Question about Humminbird NS25 GPS Receiver
NS25 Screen gone
On my NS25 is suddenly an about 5 cm long and 4 cm high white stain, i.e. in this area is nothing readable any more. Does anybody know where to buy the Sharp LM32K072 screen to replace the spoilt item? I'm concerned to change the system as I am quite happy with the C-Map for the Singapore water area and would not like to redo the complete installation + map purchase because of this. Thanks in advance Al
White vertical band in Cyan and Black
try to clean the laserwindows of the printer.
Mar 25, 2013 | Xerox Phaser 6125 Laser Printer
Tip
How to get almost ANY stain out of carpet! WITH ONLY WATER
This is a super simple way to get just about any kind of stain out of carpet, I used it on a grape jelly stain that was about a day old, and it worked.
STEP 1:
Fill a bowl with at least 5 times the amount of whatever caused the stain.
STEP 2. (optional)
put a little bit of laundry soap in the water, swish it around.
STEP 3.
Dump the water onto the stain, DON'T RUB IT IN!!
STEP 4.
Soak up the water with a towel, paper towels, whatevers handy, blot it, but don't rub it in--the rubbing or scrubbing you usually associate with getting out stains is what smears the stain cause into the carpet, or fabric fibers. It's important to not let the spill get "enmeshed" into the fibers, the water sort of will lift the spill off of the area.
STEP 5
Repeat steps 3 and 4 until spill is gone.
on May 18, 2010 | Cosco Juvenile Scenera Convertible Car...
WHITE LINES THROUGH SCREEN AND NO SYTEM PREFERENCES
White lines is either the screen or more likely the graphics chip. try a reinstall see if that fixes it.
Dec 27, 2011 | Computers & Internet
Large yellow stain / tint / spot when showing bright or white background
The problem is called pixel re-stain, it usually happens on some old LCD panels, in your case, the TV is not worth to fix.
Apr 20, 2017 | Sony Bravia KDL-46Z4100 46 in. LCD HDTV
Surface area of a rectangular prism whose length is 7 cm.,width is 4 cm., and thickness is 5 cm.?
Since the 'base' and 'top' of any prism have the same shape, the surface area can be found by
  • surface area of prism = 2 * area of base + perimeter of base * H
So for the rectangular prism in your example..
  • surface area = 2LW + 2(L+W)H
  • = 2 * 7 * 4 + 2*(7+4)*5
  • = 56 + 2 * 11 * 5
  • = 56 +110
  • = 166 sq cm
Hope this helps
Sep 05, 2011 | Encore Math Advantage Algebra II and...
How would you represent the area of the base of the box?
The total surface area is made up of three pairs of sides for a total of six sides.
We must find Areahw, which is the area of the side that is h by w.
Areahw = (h)(w)
We must find Areahl, which is the area of the side that is h by l.
Areahl = (h)(l)
We must find Areawl, which is the area of the side that is w by l.
Areawl = (w)(l)
Each of the above areas are present on two sides of the box. So, the total surface area is sum of twice each of these areas, that is:
Total Surface Area = 2(Areahw) + 2(Areahl) + 2(Areawl)
Example:
Let h = 3 cm, w = 5 cm, l = 8 cm
Areahw = (h)(w) = (3 cm)(5 cm) = 15 cm2
Areahl = (h)(l) = (3 cm)(8 cm) = 24 cm2
Areawl = (w)(l) = (5 cm)(8 cm) = 40 cm2
Total Surface Area = 2(15 cm2) + 2(24 cm2) + 2(40 cm2)
Total Surface Area = 30 cm2 + 48 cm2 + 80 cm2
Total Surface Area = 158 cm2
Aug 04, 2011 | Computers & Internet
I have a white B&D toaster oven. Something burned in the oven and the smoke came out the door and scorched the white part above the door. What's a good way to get rid of the stain.
you need to sand that stain down with sandpaper and then re-paint the area with a high temperature paint......hardware stores should sell it....it's trade name is called...."mr. touch up"......it is speciffically made for microwave ovens but is also very good for your oven.....the paint must be high temperature type since your oven is high temperature.....good luck
Dec 04, 2010 | Black & Decker Vacuums
Hello I have got suddenly a white screen after starting the 5 year old Dell inspiron 1300. In the background the typicall sound of the Windows XP startprocedure can be heard, but I dont get any readable...
Hi holm_fischer,
White screen often caused by a defective screen. The easiest way to determine if you have a hardware or software problem is by performing a power drain. Please follow the steps below for additional instructions.
Power Drain:
1. Turn off the computer.
2. Unplug the AC adapter from the power outlet and take out the battery from the system.
3. Now, press the power button for about 15-20 seconds.
4. Put back the battery in and plug the AC adapter.
5. Turn on the system and try observing it.
--> If power drain did not work, you need to consult a repairman to have your screen be checked for possible damage.
Hope it helps.
Thank you for using FixYa.
Nov 28, 2010 | Dell Inspiron 1300 Notebook
Can you gave me a example of a right triangle problems?
In right triangle we are making 90 degree angle triangle, we can have problem for finding hypotenuse or finding sin or cos values of the side of the triangle. For ex,Find out the hypotenuse,sin and cos value of the right triangle with base 4 cm and perpendicular 3 cm Solution:Hypotenuse = SQRT(4^2 + 3^2) =SQRT(4*4 + 3*3) =SQRT(16+9)=SQRT(25)=5 cm For right triangle, sin(x)=3/5=0.6 cos(x)=4/5 =0.8
Jul 16, 2010 | Super Tutor Trigonometry (ESDTRIG) for PC
Gps ns25
The wiring within the Screen unit seems to be very poorly done, there are 4 cables to the GPS side of things and these can contact each other as there is a portion of the wire where it enters the connector that is bare, and if these touch one another then you will get nothing.
Dismantle the head unit and check the cables, i would be inclined to shrink wrap the bare portion of each cable.
Hope that this helps, it might not be the answer, but it is worth checking.
adrian.
Aug 07, 2008 | Humminbird NS25 GPS Receiver
Humminbird NS25 GPS Receiver Logo
Top Humminbird GPS Experts
Jerry Greenberg
Jerry Greenberg
Steve
Steve
Marvin
Marvin
Are you a Humminbird GPS Expert? Answer questions, earn points and help others
