Question about Ozaki DT-500 3-Piece Speaker System w/Subwoofer&Wired Remote (Silver) Computer Speakers
I pluged in my speakers but the sounds are very low and wierd
The volume is up and the speakers are new.I just dont know how to ajust the sounds right they sound like an echo.
You cant get echo on a specker there not made for that just normal sound
Posted on Mar 25, 2009
NSM Digital Thunder CD Jukebox speakers on right side do not have sound
make sure speaker wires are all pluged in. if that dont wort check the speaker wire it my be broke in between speaker and player, try new wire
Jul 16, 2012 | Audio Players & Recorders
Everything is pluged in correctly. And when i go to the control panel> Sounds, speech, and audio devices> sounds and audio devices> volume, it says that their pluged in and work, but i dont here...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps you
Aug 16, 2011 | Dell A215 Computer Speakers
It says its not pluged in but it is
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
dont forget to vote
hope this helps
Feb 02, 2011 | Logitech Z4 Speakers
LAPTOP IS MAKING WIERD SOUNDS OUT OF THE SPEAKER
dear sir,
this types of problem come from the sound section of the laptop motherboard. your laptop contains sterio sound system. problem is one channel of the sound circuit faulty. but it is too dificult to repare it.
u can do one think, u can stop one channel sound by using sound balancing option from the task bar volume control option.
also u can contact with Acer service centre.
Nov 09, 2009 | Acer Aspire 5602WLMI Notebook
I have a panosonic surround sound system and a toshiba 60" tv and when watching tv speakers have a humming sound , but when watching a dvd speakers are fine and no humming sound.what is the problem? Tv...
it depends on what volume level the tv is on
if the level of volume is low and making the sound then try unpluging or pluging in the sound system to the tv
Sep 13, 2009 | Televison & Video
Low sound
are you trying to use speakers that require amplification?
try pluging headphones to the sound port and if they sound good you are using the wrong kind of speakers.
Jun 29, 2009 | ASUS A8N-SLI Motherboard
Bloom speakers only emit very low sound after being connected
well i dont know what to do except turn your volume on really high and make sure its plugged in. no they dont need batteries; i got mine today and its not that quiet its blue and i think its okay. but i dont know if its that bad you should return it. mine was only 7 bucks
Mar 22, 2009 | Macally iWave Computer Speakers
My speaker are very low, can't ajust, and have a roar. coming from both speaker.
adjust the sound effect, make the bass low.... if your using wmp, you can adjust this in the mixer or equalizer..... please rate my solution
Oct 27, 2008 | Acer Aopen MS698 Computer Speakers
My computers sound not working.
try new sound drivers for your model pc ok
Feb 07, 2008 | Dell A215 Computer Speakers
143 people viewed this question
Top Ozaki Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Ozaki Audio Player and Recorder Expert? Answer questions, earn points and help others
