I tried to reset the router following the instructions on the manual and this forum but it refuses to reset. I tried the reset hole for more than 20s and the wlan light does not stop blinking. I am not able to access the router setup page either, tried the usual 192.168.0.1, etc...it is like it is not connected to the pc, although when I disconnect the lan cable the pc detects it was disconnected.
Thanks for any help you can give me. regards, antonio
That the default page for the config page for DLINK router/modem
Same Problem
Apr 09, 2008
-   Hi there i have just bought a new hp laptop and wireless router. I started to set up the router following the instructions given and now i cannot set it up properly? 1st i typed in the web address given and typed in admin. Then i clicked on run wizard, i then clicked on next and created a password and it asked me to enter user name and password. Then when it type in my user name and password it comes up unauthirized? The router is working but not secure. Please help.-   gav_76
Apr 04, 2008
-   exactly the same. It's as though the router is not there.-   Guest
Mar 12, 2008
-   I used DI 514 for last 5 years. It worked fine. I used both wired and wireless connectivity. Suddenly one day it is stopped working. I can see all the lights are glowing except the Status light. When I connect from computer to router, it shows as connected. But I cannot browse any page from internet. Even I cannot use the wireless. I reset to defaults as mentioned by manual. But no use. I also tried to go the configuration page and it is not going to that. Pls help me how I can resolve this issue. Thanks for all your solutions.-   ChandraB
assuming your pc has previously connected to the router, why did you require a reset.
Remove your RJ45 cable and try reset button for 10 secs then let go.
The other problem I see is you cannot connect through both wireless and wired to one IP address, you say the wireless lan light flickers and then say it knows you have removed cable, are you trying to connect via two different computers or just one.
Please reply on this post and not a new one; it's hard to follow.
Was this helpful?
Yes
No
Popular Solutions for D-Link DI 514 Wireless Router
everything was perfect during the installation till when i was going to start lan...how can i...
(More)
EVERYTHING WAS PERFECT DURING THE INSTALLATION TILL WHEN I WAS GOING TO START LAN...HOW CAN I CONTINUE WITH THE WIZARD PAGE TO CONTINUE MY INSTALL? MY ROUTER D-LINK DI 524
Dl-514 is not connecting to DSL PPPOE. I have keep disconnecting the power cable to reconnect, Seem...
(More)
Dl-514 is not connecting to DSL PPPOE. I have keep disconnecting the power cable to reconnect, Seem it is not trying to dial.
