Question about Pioneer DEH-1700 CD Player
Blinker flasher problem
This is driving me insane...for some reason my blinker system is making that clicking sound continueosly....whats weird is that the left and right signal lights work fine but there after the clicking continues...sigh...what could be the problem?
  • 3 Answers
Theres a fuse in the fuse box it might help to change it i would look like a round metal peace so try that
Posted on Feb 24, 2009
Need a diagram for how to find the flasher in a 1999 dodge stratus..it's not in the fuse boxes
Simple method without mystery:
  1. Turn blinker flashers on;
  2. Listen for clicking;
  3. Find source of clicking. It is the flasher. :)
NOTE: Emergency flashers and blinkers usually use a separate flasher unit, but one is close to the other. If your blinkers do not work but your emergency flashers do, find the emergency flasher unit by finding the source of clicking, then locate the blinker flasher nearby. They will ALWAYS be underneath the dashboard on the driver side.
May 11, 2015 | 1999 Dodge Stratus
2001 alero contstant turning signal sound
check all your exterior lightbulbs; the signal circuit is balanced
if a lamp is shorted in the signal circuit the flasher will buzz instead of click
Nov 06, 2017 | Cars & Trucks
The blinker in my 2002 Chevy Malibu won't stop making the blinker noise...even when the blinker isn't turned on. Driving me insane!
the blinker control under and to the right of the steering column under the knee panel is out its a cheep part you remove the knee panel an turn on the turn signals listen for the ticking you find that part unplug it and replace it yours is bad worn contacts this is a cheap part easy to fix don't let people rip you off good day
Feb 15, 2013 | 2002 Chevrolet Malibu
I have a 2000 Dodge Durango and we have been having blinker problems too lately. Sometimes they worked, sometimes they didnt, and the other day they went out completely.They have been doing this for a...
that vehicle has a desperate relay for the hazards which is why they work, you have a defective signal flasher sometimes called a signal relay, follow the noise to locate exactly where the part is, usually under driver side of dash, it is a very cheap part and easy to install.
Sep 26, 2011 | 2000 Dodge Durango
The blinkers only work some of the time. All bulbs are good and the emergency flashers work. I found the flasher for the blinkers, but if it is bad, will the blinkers work some of the time and other times...
you need a signal flasher to correct the problem.flashers will act this way some times when they have an internal problem with the bi-metallic strip that actually completes the circuit and makes the clicking sound.make sure you have found the signal flasher and not the hazard flasher as they look the same.with the hazard flashers on you can see what the signal flasher will look like and it is in the fuse panel.
Mar 25, 2011 | 1987 Ford Taurus
I have replaced the flasher fuse located under the dash left side. I still have the clicking noise and the blinkers still dont work. Any ideas?
The problem might be the column mounted turn signal switch, in which the contacts do eventually wear out, causing some weird problems and clicking sounds from the car. Have it inspected to see if it is bad and replace it if necessary.
Oct 21, 2010 | 1992 Honda Accord
The blinker clicking sound won't stop when blinkers are off
Hello, you need to replace the flasher. It is located under the dash on the driver's side near the top of the brake pedal.
Thanks for using FixYa!
Feb 01, 2010 | 2004 Pontiac Grand Am
Chicking noise on pontiac.
You'll have to replace the blinker arm assembly. I had the same issue with my '99 GT. It turned out that a couple of the electrical traces had arced and fused together. You might be able to fix it yourself if you're electricly inclined. Otherwise it's only a couple of screws to pull off the top cover and then another for the blinker/wiper arm assembly.
Sep 10, 2009 | 1999 Pontiac Grand Am GT
Buzzing Sound Coming From right side of dash
you need a new flasher.. get under there or read the book and find where it is and replace it..
May 14, 2009 | 1994 Oldsmobile 88
"97 T-Bird...blinkers stop & start
it sounds like you need to replace the flasher unit under the drivers side dash
May 08, 2009 | 1997 Ford Thunderbird LX
Pioneer DEH-1700 CD Player Logo
42 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
