Question about GE Spacemaker JVM1640SJ Microwave Oven
Fan and light buttons pushed in, how do i install new buttons.
Model jvm2070sh001
I just fixed mine. Same problem.
  1. remove the top vent (like replacing filter) w/ 2 or 3 screws on the top of the unit
  2. Remove the one screw on the top of the clock/control unit.
  3. Remove the clock/control panel by sliding up then out
  4. See circuit board at the bottom for the 3 switches. Hopefully it just popped out of place.
  5. pop it back into place and re-assemble
  6. if it's broken, you'll have to find the replacement part here: http://www.geappliances.com/service_and_support/
  7. If the actual buttons (black plastic) are broken, you have to replace the whole plastic housing for the electronics. Probably a big project and/or you'd replace the whole bit for hundreds of dollars, but even still, it's a pop-out, pop-in.
Good luck,
-tj
Posted on Jan 04, 2009
How do I access & fix the control board buttons (ie Hi/Lo/Off light & Vent) which some how got pushed in?
Thanks Michael but the problem is the light & vent buttons got pushed in so far that I can't use the fan or light. Please help!!!!
/uploads/images/access-amp-amp-fix-control-board-34894445-1-1.jpg
Jan 21, 2015 | Samsung 2.0 cu ft Over-the-Range Microwave...
I have a GE JVM2070SH001 micowave . I do not have power to the under unit lights (work,nitelight) but everything else works fine. What is the likely problem?
Either the control board or the switch itself. I can't remember if that on is part of the main keypad or not. Does the unit beep when you press the light button? If it does then you need to follow the wiring to a point where you have power. Best guess...control board
Dec 05, 2012 | GE Profile Spacemaker Over-the-Range...
GE model JVM2070SK02 touch pad not working
Most people, and GE will tell you these are not repairable and you must replace the whole unit for $300 - 500. I can fix them. If you are interested, let me know. em.ka.ventures@gmail.com I can only fix the touchpad not working and it must not be physically damaged. You must be able to take out the control panel and send it to me. It is easy (3 screws and electrical connectors).
Jun 01, 2012 | GE Profile Spacemaker Over-the-Range...
GE Microwave oven turntable wont spin bushing can be tuurned freely and tray will spin when manually turned.
The turnable motor must be replaced, go to www.ebay.com Type: make and model of microwave oven, refine search to turntable motor.
May 07, 2012 | GE Profile Spacemaker Over-the-Range...
Ge profile spacemaker 2.0 model#JVM2070SH001 - HOW TO REPLACE CHARCOAL FILTER.
That's covered in the owner's manual. If for some reason you don't have yours, you can download GE owner's manuals and installation instructions here.
You can find handy exploded views and order parts (including filters) here.
Jan 10, 2011 | GE Profile Spacemaker Over-the-Range...
The display works (clock, mode, etc) I can push
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Apr 27, 2010 | Whirlpool GH9176XM Microwave Oven
JVM2070SH001
you have a bad magnetron. go to sears parts direct and you can see the price for a new one. but it may not pay tp fix.
Feb 25, 2010 | GE Profile Spacemaker Over-the-Range...
GE Spacemaker JVM1640SJ Microwave Oven Logo
422 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
