry, steve, that you are experiencing this problem.
According to canon.com's website regarding the i9900 InkJet Photo Printer:
Why color ink may be used when printing in black and white Even when printing in black and white, color ink is used for the following reasons:
  1. Automatic cleaning of the print head.
    To prevent the print head nozzles from clogging, the print head is automatically cleaned periodically. At that time, a small amount of each color ink is consumed.
    Therefore, although printing in black and white is performed, color ink is also consumed.
  2. Color inks may be used to create black.
    When printing in grayscale or on photo paper or when duplex printing, although printing appears in black and white, the color black may be created using the three (cyan, magenta, and yellow) color inks. Printers without a pigment black tank / cartridge will print black / grayscale will create a composite black using color ink even on plain paper.
    Therefore, although printing in black and white is performed, color ink may be consumed.
  3. In order to keep the heavy black ink from smearing on the page or in the printer, color ink is used when duplex printing to help create black text.
I might suggest taking out the color ink cartridges leaving only black there, but some printers don't take kindly to this. So, you may have to further experiment with magenta, cyan, and yellow to make it at least seem b&w to your best eye's judgment.
Good luck on this.
Jul 13, 2010 | Canon i9900 InkJet Photo Printer
My mfc-240c won't print red, even with a new cartdrige.
Try running a few cleanings on the color.
Press the ink button and select cleaning,, do about five cleanings. Print the ink quality test page (from the ink button as well) and see the quality if it improved.
If it still doesnt print its possible the ink is clogged and may need servicing to replace the printer head
Apr 06, 2010 | Brother MFC 240C All-In-One InkJet Printer
Only prints in green and blue
You are more than likely out of magenta (red) ink. That printer uses a tri-color cartridge, and it has cyan (blue) magenta (red) and yellow ink. Green is blue + yellow-therefore you do have those two colors; since it will not print anything red or black you will need to replace both cartridges.
Mar 05, 2010 | Dell 810 All-In-One InkJet Printer
QUESTION FOR DON_FARR
whenever you print greyscale what actually happen is that the printer mixes the red, blue and yellow to give the output in gray scale. See if you mix red, blue and yellow ink in the right proportion it gives you very close to black. just try to print your greyscale with your black ink finished you will still get the same print quality as when the black has ink in it. Or find a way seal the nuzzle of the black in and print your greyscale. check what results.
Dec 12, 2009 | Canon PIXMA MP610 InkJet Printer
Windows Ink Cartridge Empty false error message.
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Oct 28, 2009 | HP C6280 All-in-One Printer
The color red will not print on My Dell A940 printer.
Try find another printer(same model- says printer B)...take printer head from printer B to your printer(says printer A),use your ink cartridge and test your printing....if all color seen on paper, then the problem is your printer head, to make sure is it true or not, use printer head from printer A into printer B.see the result...
May 26, 2009 | Dell A940 All-In-One InkJet Printer
I have a used C60. I have replaced both ink cartridges with Epson cartridges. When printing in color, the colors are not accurate. For example, red comes out yellow. Also, there are lines running through...
Hi there. The reason for your problem is that the colour cartridge contains cyan, magenta and yellow ink, plus a black cartridge of course. All the other myriad colours are produced by mixing these four basic colours. So, if you print red, it requires ink from both the magenta and yellow cartridges. Thus if your red produces a yellow print, it means your magenta is not printing. This can be due to a number of reasons, mainly an empty or faulty magenta cartridge or blocked magenta print nozzles.
If you wish me to help you with sorting out the lack of magenta, please post a new comment to this effect.
Mar 04, 2009 | Epson Stylus C60 InkJet Printer
New tri color ink cartridge will not print red
Probably bad, there's actually no way to check ink levels.
Jan 22, 2009 | HP DeskJet 960c InkJet Printer
F380
You are using HP's cartridge with the smallest output . So if you are printing 80 pages of text, you will have a problem by the time you reach 95 or 100 pages. If you are printing in color, you only have 1ml/color. Meaning 3 colors. But in order to print a red, it will combine a magenta and yellow to product 1 color. So 3 colors doesn't mean 3 ml worth of colors. Effectively you may only be able to print 10-20 pages of color then your cartridge is empty. The black cartridge has about 4-5ml of ink. So if you print a lot I suggest you get another printer.
Mar 30, 2008 | HP DeskJet F380 All-In-One Printer
Epson Stylus CX9400 Photo Printer Logo
134 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
