Question about Casio EX-Z1050 Digital Camera
Lens does not close anymore -
We opened the camera all was fine but when we tried to close it the lens stayed open and even if we try to close it down, we just hear a weir noise and nothing happens. Tried recharging the battery.
When you opened it the cog connected to the motor which opens and closes the lens probably shifted and no longer has traction against the ring around the inside of the lens which turns it to open and close it. If you open the camera up again be extremely careful - the lens has loads of springs inside it - lose one of these and it won't work properly. I opened up the whole thing to try and fix my lens which had been jammed in after a friend dropped it. I fixed the lens but couldn't put the damn thing back together again to many tiny parts and no guide to the jigsaw!!
Posted on Apr 20, 2009
I dropped my camera on the lens while it was open, now it will not close. I noticed it was slightly blurry when i tryed to take a new pic. I turned it off and then back on and the lens didn't move
Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Jan 23, 2012 | Olympus Software VG-120 Digital Camera
My nikkon coolpix is a month new and almost only 3 weeks used..my uncle bought it in states...when i am taking pictures i zoom it and a message "LENS ERROR " appear on the screen and because i...
1.Check if something block it (maybe sand or smt like that
2. Never pushed lens manualy (you may broke it completly)
3.Just try to shake or slap it jently while open or close it.
Jun 07, 2011 | Nikon Coolpix S3000 Digital Camera
Dropped the Camera, Lens is stuck open
I already tried posting this but I think it falied. Just in case, here it is again!
I just now fixed my own Nikon S220 (very similar to 210) which suffered the same fate as yours. However, I laid my camera down on a cushioned foot-rest (you could use a couch cushion or pillow on a table) with the lens facing UP, pressed down on both sides of lens front gently yet firmly, and BAM, the lens went back in all the way. I turned the power back on and the camera is good as new (except for the small dent from the fall of course).
I suggest you try this before spending $100 on repairs and/or buying a new camera!
Sep 09, 2009 | Nikon Coolpix S210 Digital Camera
The lens cover will not open and close all the way.
to open them completely simply push them with your finger. try doing so also when closing them. i have the same issue sometimes.
Jul 13, 2009 | Panasonic Lumix DMC-LZ7 Digital Camera
When i turn on the camera the lens wont pop open even when the battery is fully charged.... i was taking pictures and it working fine turn the camera off and on again then the lens wont open anymore? i can...
The problem is
1- some dirt somehow got on the outside of the lense. After it was retracted fully in, it prevents the camera from opening again. When you turn it on, if it opens a little bit, try to pull it out NOT too hard and let go a few times. If it opened, clear the outside of the lense. Your camera should be back to normal.
2- If you droped the camera, you probably damaged or dislocated a mechanical part of the lense. You may have to take out the lense by unscrewing it and inspect it for damged parts or disconnected cable. Make sure clean the lense and test it by moving it in and out a few times, before puting it back on the camera.
Good luck!!!!!!!
Jun 10, 2009 | Sony Cyber-shot DSC-N2 Digital Camera
Lenses on digital camera
Hey jamber716,
I am assuming you mean the lens cover is half open and won't close or open. You could try blowing compressed air into the lens to try and dislodge whatever is making the lens cover stick. If that doesn't work I would have the camera looked at by an authorized service technician. You could bring it to a Geek Squad® precinct in a Best Buy™ store and they should be able to send it out to an authorized service center. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 29, 2008 | Nikon Coolpix 4600 Digital Camera
Lens cover stays open
hello lmsmith, the reason the lens protection shutter does not close, is that it is either jammed by sand, dirt or sticky substance. it is going to need cleaning by a qualified technician.
Jun 04, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
"Cover Is Not Open" And The "Lens Cover" Is Open...
the lens cover switch of your camera have a poor contact that why that message is appearing...you have no choice but to disassemble the camera for repairing or cleaning that switch....i suggest you have to go the service center now and don't try open your camera if you are not a technician cause you may damage the flexwire of the lcd monitor if you not properly remove the cover...
Aug 30, 2007 | Sony Handycam DCR-HC21 Mini DV Digital...
Lens cover
I know this is an old post, but for those who want to fix it themselves: try blowing lots of compressed air around the open lens shutter to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Also with the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. A grain of sand in the mechanism is usually the culprit, and you want to try to dislodge it.
You can open it up, but only as a very last resort. The above procedures usually work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk):
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Jan 16, 2007 | Casio Exilim EX-Z120 Digital Camera
Casio EX-Z1050 Digital Camera Logo
324 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
