Question about Jenn-Air Kitchen Ranges
I will like to do a full service on my Jenn Air gas slding range JGS8850AWD such as replacing all the bunnerseals, ignitors ect.
  • 116 Answers
You can find all the stuff you need online at www.repairclinic.com
Regards
Posted on Nov 16, 2008
Jenn-Air dual fuel ignitor problems
Replace the igniter on each one and you should be ok.
Oct 20, 2011 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
When i try to bake on my jenn air we have no flame on lower gas tube. But starter element is glowing red .No gas getting to gas tube?
If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
Jul 06, 2010 | Jenn-Air JGR8850 Gas Kitchen Range
My gas bake burner won't ignite.The igniter is on.Gas Range Jenn-Air model#JGS885OADW
If the bake ignitor comes on - check the amperage on the bake ignitor wires when it's on. Amperage should be 3 - 3.6A. If less than 3A - replace ignitor.
Ignitor part numbers (any will do, but the first one is a direct replacement): 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
All those are interchangeable, if you can splice the wires.
Apr 03, 2010 | Jenn-Air JGR8850 Gas Kitchen Range
Gas oven doesn't work. Broiler does.
Hello - Most likely failed lower burner ignitor. Tests good if above 4ohms. Part is 40$. Can give replacement instructions if needed. Let me know if this helps. Thanks. -ED
Mar 03, 2010 | Jenn-Air JGR8875QDS Gas Kitchen Range
Bake only heats to 75
you have a bad ignitor on the bake side
take out the racks
take out the bottom pan
you should see the ignitor
tun on the range and watch the ignitor
if its only orange and notr glowing white
it wont open your gas vaslve
asnd need to be replaced
Oct 07, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Jenn air gas range ignitors won't light
My jennair gas range ignitors will not light. Any suggestions?
May 05, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Problem with getting burner to light.
All my ignitors spark when I turn one of them on. I'v been told it is normal. I had a problem before and the tech that replace the ignitor said the issues is with alignment. Try to rotate the burner a bit left or right and see if it fixes it.
Aug 26, 2008 | Jenn-Air JGS8850BDS Stainless steel Gas...
Jenn-aire gas stove
  If this is a gas range your problem is most likely your oven ignitor.  As they get older they get weak and takes longer to open gas valve.  Eventually it won't come on at all.  Replacing the oven ignitor will often take care of problem.  BE SURE TO UNPLUG UNIT BEFORE REPAIR!!
  Remove oven floor.  The ignitor is in a cage attached to back of oven burner.  It mounts with 2 screws.  You may have to cut wires and wirenut in replacement.  Doesn't matter if the 2 wires are reversed.
Oct 24, 2007 | Jenn-Air JGR8850 Gas Kitchen Range
Open Questions:
Kitchen Ranges Logo
53 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
