FixYa.com
Tags:
Bosch Classixx WFC 2465 Front Load Washer
Conditioner is not used in the wash cycle
posted by Kalon on Dec 12, 2006
The conditioner always stays in the dispenser drawer during the wash cycle, despite cleaning everything. Even if you don't put any conditioner in, the slot in the dispenser where it should go also fills up with water which you then have to throw away manually by removing the dispenser drawer.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jan 18, 2008
FixYa! (100)
fran1050
Rank:Apprentice Apprentice
Rating: 93%, 13 votes
I had the same problem with my Bosch Classixx 1200 Express.
It was fixed today & I now know what to do in the future if it happens. The water gets into the soap/ conditioner dispenser drawer via 2 pipes. One points to the main detergent compartment and the other to the pre-wash and conditioner compartments. The pipes become clogged with a type of mould. This meant that in my machine the water was bypassing the conditioner. I had already removed the drawer and cleaned it up and cleaned the jets above with an old tootbrush but it hadn't solved the problem. The repair guy used a cable tie (one of those that is quite firm & will lock) and pushed it up inside the bigger jets. This loosened the black gunge. Then ran water thru from start of the basic cycles and all is now OK
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Washing Machines problems?
bosch nexxt 700 series softner...
softner filling with water and... Answer This...
Bosch 1200 Express Washing...
Help! My 3 year old washing... Answer This...
Not spinning
My machine works fine right up... Answer This...
draining water tank
I just bought a 6 month old set... Answer This...
WASHING PROGRAMS
i have had instructions... Answer This...
Repair Service
Find Washing Machine Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
