Question about Vivitar Cameras
Vivitar series 1 440PZ it will not take a picture or it might take the picture and then not wind film and batteries are new
  • 1 more comment
  • bgewing Nov 17, 2008
    I DID NOT PAY TO BE TOLD HOW LONG IT'S BEEN GOING ON AND THEN YOU NEED TO BRING IT TO AN EXPERT. THOUGHT THAT IS WHY I WAS HERE.
    THE PROBLEM STARTED LAST SPRING. I DID NOT TRY TO USE IT AGAIN UNTIL I JUST POSTED FOR HELP. THIS IS NOT A DIGITAL CAMERA IT IS A 35MM. PLEASE DO NOT SEND ME TO KIDS. THE CAMERA WILL NOT SNAP A PHOTO WHEN THE BUTTON IS PRESSED. IF YOU KEEP TRYING THE PHOTO MIGHT BE TAKEN BUT IT WILL NOT WIND FORWARD. IF YOU TRY TAKING ANOTHER PHOTO IT MIGHT OR MIGHT NOT TAKE. THEN IT MIGHT OR MIGHT NOT WIND FORWARD. THE CAMERA IS A 35MM VIVITAR SERIES 1 440PZ
    CLEANING THE BATTER AREA DIDN'T WORK IT WAS SPOTLESS INSIDE.
    IF I HAD BROUGHT IT TO A SPECIAL LIST I WOULDN'T BE HERE. THE CAMERA DOES TURN OFF AND ON. IT WILL AUTOMATICALLY TURN ITSELF OFF. THE ZOOM WORKS JUST FINE.
  • 4,806 Answers
The winding mechanism and shutter is either stuck or broken, plus the cogs that grab and wind the film is somehow defective possibly one of the teeth have broken off of the cogs, if you don't want take the camera to a shop them you must locate the problem yourself and try to fix it, amybe a bit of grease will come in handy
best regards
Posted on Nov 17, 2008
    Sergeant:
  • 237 Answers
Have you tried the first solution?
  • zabrina liang Nov 18, 2008
    Hi...I'm sorry all this happened. How long have you had this camera? If only the batteries are the new part, then I'm afraid this camera is a gonner.
    Scholar:
  • 181 Answers
The socket where the battery is inserted clean that socket and again insert the battery and then check out.
Posted on Nov 16, 2008
  • 4,472 Answers
How long has this problem been occurring. Are you trying to fix this yourself? Most likely you will want to have it serviced by a professional. I can assist you in locating one once I get more information from you.
Thanks,
Lee
  • Lee A.
    Lee A. Nov 17, 2008
    That is why i requested more information from you. I am well aware it is a 35mm camera. I needed to know wether or not you are planning on fixing this yourself. Being that you are here asking for assistance then you do not have the expertise required to fix the camera. That is why a professional is the best solution. If you need further assistance please let me know.
    Scholar:
  • 126 Answers
Hello bgewing,
Sounds like the push button on the unit has a bad connector to the camera board. When you push the button to take a picture it triggers the shutter which then inturn is supposed to forward the wheel assembly that the film is attached too.
The only fix is unfortunately to disassemble the camera and look for a broken or cracked solder. As you said, sometimes it works and sometimes it doesn't, there is a broken or cracked connector inside the camera that is barely making contact thus making it work when it puhsed just right.
Hope this helps.
I used my camera for 17-20 shots but then layed it aside and haven't used it again until now. Will the film be harmed? It's been over a year. That's probably a silly question but can I...
Hi Barbara - The film is actually a digital data file in a digital camera so your 17-20 photos should still be fine on the camera. Data files don't go bad with time.
You can just take up shooting from where you left off originally, just make sure the batteries are fresh and off you go.
Good Luck and happy shooting,
Mikeywaf
May 25, 2011 | Vivitar Cameras
How to open a Vivitar 845 camera?
On the back of the camera, there are two sliders. The left hand one is the battery cover, and the other is the film back release.camera03a.jpg
Film advance is automatic when batteries are in it.
If this picture doesn't come out clearly, look at the ebay listing I copied it from ....
http://cgi.ebay.com/VIVITAR-845-TELE-MOTOR-110-POCKET-CAMERA-w%2FMANUAL,-CASE_W0QQitemZ380209378342QQcmdZViewItemQQimsxZ20100225?IMSfp=TL1002251310008r37318
Feb 28, 2010 | Cameras
What if the rewinding lever doesnt rewind ?
Change the batteries under the camera. This camera is electronic. With a new battery, the camera will reset the mirror and you can **** the shutter and lower the mirror. If this does not fix the problem you may have a shutter or advance problem and the camera would have to be send off for repair. Start witht he battery, that is the fix 9 out of 10 times.
Feb 26, 2010 | Vivitar V3800N Zoom 35mm SLR Camera
Vivitar 3800n film advance lever does not move all the way. it only moves less than a quarter of a turn
make sure film is out and try to rotate the lever from the inside of the camera by turning it if the film release button "at the bottom" pop out then you should be able to use the lever again if not then it's a mechanical problem something might be out of place or broken. i just had the same issue 5 min ago and now it works fine.
Jan 29, 2010 | Vivitar V3800N 35mm SLR Camera
New roll of film rewinds instead of advancing
Your camera has a faulty winding mechanism. It suppose to rewind in the end of the film when there are tension present but somehow the detecting system in your winding mechanism is detecting when the back door is closed. Remedy is replacing the clutch system within winding mechanism. Average repair runs about $90. -James. For further assistance by email, go to www.camerarepairjapan.com
Mar 21, 2009 | Nikon N55 35mm SLR Camera
Forget how to take double pictures.
Hey xplaur,
To take a multiexposure photograph you should first expose the film, and then push the multiexposure button which is on the front of the camera on the top left when you are looking at the front of the camera. After you press this button advance the winding lever to set the shutter, and since the multiexposure button was pressed this shouldn't wind the film to the next frame. Now take your second exposure, and if you want to make another exposure on the same frame repeat the process. Keep in mind that every time you expose a single frame after the initial exposure you will be doubling the exposure on the frame. I usually under expose each exposure by one third on a double exposed frame. If you do more than two exposures I would underexpose each exposure by even more. Multi exposures are fun but tricky, and I would suggest you experiment and have fun with it. I will also say that black and white film is much more controllable and forgiving when it comes to this than color film. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 31, 2008 | Vivitar V3800N 35mm SLR Camera
Pentax ME slr (old hand film wind )
the film might not have been catching onto the wheel it has happend to me befor
Oct 05, 2007 | Pentax ME Super 35mm SLR Camera
Vivitar mini digital camara
all you have to do is buy a new battery that is what i do and it works all the time
Sep 21, 2007 | Vivitar Cameras
ME dillemma
Also, I just tried the delayed picture-taking lever, ??????? you mean self timer. if you have used self timer then unless the cycle is completed the camera will stuck in the middle, with the mirror locked up. Try releasing the self timer by moving the lever manually. if nothing major defect is theirin the self timer it will release by doing this.
Nov 15, 2006 | Pentax ME Super 35mm SLR Camera
Cameras Logo
49 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
