Question about Solis Crema SL-90 Espresso Machine
SL 90 Machine not heating
THANKS for taking our Q.
We have a Solis SL90 (a little over 3 years old) - when we turn it on, the light is STAYING RED and not heating (turning GREEN) ... Can you offer any suggestions ... oh, also, Water IS pumping through the wand but it is cold... we think it is the heating element ... and hoping we can get a part and replace ourselves ... (?)
THANKS for your help!
  • 1,089 Answers
Hi There are 3 things that could be the problem. 1. The power board on the left rear inside. 2. Heating element is burnt out. Replace the top part of the boiler and order a brew head gasket and replace it at the same time while you have the machine apart. 3. and less likely is the temperature sensor. 2 red wires goes from the board to the top of the boiler.
Posted on Jun 06, 2009
The machine is still turning on however the light which indicates when it is ready to make the coffee never changes from red to green. I wondered if it might a problem with the control panel. My machine...
HI I would suspect the thermostat on top of the boiler. it is 2 red wires with a little thermal couple on the end. Could be broken or bad. Goes to the board.
Oct 03, 2010 | Solis Crema SL-90 Espresso Machine
Solis Cream SL90 not heating water
Yes, it is possible that the thermostat tripped or is damaged. If thermostat is not damaged then elements might be damaged.
Jul 02, 2010 | Solis Crema SL-90 Espresso Machine
Solis Crema SL90 not heating water
Yes it can be repaired, sounds like the thermostats might have tripped.
Three red lights around the "on" button and a green light on the power supply
3 red lights on the Xbox 360 is the most common error and it means "General Hardware failure. To fix this you need to stop the amount of heat that the GPU and the CPU is taking.
To do this you can use the recommended guide that has been on the market for 3 years or you can send it in.
Jan 27, 2010 | Microsoft Xbox 360 Console
Solis Crema SL90 NO HEAT
Hi
There can be a couple of things. The heating element could be bad. Check with an ohms meter. 12 - 16 ohms between the element terminals. You could have a bad power board. There is a solder connection that seperates and can be resoldered. Look for a small bulls eye where 3 solder connections make a triangle in the top left side. A little heat and new solder can fix it sometimes but don't put too much solder on or you will short the connections. If this doesn't fix the problem you need a new board.
Jan 21, 2010 | Solis Crema SL-70 Espresso Machine
Solis SL-90 Been working fine for 8 years but suddenly will
Hi
Where are you located? There are a couple of things that will cause the boiler not to heat. The power board that you can replace your self if you are handy. Heating element that is a little more detailed but can be handled by a lot of people. You did not give all the details but do you have power at all? Could be the thermal fuse. Yes they are worth fixing compared to buying new. if you chose to repair also change the brew head gasket. That should be changed yearly or at least every 2 years.
Nov 10, 2009 | Solis Crema SL-90 Espresso Machine
Solis Crema SL-90 Espresso Machine Logo
417 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
AZBen
AZBen
gbob59
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
