Question about AT&T Sony Ericsson W580i Cell Phone - White
Phone gets stuck
I try to open it but it only goes about 1/3 and then it gets stuck you play with it a little bit and then it opens then it gets stuck and wont close you play with it again and THEN it closes please HELP!!!
    An expert whose answer gotĀ voted for 100 times.
  • 98 Answers
Well I had a problem not remotely similar to this one... but I might be able to help. So what you want to do is....... Go to this site..
Once you get to the LCD screen you should be able to see the spring. Try messing with it.
Posted on Nov 17, 2008
I have a jerking motion on my 1996 silverado C1500vortec4.3 when I get to 50 miles per hour what could be the problem?
If your crusing at 50 mph and just giving a little bit of gas it does it and if you give gas it goes great egr valve is opening up to fast simply disconnect that valve and go try it again im sure its gonna go great i try to find you a video about it
Apr 03, 2015 | Chevrolet Silverado 1500 Cars & Trucks
Stuck on mute! When I make a call I cant be heard by the other person. Have tried everything to unmute it. I've probably accidentally hit a wrong button when setting mailbox
i would open it up and spray a little contact cleaner on that mute button in the inside part of the button and the contact it goes to. even a tiny bit of carbon can jack those up
Jul 12, 2011 | NorStar M7208 Corded Phone
Aver DVD Veriton 5800 dvd door will not open. do not see a pinhole. tried opening from computer start did not work either
sir the pin hole is the best solution but since u r unable to find it then the only solution remains to unscrew the DVD and check the door opening belt is not broken\stuck... just move it a little bit and the hatch may open... but before going through it please try to strike ur DVD with your hands a little bit while pressing the eject button repeatedly... this might help in moving the stuck belt inside... rate this solution if you watch awesome movies on your newly repaired DVD
May 06, 2011 | Acer Veriton 5800 PC Desktop
URGENT! DVD not ejecting or playing.
It seems you will need to open the damn thing, or search for a tech, verify your warranty, dont void it.
First you can try to move a little bit the dvd, unplug and plug, change disc, ieverything that can move a part inside the dvd must be pressed, surely is stucked between the play and the open stage.
Jul 17, 2010 | Pioneer DV-515 DVD Player
I can't open Happy Aquarium game the bar fills and
follow this step,
1.clear all ur temporary files n coockies
2.restart ur system and check
if still then may there is problem with fish aquarium server
bcz i m also playing this game,n i try this step n its work
Mar 02, 2010 | Dell Microsoft Windows XP Home Edition
Trunk latch is switched to locked and won't open on a 95 chrysler
If you are talking about where the key goes, try inserting a small pin or paper clip(straightened) to hold open the little door where the key goes while spraying a bit of WD40 or CRC-56 into the lock. It won't hurt the paint. After spraying, insert the key in and out a number of times. Spray again, this time with the key inserted. Move the key up and down while sliding in and out. This should free up any stuck tumblers. If she still wont open, repeat the process. Still no luck? May need a new tumbler.
Nov 12, 2009 | 1995 Chrysler LeBaron
Printer says inner cover 1 is open, but it is not open,
Usually a piece of plastic from the cover turn a switch on and off. Maybe is this bit broken.
if not, unplug the printer for several hours,
take off paper and cartridge and choke the printer a little bit maybe is the switch stuck due to spread ink or dust or something else.
If still stuck, open it and find those switch, try to play with it power on. Nothing happen? change the printer ...:(
Dec 24, 2008 | Lexmark X3480 All-In-One Printer
GN 9120 beeps constantly
Are you using the GN1000 Handset Lifter? And if so, are you playing music/radio through the speaker of your telephone? If this is the case the Lifter will be picking up the sound of the music coming from the telephone and interpreting it as an incoming call, hence sending a signal to the earpiece in the form of beeps. Just stop the music coming from the telephone and the beeps should stop.
If you are not playing music through the telephone, you may need to turn down the sensitivity adjustment on the back of the Lifter. Just turn the knob anti-clockwise a little bit and see if that eliminates the beeping. If the sensitivity adjustment is too high it will pick up every little noise that goes on around your desk and interpet them as the phone ringing.
If you are not using the GN1000 Handset Lifter, then the beeping may be the result of a sticking/stuck volume button on the earpiece. If you adjust the volume on the GN9120 it gives a beep when you reach the maximum or minimum volume. If a button is stuck down it will result in a constant beeping. A stuck button is generally not a user servicable problem, however a little bit of tinkering with the button may get it unstuck.
Nov 19, 2008 | GN Netcom GN 9120 Professional Headset
The games will play for a little bit then they will freeze
if you are good with repairing things try this it worked for my 8 year old ps2 you will need a phillips head screw driver and some rubbing alcohol and q tips 1 pull off rubber feet on bottom re move six screws you will have to rip or cut do not open sticker care fully open case watch out for ribbon cable going to power reset button 2 open top of cd player part carefully re move cdtray can be tricky may have more screws 3 carefully wash lens with q-tip and alcohol then dry with a dry q-tip put back together wait about 15 minutes then plug er in try it out if this didnt work you have a bigger problem good luck
Nov 09, 2008 | Sony PlayStation 2 (PS2) Console
Xbox 360's disk tray will not open
The motor that opens the drive tray could be bad or there could be something stuck in the gears. You may have to take the Xbox apart and pull out the drive and then take it apart to see if there is anything stuck in there.
Jun 22, 2007 | Microsoft Xbox Console
AT&T Sony Ericsson W580i Cell Phone - White Logo
44 people viewed this question
Top AT&T Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
