Question about Blodgett (ZEPHAIREG-DOUB) Double Oven
1860 s The oven will drop 60 to 80 degrees when pizza goes through and it takes over an hour to heat up when I first turn it on for the day
    Scholar:
  • 181 Answers
Check out the temrature settings. if its proper then it could be the magnetron gone faulty.
Posted on Nov 16, 2008
  • 6 more comments
  • fixyy Nov 16, 2008
    Q - My microwave seems to shut off every once in a while, what might be wrong?
    A - Make sure you hear the fan is still operating in your microwave. Next is to make sure the air intake grill on your microwave is not plugged up with air borne dust and dirt.
    Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
    A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
    Q - My microwave is running and sounds like it is working but will not heat up anything.
    A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
    Q - The microwave display counts down and the inside light is on,  but nothing is heating and the fan is not running.
    A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
    Q - The fan in my microwave oven is not running will this hurt my microwave?
    A - YES, the fan cools the magnetron and electronics, take the microwave in for service, most fans are not too expensive to replace.
    Q - My microwave blows the fuse inside itself as soon as I push the start button.
    A - Usually a shorted high voltage capacitor...see components section.
    Q - I burnt something in my microwave and now it is dead...help!
    A - The fuse inside the microwave may have blown, but more commonly the flame/oven thermostat has sensed the over cooked food and the flame/oven/cavity thermostat has opened up - Info on that
    rate the solution if it helps u.
    feel free for further assistance.
    thanks.
Gas Pizza Oven - Heat issues
Many of the Pizza ovens require ceramic plates that line the bottom surface of each oven. These ceramic plates absorb the heat and retain the temperature. I never used our ovens with a bare lower surface, always applied the plates for even heat and distribution.
Mar 05, 2014 | Ovens
How do I start the oven? I want to cook a pizza
Open the oven and make sure it is empty nod one rack is near the middle level. Turn the knob that says OFF to BAKE. Then turn the knob with all the numbers to the temperature that Theo Sri toons on the box tell you to use. Allow the oven to heat up for 10 minutes. It may beep when it is up to temp or a red light will turn off to let you know it is ready. Put the pizza in the oven on middle rack. Take it out according to box instructions ( usually 8 to 15 minutes). That pizza out by sliding it onto a plate. Turn off the oven and eat the pizza. If it is not done completely, leave it in longer next time. Enjoy
Jul 08, 2011 | Ovens
We purchased our Frigidare Double Oven, Model Number FPET3085KFA, October 2009 (15 months ago). We ran the self-clean process for the first time yesterday on the top oven using the 4 hr option and it...
try turning your breaker off for 20 minutes, then try it again,, if this does not help it could have burnt out a element or the main board has went out,,, also make for sere you are getting the full 220 volts to the unit,, this will involve taking the unit out
Jan 19, 2011 | Frigidaire 30 in. Electric Gallery Series...
Why does food get hard after cooking or reheating in a microwave
It's basically a loss of moisture during the cooking process, to avoid this in a standard oven cook on a lower temp for longer and cover with foil....in the microwave, drop the power setting and always reheat or cook with the food cover with a microwave safe cling wrap or microwave specific cookware with lids.
Hope this helps.
Sep 08, 2010 | Whirlpool Ovens
MY OVEN wont heat up. its takes at least an hour
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 28, 2010 | Ovens
Model GBS307PDQ5: Oven preheated to 425 degrees.
F3 usually means, that the oven temp. sensor is bad and one need to replace it.
The fact, that it's not heating tells me, the fuse in the back also needs to be replaced (requires pulling out).
Whirlpool oven repair orange county, ca
Feb 06, 2010 | Ovens
I tried to cook a frozen pizza in my Tappan electric range last night (which required it to be preheated to 400 degrees) and it would not preheat at all, even after about a 3 hour wait. I just turned up...
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5153992&diagram_id=1251523#d1251523
your looking for part number 67 on that part breakdown
it is the bake element and if you inspect it im sure you will find it cooked or broken
befor you actually order the part take the unit out
unplug it
and inspect your wire connections to both sides of the element
Oct 17, 2009 | Tappan 30IN ELEC IGNa Oven
Hi. I have a ge convection oven(JCTP17) that has been working great until recently. I bought a Taylor oven thermometer model number (503) To check othe oven temps to see how accurate the oven is. I do a...
The Taylor oven thermometer you bought is decent at best. It is most likely the sensor inside the oven. Has your clock displayed any fault codes? F, followed by a number? Changing the sensor will probably correct the problem.
Aug 19, 2009 | Ovens
KitchenAid Oven Temp.- Bottomside of Pizza or Cake stays uncooked
I have a 2yo Kitchenaid oven, and my advice is first, don't use convection for cakes or pizza. Use the thermal oven. For pizza preheat to 500 degrees, then put the pizza on the lowest rack, and bake for 7-8 minutes.This way the bottom browns, and the top doesn't get broiled from the top element coming on during the bake cycle.
As for cakes, again place them on the low rack so that they get bottom heat. I keep my eye on the oven and when the broil element comes on I stick a piece of foil over the cake until it goes off. Otherwise it will set the top and the cake won't rise as much. Even doing that cakes don't rise as much as they did in my old oven, and they brown too much on top.
The convection oven does a good job of cookies, and the broil mode is okay.
I wish I hadn't bought this oven, but I didn't know about the upper (broil) element coming on during the bake cycle until I'd had it for awhile, and it was too late to return it.
If anyone's shopping for an oven, ask questions, and don't get one that maintains the oven temperature by activating the broil element when baking.
Jun 24, 2009 | KitchenAid Architect ® II KEBS208S...
Blodgett 1860s Pizza Oven
the fan motor is faulty or the fan is faulty.and it needs replacement. this is very rare that sometimes the the dust particles are got stuck up in the fan and it cannot move so cleaning it helps. also if every thing seems perfect then loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
rate the solution if it helps.feel free for further instructions. thanks.
Nov 16, 2008 | Ovens
Blodgett (ZEPHAIREG-DOUB) Double Oven Logo
29 people viewed this question
Top Blodgett Ovens Experts
Dennis Boxerman
Marvin
Marvin
Are you a Blodgett Oven Expert? Answer questions, earn points and help others
