Question about Garden
HOW TO INSTALL A NEW CHAIN ON POULAN 16'' BLACKHAWK CHAINSAW
2004 POULAN 16'' BLACKHAWK CHAINSAW 36cc engine chain replacement procedure.
  • Anonymous Mar 12, 2014
    poulan model pp4218A chainsaw was running fine, cutting thru a mulberry tree about 35" across and after about 5 min the engine started running as though the chain was binding so I turned off the engine an withdrew it from the tree and allowed it to cool before trying to start again. The rope would pull out about 8" and then stop as though the engine is seized. this saw was a reconditioned one and I ran it long enough to have to replace the chain and then 5 min. after the new chain was installed this problem occurred. Is it possible that the starter id jammed or is the engine seized up?
  • 211 Answers
Hi likniz
unlock the lock nuts,take off the chain cover,change the chain,adjust the screw tightening chain,back the cover and the lock nuts.
best wishes savumihai71
Posted on Dec 02, 2008
Will a Poulan 16 " chainsaw gear fit a poulan 18 " chainsaw?
If you mean the drive gear on the end of the shaft, the answer should be yes. The radius for the drive gear does not change as the bar and chain length increase (within a few inches of bar and chain length). The determining factor for a larger bar and chain, in any chainsaw model, is the hp of the engine.
Oct 23, 2015 | Poulan Garden
What size of chainsaw file do I need for poulan pro PP4620AVX
hi there susan brown6
if your chain is a 3/8 lo pro chain the file will be 5/32nd ------- and if its a 0.325 size use a 3/16th file -------- or if its a 3/8 -0.58 chain use a 7/32nd file
but its more likly to be either 5/32nd( for 3/8 low pro chain ) or 3/16 th for .325 chain
cheers
pauly46
Sep 10, 2011 | Poulan Pro PP4620AVX 46cc Gas Chainsaw...
Cannot get chain back on bar of poulan pro electric chainsaw model 1630
Slide the bar on the studs all the way to the left, or rear of the chainsaw, and feed the chain around the motor sprocket, THEN along the top of the bar to the right, and around the bar's sprocket at the right end of the bar, if this doesn't work, report back. This is the original bar and chain correct?
Nov 21, 2010 | Poulan 1630 16" Chain Saw
Remove chain guard
The OM for your saw is is the best guide. You can download a replacement here (disengage the chain brake first - pull handle aft):
Poulan.com/CurrentModels
http://www.poulanpro.com/node4043.aspx
Type just the model numbers (choose the suffix after the list is provided).
A broad adjustment procedure can be found here. Completely remove the bar cover, slide the bar against the drive sprocket, remove the chain from the bar.
http://www.fixya.com/support/r4146814-chainsaw_chain_installation
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 10, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
I have a 16 inch gas poulan chainsaw. I can't
Hi Speed circuit clogged in Carb.
Remove clean and soak blow out jet, Replace spark plug.
Also verfi Oil mix, add a fuel stabiliser if using fuel with ethanol.
Hope this tip helps.
R/
David
Jan 27, 2010 | Poulan 1630 16" Chain Saw
Poulan Pro 42cc Just Won't Cut It
The chain is directional, only cuts one way. If a new chain won't cut, it must be on backwards.
Apr 27, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Chain slips off bar
I would suggest adjusting the tension and cleaning and debris along the chain path (guide bar).
Here's the manual for Poulan PP4218AV =>
http://72.3.225.179/manuals/165555e.pdf
Look at page 6-7 for instructions to adjust the chain tension and page 16 for cleaning the guide bar.
Here's the link to other Poulan Products =>
http://www.poulanpro.com/poulanpro/manualSearchPrepare.do
Jan 03, 2009 | Poulan PP4218AV 18" Chain Saw
Poulan Farmhand chainsaw chain tightens too tight for motor to move chain
Make sure the chain is not over tightened. When adjusting the tightness, ensure there is at least 1/8" of looseness by pulling up on the chain in the middle of the bar and releasing it. If a chain becomes overheated because of leaning on the saw when the chain is dull, or lack of oil on the chain, it may expand in the track and not turn freely.
Marlyn, Mountain, Ont. Canada
Oct 02, 2008 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Garden Logo
1,624 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
