Question about Pioneer AirWave XM2Go Satellite Radio Receiver with Home and Car Kit
Low Volume on Aux output
My Airwave XM radio has been working fine, hooked up to my portable FM radio until yesterday... now the volume is so low it's inaudible and impossible to increase. I have checked all the connections but nothing seems to correct it. What could this be? (both devices are plugged into wall outlets so it's not batteries.)
  • Waverxm Jan 18, 2008
    I have the same problem I tried my spare battery and it fixed it for 5 minutes. I think its the ac adapter relay or a relay in the docking station. My radio says battery charged. If I unplug my ac adapter and plug in back in it work for a minute or less. It tried checking the voltage and it was ok on the adapter. But it might cut out under load.
2 Suggested Answers
TOLhamRadio
  • 509 Answers
SOURCE: Airwave won't power up!
Remove back cover. Plug DC adapter into the bottom of the radio. Use an extra small paperclip or pin to push the 'reset' button just to the left of the white battery. Report back on progress.
Posted on Sep 05, 2009
Volume is too low even when turned all the way up
The power or out put ic could be damaged. Please visit a qualified technician to check on this. You couls also check if the female part of your stereo jack pin is okay.
Mar 09, 2014 | Pioneer inno2 Portable XM Satellite Radio...
My xm plays extremely loud thru my car stereo.no matter what i set the volume at.it is either off when volume is set to zero or loud at any other setting.changing the output level on the xm receiver does...
Are you playing it directly thru your FM antenna connection, or using the RCA jacks? You have to set the FM modulator level. It is also possible that you have a new FM radio with a type of ALC that will raise the lever regardless, but your regular car radio volume control should work. do not wire this directly to a power amp, as you won't have the control that you need. Good luck, let me know more.
Apr 01, 2010 | Terk XM Commander Satellite Radio Receiver
The factory xm volume to low in 2006 corvette
Separate 'plug and play' XM radios, like the one pictured above, have a "MENU" setup, and you can adjust the "Audio Level" in that menu setting. See if you can access an XM menu. You can also ask your question over at XM411.com or XMfan.com; both are 'fan' websites.
Good luck - nice car too!
Aug 05, 2009 | Delphi SKYFi2 SA10126 XM Radio Receiver
Aux in runs only back speakers and no volume control
check sub setting some radios can select between non fading sub output or aux input
May 08, 2009 | Pioneer DEH-P3000 CD Player
1000 w sony xplode works at low volume then red lights at volume5
Most likely one of your subs are blown, or the Ohm's are too low for the ampliphier. Try hooking up one speaker at a time to the amp and see if it does the same thing. If it shuts off on one of the two speakers, that speaker is most likely blown.
Apr 19, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony CD Walkman-(portable Radio -CD player)Very low sound output.
Problem solved by trying another set of headphones.
Thanks anyway.
Gerda
Apr 05, 2009 | Sony (Personal Audio) Walkman AM/FM Stereo...
75-822 cb that has extremely low audio output
Hello..if you can try to connect a external speaker or phones..if the volume is ok..than i think it is time to replace your internal speaker..pse tll me....good luck...Ron
Mar 14, 2008 | Midland 75-822 40-Channels Handheld CB...
Bose Wave System CD 2000 FM volume much lower cd stops if volume higher.
sounds like a loose cable from the control bard to , some one will have to open up to fix, i recommend bose do that for you,
as for fm volume, the same could be the cause as the fm antenna coudl be disconnected, ( are you using an external FM antenna ?)
Feb 29, 2008 | Bose Wave Radio
AUX Input, very low volume
Try turning the volume up on the pc first, and then the hts volume should be amplified by using its own volume control
Feb 11, 2008 | Philips LX3950W System
Pioneer AirWave XM2Go Satellite Radio Receiver with Home and Car Kit Logo
50 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
