Question about SanDisk Memory Media
Memory sticks empty and shows no memory available
I have two Sony's digital cameras, on one I have a 2GB memory stick duo and on the other I have a 4GB.  On the 2GB the memory stick started giving us less and less pictures available, resolution on the camera was at its lowest since we had to change settings to see why it was showing that I only had like 47 pics in a 2GB card.  I change the 4GB from the other camera to see if the problem was the memory card and now the 4GB when i turned the camera on has a message that says , no memory space in the memory stick, the stick is empty and still I can even take one picture.  Could it be a problem that one camera has damage both memory sticks?  Or could it be that the memory could have erased? Thanks for your help Ana
  • 1 more comment
  • sozo112 Dec 10, 2008
    I have a 256 MB SanDisk memory card and am having the same problem--it says that there are no images, yet there is no memory available on the memory stick?  please help!
  • tnsc84 Dec 13, 2008
    same thing - memory stick pro 512MB used with a Sony Cybershot
  • miekeens Jan 01, 2009
    I'm Dutch and have the same problem.
    I have tried to put some photo's and films back on my memory stick pro, but it didn't work and after I did this I also get the message 'no memory space, although I know for sure that it is empty.
    Mieke
I have a solution that worked! Notice: save all the needed data on your computer, because Formatting your Memory stick will wipe everything out!
if you have a Sony PSP, or know someone who does, replace the memory stick that says "no memory Space" in to the PSP port, go to "Settings" which is the left-most section of the PSP main screen, then scroll down to "System Settings," select it, Scroll down again to the "Format Memory Stick" selection and press "X" follow on-screen instructions and  SHAZAM!  its ready for action in your camera again!
-Indy
Posted on Mar 19, 2009
  • 416 Answers
Best would be to check the Crad on a PC to actually see if there are any images on it, if not try formmating the card via the PC & Try on the camera. if all fails i suggest you take the camera to the local camera repair shop just to get it checked out.
Posted on Jan 05, 2009
What memory sticks do i need
Quoted from the technical specifications available on the Sony website UK. http://www.sony.co.uk/electronics/cyber-shot-compact-cameras/dsc-h300/specifications Storage Media Internal MemoryApprox.55MB Compatible Recording MediaMemory Stick Duo, Memory Stick PRO Duo, Memory Stick PRO Duo (High Speed), Memory Stick PROHG Duo, Memory Stick Micro*10 , Memory Stick Micro (Mark2)*10 , Memory Stick XC-HG Duo, SD Memory Card, SDHC Memory Card, SDXC Memory Card, microSD Memory Card*10 , microSDHC Memory Card*10 , microSDXC Memory Card*10
Mar 26, 2015 | Sony Cyber-shot DSC-H300 Digita Camera -...
My Sony memory stick pro duo magic gate mark 2 is not shows images on pc but in my camera, but the photos are visible on Sony cybershot camera
Some Sony Cybershot camera's have a small amount of memory built into the camera. Double check that the camera is set to put the pictures onto the memory stick.
If the camera is set up correctly, the memory stick may not be formatted correctly for your computer. If at all possible, connect the camera to your computer directly with the USB cable that should have come with it.
May 31, 2011 | Sony 2GB Memory Stick PRO Duo Memory Card
Bought used camera Sony Cyber Shot Model DSC-P32. What Memory Stick do I need?
You can use Memory Stick standard, pro or pro duo up to 2GB with the Camera.
    A dedicated adapter (MSAC-M2) must be attached to use Memory Stick Duo™ or MagicGate Memory Stick Duo media.
I have provided the Memory Stick compatibility chart for your reference.
http://esupport.sony.com/US/perl/support-info.pl?&info_id=12&mdl=DSCP32
Feb 09, 2011 | Sony Cyber-Shot DSC-P72 Digital Camera
Sony memory stick duo is saying full but has no images on it
> it has no images on it
Insert the memory-card into your computer.
Open "My Computer".
Click with the SECOND (usually the RIGHT) mouse-button on the icon for the memory-card.
Choose 'FORMAT' and choose 'Quick Format'.
This will "empty" the memory-card, making it 0% full.
Or, you should be able to do something similar to the above, while the memory-card is inserted in your digital-camera.
Feb 01, 2011 | Sony 2GB Memory Stick PRO Duo Memory Card
What memory stick works in the DCR-TRV340 Sony Handycam?
Mine says msa-4a. the duo sticks won't work. You will the larger older memory sticks
Apr 26, 2010 | Sony Handycam DCR-TRV340 Digital Camcorder
Getting an error code c:13:01 on my sony t900 camera
“Memory Stick Duo” is unformatted.
“Memory Stick Duo” is broken.
“Memory Stick Duo” type error
The camera cannot read or write data
on the “Memory Stick Duo”.
Format the “Memory Stick Duo”.
Replace a new “Memory Stick Duo”.
Insert a supported “Memory Stick Duo”.
All above are solution for your quiry
Jan 21, 2010 | Sony Cyber-shot DSC-T900 Digital Camera
I have a Memory Stick Pro Duo 8GB will not open on my computer or camera..was working then quit. Advice please
Problem for Sony Memory Stick PRO Duo (2GB) for PSP I have a Memory Stick Pro Duo 2GB will not open on pc &also not formated
Jan 02, 2010 | Sony Memory Stick PRO Duo (2GB) for PSP
I have pictures on the card that show up on my
Keep the memory card in your camera....plug your camera into the computer and then turn your camera on...options should start to appear on the screen...follow the questions to get your solution...
Nov 08, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
No piks showing
The memory card can't be more then 2gb...the camera won't support more than that. Have you formatted the memory with the camera? If not try that, don't format the card with your computer.
May 05, 2008 | Sony Cyber-shot DSC-T9 Digital Camera
Memory card
Try and format the card with the camera. Got to use the menu settings for that.
Apr 19, 2008 | Sony Cyber-shot DSC-T9 Digital Camera
Electronics - Others Logo
1,074 people viewed this question
Top SanDisk Electronics - Others Experts
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
