Question about Lenovo 3000 Y410 Notebook
My blooth is not working
Its folder could not open&when i press the right click button on bluetooth icon then send file,receive file etc. not appear
    Sergeant:
  • 237 Answers
Can you do this for me: Go to Control Panel, go to remove and add hardware, and check to see if Bluetooth is in your program. If it is not, you will have to pull out your windows xp/vista and reinstall the bluetooth program.
Posted on Nov 20, 2008
I really don't have a problem, I would like to know how to scan photos into my computer and them send them in an email. Could you explain it to me so I can understand it. As you can guess, I'm a...
Hey Helen,
This can be hard or easy depending on which softwre your printer/scanner has loaded.
Firstly, install the software that came with your printer scanner.
Once thats done, you should be able to access the scanners functions either through an icon in the taskbar (bottom right corner of your screen) or by pressing the scan button on the printer.
Once the scanner starts up, it should ask if you want to save the scanned image to your PC or, in some cases, email the image.
Save the image into your "my documents" folder so you can find them later and give the file a name that you can easily associate with the image (like my daughter etc)..
Scanning to email will usually start up outlook or outlook express which is no good if you do not use outlook and use a third party email system like hotmail etc.
So, shut down outlook in this case. otherwise, setup your email as you normally would (receivers email address, subject etc)..
If you use hotmail etc, the procedure is about the same..
Once you are ready to attach the image from your scanner, click on "attach" and select file.
In the dialog box that opens, select browse and navigate to your "my documents " folder if it is not already in that folder. Select the file you scanned and named earlier and click on open or attach.
The file will then upload and appear in the list of attachments once uploading is complete.
Click on send and off it goes..
Jan 24, 2011 | HP Office Equipment & Supplies
Tip
How to turn Bluetooth on and off on a BlackBerry Tour
The BlackBerry Tour comes with Bluetooth capability, but in order to connect to a Bluetooth device, you have to enable the Bluetooth functionality. When you're not using a Bluetooth connection, disable Bluetooth to avoid other devices from connecting to your BlackBerry.
- To turn Bluetooth on:
From the main home screen, press the BlackBerry button (to the left of the trackball) to go to your Home folder. Scroll down until you see the antenna icon for Manage Connections and click on it. A pop up list will appear; find Bluetooth on the list and click it to put a check in the box next to it. "On" will appear next to Bluetooth, and the Bluetooth icon will be displayed in the upper right corner of the screen. Your BlackBerry is now in Bluetooth mode, where it can connect and pair with other Bluetooth-capable devices.
Bluetooth can also be turned on from the Options folder, under the Home folder. Select Bluetooth from the list and when the screen comes up saying "Bluetooth: Disabled," press the BlackBerry button and then select Enable Bluetooth. If you've previously paired your Tour with other Bluetooth devices, the list of those devices will appear.
- To turn Bluetooth off:
From the home screen, press the BlackBerry button. Scroll down to Manage Connections and select it. In the list that appears, click Bluetooth to uncheck it and disable Bluetooth functionality.
You can also turn Bluetooth off by clicking Options in the Home folder, selecting Bluetooth from the list of options, then pressing the BlackBerry button and choosing Disable Bluetooth.
on Jan 14, 2011 | RIM BlackBerry? Tour 9630 Smartphone
I cannot send pictures from my blackberry storm,
You receive a Failed to Find Service message when you attempt to transfer a media file between two BlackBerry Pearl smartphones.
The BlackBerry Pearl smartphone receiving the media file is not properly configured.
To send and receive files between two BlackBerry smartphones using Bluetooth® wireless technology, complete the following steps:
  1. Enable Bluetooth technology on the BlackBerry smartphones. For instructions, see the Turn on Bluetooth technology section of the BlackBerry User Guide.
  2. Make the BlackBerry smartphones discoverable. For instructions, see the Make your BlackBerry device discoverable section of the BlackBerry User Guide.
  3. Pair the BlackBerry smartphones. For instructions, see the Pair with a Bluetooth enabled device section of the BlackBerry User Guide.
  4. Set the Trusted field to Yes on both BlackBerry smartphones by completing the following steps:
    1. In the Bluetooth application, highlight the BlackBerry smartphone and press the Menu button.
    2. Select Device Properties.
    3. Set the Trusted field to Yes.
    4. Press the Menu button and select Save.
  5. Send and receive the transfered file.
On the recipient's BlackBerry smartphone
  1. On the Home screen of the BlackBerry smartphone, select Media.
  2. Select a media type (Music, Video, Ring Tones, Pictures).
  3. Press the Menu button and select Receive using Bluetooth. The File Transfer dialog box appears, followed by a prompt to Save or Cancel the file.
  4. Select Save to save the file to the current location, or select the folder icon to save the file in a different location.
On the sender's BlackBerry smartphone
  2. Select the same media type selected on the recipient's BlackBerry smartphone.
  3. Press the Menu button and select Send Using Bluetooth.
  4. When prompted to select a BlackBerry smartphone, select the recipient's BlackBerry smartphone.
Nov 02, 2009 | RIM BlackBerry Storm 9530 Smartphone
How do you print a fax report? HELP! URGENT!
1 Press the FAX button, then press the Menu button.
2 Press the < or > button to select PRNT REPORT/LIST, then press the OK button.
3 Press the < or > button to select ACTIVITY REPORT, then press the OK button.
The Activity report is printed.
Oct 31, 2009 | Canon PIXMA MX310 All-In-One Printer
Laptop will not discover bluetooth devices
just make the blue tooth visible like on the phone
Apr 14, 2017 | Nokia Mini USB Bluetooth Dongle w/...
I can not receive incomming blue tooth on my blackberry 9500
from :http://www.blackberry.com/btsc/search.do?cmd=displayKC&docType=kc&externalId=KB05409
chathudagr8@yahoo.com
Aug 27, 2009 | RIM BlackBerry Storm 9530 Smartphone
Problem with Bluetooth Transfer
There is one easy solution for the second question: You can set your SGH-L700 to store your photos and/or videos on your memory card. Just go to Settings -> Application Settings -> Camera Settings. Go to the rightmost section using arrow keys and change camera's default storing location as memory card, instead of phone.
The bluetooth problem is not that easy. There is one solution if you send the files from your PC. Just browse your "Bluetooth Devices" from your desktop - your SGH-L700 will appear as an independent device. Double click it's icon, you'll see the folders in it, just like you're browsing your computer's hard drive. Open "Memory Card" folder then drag and drop the files you want directly inside it. I almost always prefer this way when I use bluetooth transfer.
If you try right clicking on a file on your PC and choose "Send via Bluetooth" from the context menu, SGH-L700 receives it directly to the phone memory. So I recommend using "Bluetooth devices" option and placing the stuff directly in the memory card, just like you copy items in any place on your hard drive.
But there is not a standart solution for sending a file from another cell phone to SGH-L700. Some devices can browse SGH-L700's folders like your PC does, but some of them can't - and they just send the files to the phone memory.
Feb 05, 2009 | Samsung SGH-L700 Cell Phone
My desktop shortcuts open with search results page only
1.
Right-click Start, and then click Explore.
2.
Locate the folder, file, or program in the Folders directory, and then click the item to open it.
3.
Click the icon representing the item.
4.
Click File on the toolbar, and then Create Shortcut on the drop-down menu that appears.
5.
Right-click on the shortcut icon that is created.
6.
Choose Send To from the drop-down menu, and then click Desktop (create shortcut) on the submenu that appears.
Jan 09, 2009 | Acer Aspire™ T180 PC Desktop
My laptop is asking me some driver to install
  1. Save any work open and close all programs.
  2. Browse to support.dell.com.
  3. Click new%20support%20button%20left.jpg I'm looking for drivers and downloads new%20support%20button%20right.jpg.
  4. Under Choose by Service Tag click green_button_left.gif Enter a Tag green_button_right.gif, then type in the computer's Service Tag number, click Go in the green oval support%20site%20go%20icon.jpg.
    • When the default values are not correct, click the drowpdownarrow.jpg to the right of Operating System or Driver Language and select the desired value.
  5. Click the drowpdownarrow.jpg to the right of Category, then click Network in the list of categories that appears.
  6. Click rightarrow.gifDownload Now to the right of Wireless Internal Bluetooth® Module.
  7. In the File Download - Security Warning window, click Save.
    • Write down the filename, it will be needed later.
  8. Click Desktop on the left under the navigation bar of the Save As window, then click Save.
    • It may be necessary to click Browse Folders to expand the list of options.
  9. In the Download Complete window, click Close.
  10. Click the Start pearl.bmp button.
  11. Click the arrow vista_restart_arrow.jpg to the right of the lock vista_lock.jpg icon.
  12. Select Shut down.
  13. Wait 10 seconds after the computer shuts down, then press the <Power> button.
  14. Once the computer has reached the Desktop, double-click the file previously downloaded.
    • The Open File - Security Warning window may appear. If so, click Run.
    • The User Account Control window may appear. If so, click Allow or Continue.
  15. In the Network: window, click Continue.
  16. In the Select the folder where you want to unzip the files to window, click OK.
  17. In the Folder does not exist. Do you want to create it? window, click YES.
    • When the message appears asking to overwrite the folder, click Yes to All.
  18. In the All files were successfully unzipped window, click OK.
    The Preparing to Install the Vista Bluetooth Profile Pack screen appears and closes.
  19. In the Vista Profile Pack Bluetooth InstallShield Wizard Welcome window, click Next.
  20. In the Ready to Install the Bluetooth Profile Pack window, click Install.
    The Installing the Vista Bluetooth Profile Pack screen appears and closes.
  21. In the One Click Download Firmware Upgrade window, click OK.
    • A message to plug the computer in to A/C power may appear. If so, provide the computer with A/C power before proceeding.
    The Dell Bluetooth module's firmware is updated and the installation of the Vista Bluetooth Profile Pack continues.
  22. In the Vista Bluetooth Profile Pack InstallShield Wizard Completed window, click Finish.
  23. In the Vista Profile Pack Installer Information window, click Yes.
    The computer restarts.
this would work for dell 1525 with vista and xp please note that the perihepral device is nothing but the device which you are connecting, will have its own device please check you must have a driver in the manual or it would already be installed in device as soon as you connect it should work after this steps
Aug 14, 2008 | Dell Inspiron 1501 Notebook
Lenovo 3000 Y410 Notebook Logo
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
