Question about Frigidaire Dryers
Frigidare ice maker making slabs of ice, not cubes
Why won't my icemaker make cubes. Also it has started to allow water to go to tray in front. I tried turning up the controls to make colder. But all i get is slabs, not cubes. It actually jams the auger.
    Problem Solver:
Today, I removed ice maker and auger motor. Found out this morning that water was running down the back of frig. inside, everything in freezer was frozen together. Found this out after removing all food from freezer. When i looked into the ice maker where water enters, that was frozen solid. After thawing and checking everthing. I put it back together in freezer. It is nine oclock now, and I do have cubes. I really can't tell you what I did, except thaw it all out. It's been running for four hours now and it seems to be all right.
Posted on Nov 18, 2008
Ice cube tray won't stop making ice.
This is due to the arm that controls the switch on the icemaker itself either being shorted or froozen in the toggled position. Usually the arm would lift as your ice container becomes full and shut the icemaker off until it reached a level where the switch would then toggle to the make ice position and then start makeing ice again. There are three 1/4" screws that hold the icemaker in place remove these screws unplug the icemaker and then use hot water to dethaw your ice maker for about 2-4 minutes after wards dry the icemaker then try reinstalling the icemaker if the problem persists replace the icemaker itself. If you have any further questions message me back I await your reply.
Thank you
Rick
Mar 12, 2012 | Refrigerators
My Liebherr ign 2566 freezer is having problems with the icemaker. It is producing ice cubes but also water is pouring direct into the tray therefore producing a big slab of frozen water.
Hello there,
You need to check the water inlet valve, it is having a problem, it is not shutting close after filling the ice maker with water. It is already defective hereby causing water to pour out into the tray therefore producing the big slab of frozen water.
You will have to test and replace the water inlet valve. That way, it will stop pouring water into the already made ice that is in the tray.
Hope this helped. All the best Elect_Comp
Sep 23, 2011 | Liebherr Refrigerators
I set the ice maker feature to make cubes with my samsung refrigerator rs2555sw. But the ice maker makes a ice chunk. All the cubes are frozen together with a flat and thick layer of ice on top..
Hi and welcome to Fixya.
Remove the front cover after the ice tray has dumped cubes and remove all of the water from your ice maker tray.
Then depress the test button on the bottom of the icemaker (in front on bottom) located about 1 inch from the lower rh corner.
The icemaker fill cycle should add just enough water to cover barely cover the tray. (see page 32 of the 25 Sept 2005 user's manual)
If it is overfilling the icemaker fill time / water level needs to be reduced on the ice maker module. A normal fill cycle is about 7.5 seconds.
Another thing that will cause larger cubes is high water supply (utility co) pressure.
A temporary fix would be to slowly close the refridgerator water supply line's shut off vavle so that the water flow restricts.
The real solution is to investigate ice maker fill time, and the function of the icemaker water supply solenoid vavle for possible Delayed closing of the internal diaphram.
Feb 06, 2010 | Refrigerators
Maytag ice maker will not release cubes
Sounds like it has a " seeping " water valve . Only thing to do is replace the water inlet valve . There is a certain amount of water to go into icemaker at fill . A seeping valve will let water continually drip into icemaker , making large cubes which icemaker cannot dump . A larger amount of seeping , will overfill the icemaker , and drip into the freezer and floor .
Aug 12, 2009 | Maytag Refrigerators
Kenmore refer #70162990 ice maker leaking into storage tray
Please confirm you have given the complete model number.
If the icemaker has a bail wire to control how much ice is in the bin, there is a fill switch inside the front cover of the ice maker which allows you to increase or decrease the amount of fill.
You may also have a cracked or corroded ice mold. Check by filling the icemaker with water manually, and watching to see if it drips once the initial overfill stops dripping. This would also be indicated by the ice cubes being smaller than usual.
Jan 04, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Water runing down back side of icemaker and forming icicle.
If it is running down the back of the icmeaker then you need to make sure the inlet tube is properly installed into the fill cup on the icemaker. If the tube is in the right place then your icemaker fill level needs to be adjusted.
Dec 07, 2008 | Refrigerators
Sub-Zero 632 Ice Maker Leaking into Ice Bucket
Ice Maker is overflowing and leaking into the ice bucket: There are several things to check for.
Go for the easy stuff first, make sure the icemaker is level, some of the plastic liner fridge's will move and allow the icemaker to tilt over and leak. Other troublemakers..... the fill valve
staying on and over filling the icemaker..... the finish sometimes comes off the icemaker body and all the ice cubes don't come out. This will allow the new water to fill on top of an icemaker
that still has a ice cube or two left inside the body, if you have had trouble with black specs in your ice cubes, this may have been the beginning of your finish problem on the icemaker body.
On the module style ice makers (Whirlpool, Maytag Family, Sub Zero) the printed circuit in the
module head often wears and the contacts become too long and allow the icemaker to over fill = new ice maker or new module head.
Older style icemakers: This gear is bad for breaking and the icemaker quits turning to eject the ice.
You can remove the front cover to see the gear.
This is a common parts breakdown of the older style icemakers
Water fill volume: The water fill adjustment screw will change the fill volumes by changing the fill time.
One half to one full turn usually ( approx ) is equal to 20cc ( 0.68oz ) to 40 cc.
The correct fill is usually 130 to 150 cc ( 4.5 to 5.0 oz ).
When a water valve is replaced the fill volumes must be re-checked!
http://www.SubZeroLosAngeles.com
________________________________________
Sub-Zero Service Experts in LA Metro
Aug 15, 2008 | Sub-Zero 632 / S
I have a 13 year old refrigerator with an icemaker. I installed a water line to get water to the fridge. The hose is connected to the water main and the fridge. I am not getting any ice.
Obviously, your ice maker problem could be any number of things... Now that you have water to the ice maker, is the inlet valve opening to allow water to get to the ice maker itself? If it is, is the line that runs between the inlet valve free to allow water to get to the ice maker? if it is, is the ice maker cycling ( meaning the motor rotates the drive mechanism that times the cycle of opening the valve, rotating the mold tray then releasing the ice with a small mold release heater? An ice maker that's ~ 13 years old probably has a removable front cover so that you can see the drive gears.. Also, is the lever that senses the ice cube bin is over full in a position ( normally down) that allows th eice cube maker to cycle? Hopefully, these simple checks will help you trouble shoot the problem and get your icemaker functioning again. Hope this helps !
Aug 14, 2008 | Amana Refrigerators
Ice Cube maker stops making cubes as they are being made ....
Ice makers use a small heating element to release the ice from the mold tray..sounds like that isn't working and everything else is. Check to make sure all electrical connectors coming from the ice maker are properly seated into their mating connectors. If that doesn't solve your problem, you may be better serevd by just replacing the entire icemaker assembly.. Hope that helps...
Jul 25, 2008 | Frigidaire FRS26R4A Side by Side...
Frozen slabs of ice instead of ice cubes
the icemaker could be leaking by can you see where the water is coming down into the bin from??
Jan 23, 2008 | GALAXY Microsystems 55622
Dryers Logo
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
