Question about Whirlpool Freezers
Refridgerator freezer not geting cold
Quit all of a sudden. I have cleaned coils underneath even blew out with compressed air. all fans seem to be runing compressor is rather hot. I can hear a click and compressor runs for less than a minute and then not again for 3-4 minutes. can you help?
  • k1ngfam Nov 16, 2008
    By the way this is a wirlpool conquest side by side
  • Anonymous Mar 30, 2014
    I turned it up to the igloo setting and the compressor started vibrating. Turned it clear down then back to a setting of 4 and it seemed to work. However, still not getting cold enough.
  • 367 Answers
Your compressor has shorted out. The compressor shouldnt be scorching hot just warm. And that humming you are hearing is the compressor trying to start but it is shorted. There is nothing you can do except for replace the compressor.(or the refrigerator)
Posted on Nov 19, 2008
What can make my refridgerator stop getting cold?
Many issues. First dirty coils bye the compressor,defective condenser fan, or defective evaporator fan or even low on charge
Nov 07, 2015 | Sunfrost RF19-24V High-Efficiency...
My true gdm-43f freezer keeps running won
Not sure exactly what the situation is I'm going to give you a detailed overview on how the system works that way you'll be able to isolate the problem. Your machine is a single compressor unit, meaning that even though there are two seperate sides, the freezer and the refridgerator, they do not operate independantly. The sealed system, which is what cools the machine, has two parts, a high side and a low side. The high side is located under the machine and consist of a condensor, for which freon is pressurized back into a liquid and passed throug the compresoor to be released as a gas into the evaperator, the low side. This is where the freon is at a cold state. Ok, now that you have the bare basics of a sealed system, we move forward. The Evaporator is located in the freezer side, behind the freezer wall. As freon goes through the evaporator, a fan, called the evaporator fan, is located above it and circulates air throughout the freezer compartment. Also, an airway connects the freezer to the refridgerator, usually top right of freezer, or top left refridgerator on side by sides and through the freezer floor on top mount models. This means the freezer cools the refridgerator side. ****First check point**** Is the fan running in the freezer? This would cause the freezer not to cool as well but also a rise in the refrigeration side would be noticed. As freon goes throught the evaporator, which is made of aluminum, the temperature levels are well below the freezing point, so frost and ice will form on the coils. Over time, this kind of build up would form a blockage, not letting air be drawn from the bottom of the coils by the fan to circulate the cold air. To prevent this from happening the a defrost heater is installed to thaw the ice away and comes on every 6-8 hours. This is initiated by the defrost timer, or in some machines an adaptive defrost control. The heater will be located at the bottom of the evaporator because hot air rises, getting maximum effect. A third part to the defrost system, the first two being the timer and heater, is a bi-metal,or terminating thermost. Its called this because when the thermostat is cold, the metal inside it constricts making a pathway for electricity to flow through to the defrost heaters so it can get hot, and as the heat rises and the ice melts away, the terminating thermostat will warm up, and the metal will expand causing the path of electricity to be broken, turing the heaters off. This is to prevent any high temperature situation from happening, like melting plastic or even a fire. If any of these parts fail, the machine will nit defrost. ***Checkpoint two***** Do you see any ice build up on the freezer wall. This ice will be completely across the back wall. Most signs of defrost problems are noticed first by a rise in temperature on the refrigerator side first. The above can be assessed with a quick look and listen. If no frost is present and the fan is running you can rule out the above. ****Please not that ice build up on just a small section, for example, upper left or right corner only is not a defrost situation but a sealed system issue, caused from low freon or a restriction in the lines and a EPA certified technician should be called.****** The last thing you should check you'll need to pull the machine away from the wall and remove the lower panel to gain access to the compressor area. What you are checking here is to see if the condensor fan motor is running and that the coils are somewhat clean enough for air to flow across them. The fan draws air from across the compressor and through the coils helping to keep the compressor temperature down and also to evaporate the water that is drain when the machine goes into defrost. Rule of thumb is if the compressor is on the fan should be. If the fan isn't runnning the heat from the compressor will be transferred to the machine and notice first on the freezer more so than the refrigerator. ****checkpoint three**** IS the condensor fan running? Are the coils clean, and can you feel the air from the fan with your hand placed on the opposite side of the coils?
The refrigerator side is usually where your defrost timer, discussed earlier is located. Also on this side is where your temperature control, or controls , are located, These controls are what are called thermostats, and have a direct line to the compressor. This means when the temperature has reached the desired setting the thermostat will kill power to the compressor in the same manner the terminating thermostat does with the defrost heater. Some models have a temperature control thermostat for the freezer and the refrigeratot, but some only for the refrigerator. The most noticeable sign of a thermostat being bad is the food in the refrigerator side will freeze, usually on any setting or the machine won't come on at all, including the fans. Problems are usually noticed on the refrigeratot side first. The last thing to discuss is The freezer and the refrigerator both are rising in temperature, but the fans are running, etc. Normally in cases like this a humming sound followed by click is heard or sometimes just the click. The humming sound is the compressor trying to start but failing and the click is the relay breaking contact. On newer machines, especially ones that fall under the whirlpool umbrella, the compressor relay, also called the start device has failed and needs to be replaced, but also the compressor itself could be bad. Well, thats the basics. I know it's long winded but I wanted to put something that you could print out and use as reference. Good luck.
Jun 19, 2012 | True GDM43F Commercial Freezer
Wont get below 24 degrees only end of the coil inside the freezer seems to get cold at the very top in the back
if these coils are clean and the fans are operating then the refrigerant charge needs checked. I would also check the compression ratio on the compressor to see if the compressor has weak reed valves. this would let the refrigerant pressures equalize. and would not remove heat as efficiently as it should. This would make the compressor run alot more
Nov 19, 2009 | Frigidaire 20 cu. ft. / 566 liter Upright...
Not sure of the model or make, but the freezer and refridgerator work and then dont work, i can freeze water but a day or two later it's thawed?
First, make sure the refrigerant coils underneath the unit are not dirty. If so, clean them off.
Second, make sure the compressor (underneath the refrigerator) is running.
Third, make sure the compressor fan (underneath the refrigerator close to the compressor) is turning. This fan should always be turning when the compressor is running. It removes heat from the refrigerant coils and transfers it to the outside.
Fourth, make certain the evaporator fan (in the freezer, likely behind an access panel) is turning.
All of these conditions must be present for proper cooling.
Oct 20, 2009 | Freezers
Gladiator ref is not cooling properly
Check to see if there is cold air coming from the freezer to the refridgerator side through the vent holes The compressor maybe getting weak or the freon charge maybe low. Does the unit run a long time before it shuts off? 50 degrees is not cold enough for a freezer. You should be around 32 or less.
John
Sep 28, 2009 | Gladiator Freezer GAFZ21XXRK
Freezer is getting to about o degrees but refrigerator section wont go below 50 this is amana side by side asb2623hrw also changed the defrost timer about a month ago and blew off the coils from underneath...
Check your lower air shutter that lets cold air move from the freezer to the refrigerator's. You may have something blocking the air flow, food, plastic, etc... There should be a dial that opens, and closes the door.
Sep 01, 2009 | Amana Freezers
White Westinghouse upright freezer not cold enough.
Coils are probably underneath. remove the grille at the front (usually you just rotate it down to pull off) and then vaccum inside with a wand. If there aren't any coils there either, pull the machine out from the wall, and remove the lower panel from the back side. Inside you should find a fan next to a coil. Make sure that fan is working, and if it isn't make sure it is getting power.
Vacuum out as good as you can, and if you can use compressed air to blow it clean, even better (vacuum first because it will kick out a lot of dust).
If vacuuming the coils doesn't work, then you probably have a freon leakage problem, in which case it is probably not worth the cost of repair.
Mar 06, 2009 | Freezers
Got another question about a freezer
I have seen freezer stop working because the owner pulled it out to clean behind it and pushed it back into place too far. This "Chocked" the air flow around the condenser and caused the failure. Be sure condenser is clean and air can circulate. Older units have coils up the back and newer ones have them underneath and utilize a fan. You can use a vacuum on the the underneath ones. Be sure fan runs under there.
Jan 07, 2009 | Freezers
Fridge freezer
  • Check the temperature setting
  • Assure that there is enough room for air flow in the refrigerator or freezer
  • Check for air flow restrictions in vents
  • Test the temperature control
  • Clean the condensor coils
  • Check the door seals
  • Test the door switch
  • Test defrost heater
  • Test defrost timer
  • Test evaporator fan
  • Check for a clogged drain tube
  • Check for refrigerant leak
Sep 23, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Fan continuously running, non-stop
hi thanks for the question its normal for a frost free freezer to run a long time to keep a good cold temp i don't think you have a problem thanks the appliance doc
Sep 08, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Freezers Logo
145 people viewed this question
Top Whirlpool Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
