Question about InFocus ScreenPlay 4805 Multimedia Projector
InFocus 4805 lost red
I've had my InFocus Screenplay 4805 for 3 years and it has done 1600 hours. Last night I was watching a film and there was a load snap. The projector kept running ok but the red part of the spectrum seems to have been washed out. Any thoughts - thanks. Geoff
    Scholar:
  • 167 Answers
Yes Geoff, What has happened is one of the two red glass filters on the color wheel has separated and flew off which was the snap you heard. So white light is in half of all parts of the spectrum that require any red.
There should also be a vibration now that can be felt on the projector and possibly heard as well.
I suggest not running it again until this is repaired as more damage could result. If you have the skills and the part that flew off isn't destroyed it can be carefully glued back in place and problem solved. I have seen quite a few of these glass filter segments survive this.
Good Luck!
SagerTronics
Posted on Nov 29, 2009
When unit was turned off last night it "popped". Now it does not come on and the power light flashes at a rate of 1 flasher per second.
the lamp blew. take it out and see if there is shattered glass inside. if there is, replace the lamp and blow the dust out of the projector. the dust keeps in the heat that the projector is trying to expel. the lamp probably overheated and shattered. otherwise, it was at the end of it's life (usually 3000 hours).
Jan 04, 2010 | InFocus ScreenPlay 4805 Multimedia...
Infocus 4805
You may have got finger prints inside the unit. Use alcohol and a paper towel or q tip/swab to clean all the glass surfaces including the bulb. You should never touch these bulbs because the oils from your hand will decrease the life of the bulb. Also make sure you put all the parts back and that they are tight. Last item is the lens may screw for focus.
Aug 29, 2009 | InFocus ScreenPlay 4805 Multimedia...
I have a InFocus ScreenPlay 4805. the motor that
it is the colorwheel and the part number is 525-0146-00. call any infocus authorized service center (find one in your area on their website).
May 01, 2009 | InFocus ScreenPlay 4805 Multimedia...
Bright picture on outside images
try to change the preset setting on film maybe its is set on presentation which gives you more light than in film mode
Feb 04, 2009 | InFocus ScreenPlay 4805 Multimedia...
My Infocus 4805 suddenly blackout
First check what is the lamp you using please use lamps recomended by SONY only. That lamps might run up to 2000 hours so.......try checking your lamps and let me know.
Jan 26, 2009 | InFocus ScreenPlay 4805 Multimedia...
I have an infocus 4805 and the lamp won't come on. It worked the last time we used it
The lamp has probably failed. your description of events is a very common way a lamp failure presents.
Jan 23, 2009 | InFocus ScreenPlay 4805 Multimedia...
Color wheel in my InFocus ScreenPlay 4805 projector
The 4805 Color wheel part number is 525-0146-00
You can buy it from AV SOLUTIONS in NY
As far as if it's worth it... That's up to you.
Nov 07, 2008 | InFocus ScreenPlay 4805 Multimedia...
Infocus 4805 blinking red light problem
My first questions is:
Is this the first lamp you have placed into your Infocus pj? If not, did you reset the hours when you did it last time? Otherwise that can also confuse the projectors internal system thinking there is NOT a new lamp in there and there for make it stop working once the clock hours are expired and over the 3000-6000 suggested hour life.
Let me know so I can help trouble shoot other possible problems.
Oct 27, 2008 | InFocus ScreenPlay 4805 Multimedia...
No color
Color wheel disc is broken and not repairable, problem is unless you know someone that can get the part you have to take your projector to an authorised service centre.
Dec 11, 2007 | InFocus ScreenPlay 4805 Multimedia...
InFocus ScreenPlay 4805 Multimedia Projector Logo
116 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
