Question about ICOM Informatique Icom F21GM GMRS Radio with 4 Watts Output, CTCSS and Battery/Charger
Hand-held radio I can call out, but I can't hear anyone calling back to me. The green indicator light comes on, but I hear nothing. Please help! Lisa
  • Lisa Robinson Dec 04, 2006
    How could I check the programming parameters? I am not really familiar with the electronic language. Could my problem have anything to do with my letting the radio sit in the charger while turned on?????
  • 65 Answers
Set the radio for simplex ptt monitor out buttons turn on radio make sure the other radios work with each other hold the monitor down if you hear white noise then you dont have the simplex duplex setup right and or try holding the monitor button in when other people are transmitting that would indicate a ctcss programming problem
Posted on Dec 09, 2006
  • 123 Answers
Hello Think you have to make sure that both radios have the correct encode and decode CTSS or DPL, if you dont select the encode for one of them the other one just will light the green led but will not recieve. Also make sure that the speaker is working correctly. Check your programming parameters one by one. Good luck
Posted on Nov 30, 2006
My scanner wont come on I turn the switch on and nothing lights up I was wondering if it's dead.
Without model and make it's hard to say. First check the power and or batteries if it's a hand held model. I run into this issue with my Whistler scanner from time to time...I just remove the batteries and put them back in and it comes back.
Apr 23, 2015 | Radio Communications
I have a GE hand held cb radio, I think I can talk out but I get no sound back. I have checked all I could
get another radio thats hooked up and ready to go and then get your hand held and start talking.Now listen to hear if you come through the other radio.Simple
Aug 08, 2014 | Radio Communications
I have lost manufacturers manual on my BMW 325ci 2001 model. i only require pages relating to the programing of automatic garage door thank you
NOTE: Some vehicles may require the ignition to be turned on or to the second (or"accessory") position for programming and/or operation of HomeLink. It is also recommended that a new battery be replaced in the hand held transmitter of the device being programmed to HomeLink for quicker training and accurate transmission of the radio frequency. Please use a ladder and do not stand on your vehicle during the programming steps for a rolling code opener.
Rolling Code Programming:
1. Press and hold the two outer HomeLink buttons until the indicator light begins to flash (after 20 seconds). Do not hold for longer than 30 seconds. Do not repeat this step to program additional HomeLink buttons.
2. Place the hand-held remote 1-3 inches from the HomeLink button you want to program.
3. Simultaneously, press and hold both the HomeLink and hand-held remote buttons. Do not release either button until step 4 has been completed. (If you reside in Canada, refer to the "NOTE" below.)
4. When the indicator light changes from a slow blink to a rapid flash, release both buttons.
5. At the garage door opener receiver (motorhead unit) in the garage, locate the"learn" or "smart" button (usually near where the hanging antenna wire is attached).
6. Press and release this "learn" or "smart" button. (The name of these buttons vary by manufacturer.) There are 30 seconds in which to initiate step 7.
7. Firmly press, hold for two seconds, and release the programmed HomeLink button. Do this procedure again and, depending on the make of your garage door opener, do this procedure a third time to complete the procedure.
The garage should now activate when the programmed HomeLink button is firmly pressed and released. If not, give us a call or refer to the "Troubleshooting Tips" noted below. NOTE: If you reside in Canada, replace step three with the following: Press and hold the desired HomeLink button and "cycle" the hand-held remote. To cycle: Press and release the hand-held remote button every two seconds until the indicator light changes from a slow blink to a rapid flash(step four).
Troubleshooting Tips:
** Check the frequency of the garage door opener's hand-held remote (usually found on the back). HomeLink is compatible with radio-frequency devices operating between 288-399 Mhz.
** Put a brand new, store bought battery in the hand held remote. During the programming process (step three above) the battery's energy tends to drain (more so with an older battery). A new battery will increase the speed and accuracy in which the hand-held remote sends its signal to HomeLink.
** Retrain HomeLink holding the hand-held remote at different lengths and angles from the HomeLink button you are trying to program (during programming step three). Try 4-6 inches away at a different angle.
** Confirm that the HomeLink button you are trying to program is in the "programming mode". Press and hold the desired button. The indicator light will be a slow blink when HomeLink is in the "programming" mode and can be programmed at any time.
Verifying HomeLink has picked up a rolling code signal:
** Press and hold the programmed HomeLink button. If the indicator light blinks rapidly for two seconds and turns solid, HomeLink has successfully picked up the rolling code signal. If necessary, proceed with steps 5-7 noted above to complete the rolling code programming.
Sep 09, 2009 | 2001 BMW 325
Towbar wiring
i wiried up my focus estate with the following no relays needed as the wiring is protected by the car fuses
pin 1.yellow/left hand indicator
pin 2.blue fog light
pin 3.white/earth
pin 4.right hand indicator
pin 5.brown/right hand tail light
pin 6.red/ brake lights
pin 7. black left hand tail light
connect these to the car wiring with scotch locks as follows/red/blue.right hand indicator/blue.left hand indicator,green/black,left hand indicator,red/green,right hand indicator,orange right hand light,orange and white,left hand lights, finally green/yellow fog light
hope this is of use to you all my lights are working and correct
May 09, 2009 | 2000 Ford Focus
Push on button and green light comes on then goes off in 10 sec
my tv been in my storage for about two years i pull it out pluged it in and only the green light on the button comes on you can hear it make a noise like the screen is about to come on but nothing.then the green light shuts off. please if anyone know what the problem is please e mail me.
shadowbowl71
Mar 17, 2009 | RCA HD52W59 HDTV Projection Television
Not hearing certain frequincies
not all scanners will pick up the same, the hand held can't pick up frequency as far as the other one.
Mar 11, 2009 | Radio Shack Pro-97 Handheld Scanner
Nothing comes up on tv when i turn ps3 on and controllers wont connect
Read this very carefully. Turn off your ps3 from the back. Then turn it back on wait unit the light is red. Turn on the system through the front keep holding the power on. You will hear a beep one time that just tell you that the ps3 is powering on keep holding the button until you hear the second beep this will rest your video setting. If that dosnt work call me at sony
Nov 07, 2008 | Sony Playstation 3 (PS3) Console
Plantronics Problem with my headset
Setup the Plantronics CS60 wireless headset as follows:
  • Locate the 2 ports on the bottom of the CS60 charging base. One has an icon of a "full telephone" and the other has an icon of a "hand receiver."
  • Unplug the hand receiver from the base of your existing telephone and plug it into the "hand receiver" port on the CS60 base unit.
  • Then take the short cable that came with the CS60 and plug it into the "full telephone" port on the base of the CS60.
  • Plug the other end of the short cord into the hand receiver port of your telephone (where the hand receiver just was).
  • Make sure the AC Power is plugged into the wall, and then you can adjust the configuration settings.
To be able to hear or speak through the handset, either place the headset back into its charging cradle or press the call control button on the side of the headset. The talk indicator light on the base should go off and no sound will come through the headset.
To be able to hear or speak through the headset, press the call control button on the side of the headset. The talk indicator light on the base should go on and the green light on the side of the headset should be blinking.
Note: Make sure that the cables are connected correctly and the handset cable is connected to the base of the CS60 base.
Jul 21, 2008 | Plantronics CS55 Wireless Headset
Hitachi Ultravision front projection
Good Day scooter351;
IT IS time to call an Authorized Service Center and have them come out and give you a written estimate, before they proceed with the repairs.
Good Shopping, big IRISH.
Jul 10, 2008 | Hitachi 53UDX10B 53" Rear Projection...
ICOM Informatique Icom F21GM GMRS Radio with 4 Watts Output, CTCSS and Battery/Charger Logo
153 people viewed this question
Top ICOM Informatique Radio Communications Experts
eradiostore
eradiostore
BJ Russell
Steve
Are you an ICOM Informatique Radio Communication Expert? Answer questions, earn points and help others
