Question about Whirlpool CAM2752KQ Top Load Washer
No final extract spin
Coin operated top loader. all cycles function correctly, fill, agitate, drain, rinse with spin. but final extract spin does not happen (though final drain does). Also, of greater irritation, the problem appears to be intermittent and is not affected by type of wash (gentile, regular, etc). I have no Whirlpool repair information (only the useless installation manual). Help. Thanks
    President:
  • 878 Answers
P-bass, sounds like your problem is in the lid switch actuator that mounts to the bottome side of the top. I have found a bunch of these actuators just missing making the switch. Therefore the intermittent problem. Solution is to just bend it enough to insure making the switch on every closure. Catriver..post back.
Posted on Dec 01, 2006
SOURCE:
Serial # SD117482G
Most likely the control or timer. What is model #?
Nov 17, 2017 | GE WBSE3120B Top Load Washer
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
Whirlpool washing machine top loader will not rinse or do final spin
If your machine fills and agitates through the wash cycle and then stops, check the lid switch.
http://www.youtube.com/watch?v=bV8C6aLBL9w
Mar 03, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Have a circa 1999 Kenmore Three-speed clothes washer (Top Loader) that keeps on agitating regardless of the cycle I put it in. Some cycles do nothing at all, but others (such as Rinse) make it just keep...
The clutch assembly works only to release the basket allowing it to spin during the drain and spin cycles. The drain function works only when the spin function works. If the machine also agitates during spin cycles, then the problem is in the transmission assembly not able to release the agitate gear from the agitate spline in the drive shaft.
Sep 30, 2010 | Kenmore Washing Machines
Hi, our simpson enduro 701 washing machine does not spin back and forward in the deep rinse cycle. but operates ok and spins in spin cycle. thankyou Tina.
Hi Tina just read your posting. From the information in your posting the machine fills, then when the machine is full of water the agitator moves clockwise then anticlockwise until it gets to the rinse cycle then drains the water ,then it fills for the rinse cycle but does not move the agitator in the rinse cycle.Then it drains and spins the clothes dry .Is this assessment of your posting correct.If it is not 100% correct please reply to tell me what the machine is doing or not doing.If it is correct then the problem with your machine is the control board.Is your model the electronic one with the push buttons?Looking forward to your reply.
Jun 26, 2010 | Washing Machines
Top load washer won't go through cycle
modle problem here its the main board common fault with this model good luck
Mar 26, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing machine won't spin and drain
the drain pump is not working,after wash cycle the washer should drain the used water,if it does not function-all the next cycle will not commence.
Mar 19, 2010 | Washing Machines
Doesnt spin or drain
Sounds like its a pump problem if pump dosent work the rest of the cycle wont either maybe pump belt has come off or has broken hope this helps
Sep 06, 2009 | Kenmore Washing Machines
Washer won't drain or spin
top loader ??? or front loader??? if top loader you have broken your lid switch, will fill, agitate, but when it comes to drain/spin for safety reasons if the unit doent recognize the lid closed it will not advance...if yo have a front loader then i would suspect that something has gotten into the pump assy and preventing drainiing of water therefore will not spin
Mar 02, 2009 | Kenmore Washing Machines
Whirlpool CAM2752KQ Top Load Washer Logo
154 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
