Question about HP Computers & Internet
HP pavilion a647c, trying to connect samsung sc-dc173U to usb port to copy video. Does not recognize the camcorder
  • HP Master
  • 4,806 Answers
Try to connect it to another computer to rule out other possible problems like the usb lead for example, if you no other pc to connect it to, try another usb lead if you have one, this will maybe help you to get to the bottom of it
Posted on Nov 16, 2008
  • HP Master
  • 1,879 Answers
On Windows:
Open Device Manager by right-clicking on the My Computer icon then click Properties. Then click the Hardware tab and click the Device Manager button. Locate the camera by expand Imaging Devices and/or USB Controllers section.
On Mac:
Click the Apple icon then About This Mac and click More Info button. Scroll down to the USB section.
  • monk3ybidzness
    monk3ybidzness Nov 16, 2008
    Ooops! HP Desktop - I missed that.
    If the device shows up, usually the icon will have a Big Red X OR a Yellow Exclamation Point on it, a Device Driver is needed. An installation CD is included when you purchased the camera .
    If it doesn't, change the USB cable and try other USB ports.
    Scholar:
  • 181 Answers
Have u loaded the drivers of the device in your pc to recognize it.
  • fixyy Nov 16, 2008
    http://www.manualnguide.com/dl/1830/
    check out this link for the manual of the device for step by step instructions on what to do if the device is not recognized.
    click the link directly.
    thanks.
  • 4,472 Answers
You cannot copy video through the usb port. Only pictures. I can assist you further on how to transfer video.
Thanks,
Lee
  • Lee A.
    Lee A. Nov 16, 2008
    USB Interface (SC-DC173(U)/DC175/DC575 only)
    Notes
     On a slower PC than recommended, movie playback may not be smooth or video editing may take a long time.
     On a slower PC than recommended, movie playback may skip frames or operate unexpectedly.
     Intel® Pentium III™ or Pentium 4™ is a trademark of the Intel Corporation.
     Windows® is a registered trademark of the Microsoft® Corporation.
     All other brands and names are property of their respective owners.
     In M.Cam Mode or M.Player Mode, be sure that the Memory Card is inserted into the DVD Camcorder before connecting
    USB cable. If no Memory Card or an unformatted Memory Card is inserted, the PC will not recognize your DVD Camcorder
    as a removable disk.
     USB Streaming requires Video Codec, DV Driver and DirectX 9.0.
     If you disconnect the USB cable from the PC or the DVD Camcorder during the data transfer, the data transfer will stop and
    the data may be damaged.
     If you connect the USB cable to a PC using a USB HUB or with other devices at the same time, it may cause conflict and
    may not work properly. If this occurs, remove all other USB devices and try the connection again.
    Using the Camcorder as a USB Device (USB Connect)
     The USB Connect function works only in M.Player Mode. page 26
     Using the USB cable, you can connect your DVD Camcorder to a computer to copy your moving images and photo images
    from the Memory Card, or to a printer to print your images.
    1. Set the [Mode] switch to [CARD].
    2. Set the [Power] switch to [ (Player)].
    3. Press the [MENU] button.
     The menu list will appear.
    4. Move the [Joystick] up or down to select , then press the [Joystick].
    5. Move the [Joystick] up or down to select , then press the [Joystick].
    6. Move the [Joystick] up or down to select or , then press the
    [Joystick].
     You can select to use the DVD Camcorder as a PC Camera, USB
    Stream or removable disk.
     You can select to use the PictBridge feature. page 105
    7. To exit, press the [MENU] button.
    Installing DV Media PRO Program
    Before your start!
     Turn on your PC. Exit all other running applications.
     Insert the provided CD into the CD-ROM drive.
    The setup screen appears automatically soon after the CD is inserted. If the setup screen does not appear, click on “Start”
    on the bottom left corner and select “Run” to display a dialog. Type “D:\autorun.exe” and then press ENTER, if your
    CD-ROM drive is mapped to “D:Drive”.
    Installing Driver - DV Driver and DirectX 9.0
     DV Driver is a software driver that is required to support connection to a PC.
    (If it is not installed, some functions will not be supported.)
    1. Click on on the Setup screen.
     Driver software is installed automatically. Following drivers will be installed:
    - PC Camera/USB Streaming driver(Capture Driver)
    2. Click on to finish driver installation.
    3. If the is not installed, it is installed automatically after setting .
     After installing , please restart your PC.
     If is installed already, there is no need to restart the PC.
    Application Installation - Video Codec
     Click on
USB not working- Samsung Digital SC-D372
take battery out and use mains power(might help)
May 17, 2010 | Samsung SC-D372 Camcorder
I cannot get the computer to recognize that I have a camcorder install? I wiould like to use my camcorder to work on my laptop and I cannot get the computer to work with the camcorder.
Make sure that the software/driver of your camcorder is installed on your computer. The driver is included in the package with your camcorder. If it's already installed, try using other USB ports on your computer. If that fails, try hooking other devices that use USB ports on your computer, and see it that work. If other devices work w/ the USB, check the USB cable of the camcorder, then try to see if there is a setup on the camcorder that indicates "connect to computer", some camcorders have this. If all else fail, contact your manufacturer.
Nov 11, 2009 | Samsung SC-D363 Mini DV Digital Camcorder
Formatting the disk
Yes, the mini DVD-RW will work on this camera. When you insert the disk and power on the camcorder (with the mode on DISC), the camcorder will try to read the disk, and if it isn't formatted yet, the LCD display will offer you the option to format it (in VR or Video mode). Simply select and click to format the disk
May 07, 2009 | Samsung SC-DC173 DVD Camcorder
Driver for Samsung DVD Camera Recorder SC DC173U
go to the samsung.com website. their support section has drivers and instructions.
Dec 11, 2008 | Samsung SC-D363 Mini DV Digital Camcorder
I need 2 open my samsung dvd camera recorder sc-dc173u my usb port is pushed in
TAKE ALL THE LITTLE SCREWS OUT FROM THE OUTSIDE. REMEMBER WHERE THEY GO WHEN U PUT IT BACK TOGETHER.. DONT OPEN THIS UP WITH A BATTERY OR A INTERNAL BATTERY INSIDE. TAKE ALL BATTERIES OUT THEN TURN UNIT ON FOR A MINUTE TO DRAIN LEFTOVER POWER OUT. THEN OPEN UP. GOOD LUCK
Oct 27, 2008 | Samsung SCDC163 Camcorder
Problem w/my Samsung DVD Camcorder SC-DC173U
my disc are blank after recoding
Jul 02, 2008 | Video Cameras
"No Disk!" Error
hi there, have you refered to the manual which type of dvd your cam reads?
you usually get this "no disk" on screen when inserting a non readable disk or a disk that it doesnt support.
hope this helps
Jan 29, 2008 | Samsung DVD Camcorder
How do I downloard pics from my Samsung SC-D6550 Camcorder?
Are you using a Video Camera? If so, you need a Fire Wire cable, not a USB cable. You can get Fire Wire Cables at Radio Shack or any store that sells electronics.
Sep 26, 2007 | Samsung SC-D6550 Duocam Mini DV Digital...
Computers & Internet Logo
41 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
