SOURCE: my banshee wont shift past 2 gear
You have a bent shift fork. The repair means taking the engine out of the frame then removing the top end, removing the flywheel and electrics, removing the clutch , shift mechanism and kick starter and a few other parts. THEN you are ready to split the gearbox to remove the gears and crankshaft and then the shift drum and bent shift fork. Next you get to put it all back together. This is a pretty big job for the home mechanic.
You will need an impact driver, flywheel puller, case splitter and torque wrench plus the normal screwdriver, pliers, etc.. Alternate to the special tools is taking it to the dealer and say "Fix it".
I normally tell people to take it to the shop just so they don't get into such an involved project.
Free service manual PDF download at > http://www.carlsalter.com/motorcycle-manuals.asp
Please rate this solution. Thanks!
SOURCE: Shift lever will not return after shifting gears.
It most likely is the shift return spring.
SOURCE: TS-250 Suziki Savage 1969 Shift rod moves in
If the shift pedal shaft does not spring back into position a problem with a spring is indicated. Your bike has two springs tied to shifting. The shaft spring and the index wheel spring. Both springs are still available at Babbitt's. Remove the left case cover and both springs are accessible after removing the clutch. A new gasket is also available.
Please rate this answer. Thanks!.
Go to the site below where you can see a parts diagram for your specific bike. You will select the actual brand, year, model, etc., once you go to the site. Part numbers and prices are also shown. You can order parts from this site. In the event no price is shown on a particular part and/or the notation "Not Available" is in the description, the part is not in stock. www.babbittsonline.com/pages/parts/viewbybrandand/parts.aspx
Testimonial: "Thanks for your help, this info has helped immensely."
SOURCE: When I shift my 02 GSXR 600 the gear shift lever gets stuck
Get yourself a repair manual and find out what it says, but I think you are correct, the return spring is either broken or it has slipped. Try this site for a freebie manual:
SOURCE: Dirt Bike Shifting gears problem(1972 yamaha dt 250 2stroke)
it will be down to adjustment, there are 2 ways to adjust one close to the engine casing and one at the lever just have to get a good balance :)
Testimonial: "Exactly what i needed to know thankyou!"
