Question about HP Photosmart D7260 Printer
HP Printer D7260 Printer error
Can't print any documents.  Keep getting an error saying printer is offline but there isn't any way to put it back online (no button to push, etc).  I'm using a Mac (in case you needed to know)
  • jots6 Jan 24, 2009
    I am trying to print a photo out on a mac, i have an hp photosmart D7260 printer and it just tells me that the printer is off line, I've turned both computer and printer off and started again but same error message - I printed something out 2 mins ago that was fine but now it won't - there is no paper jammed either - HELP
I do not have areason for why the printer continuously goes offline but there is a way to put it temporarily back online. Go to printers in the control panel. right click on d7260 and click on use printer online. This only seems to work for one or two docs before you have to repeat the process.
Posted on Mar 15, 2009
    Scholar:
  • 91 Answers
Got to Printers and Faxes. Right click the HP D7260 printer. Look for the 'Use Printer Offline' or 'Online'. This is about the 5th item from the top of the drop-down menu. Make sure that it says 'Use Printer Offline'. If it says 'Use Printer Online', move your mouse over it and left click it until you see it change to 'Use Printer Offline'. Try to print.
Another question, did you have a paper jam in your printer? If you did there might be a small piece of paper stuck inside that is triggering a sensor that is telling your computer that it is offline. Look for any stuck piece(s) of paper. Let me know what happens.
Binary Bob
Posted on Nov 16, 2008
HOW TO FIX...PRINTER IS OFFLINE BUT IT IS ON...WE ARE UNABLE TO PRINT.
If you are getting a status message as the printer is offline on your pc,and afterward you can't ready to print the reports.
Steps to Resolve the Printer Offline Issue:
Step 1:
At first, you need to check your network through the HP Scan Doctor which encourages you to discover and fix the printing issues.
Steps To Run the HP Scan Doctor
    •Open the HP Scan Doctor tool by double tapping the symbol.
    •Start- - >Select your printer- - > Fix Printing
    •Then the list of issues displayed on the screen as result.
    •If the tool shows the white checkmarks at that point there is no issue.
    •If the tool shows the white wrench then the issues are found and repaired
    •If the tool shows the yellow shout point then the issues are found however that can't be solved or skipped.
    •If the device shows the red stamp then you have to take after the on-screen guidelines to determine the issues.
    Step 2:
      Set Your Printer as Default Printer
      •Search your gadget on your PC and select your printer and uncheck the Pause Printing and Use Printer Offline
    •If you can capable print implies your printer is online.
    Officejet 4650 keeps going offline then proceeds with following step Step 3:
    Check Whether You Connect With Correct Port
      •Go to printer- - > Printer Properties - >Port
      •For USB association utilize USB or DOT4
      •For Network Connection use WSD, organize, Standard TCP/IP Port Step 4:
      •Update the printer firmware which may resolve your issues
      Step 5:
      •Manually connect the wired or wireless connection
      Step 6:
        •For network connection just you have to add the second printer to your Windows.
        •Select your printer - > Properties - >Add Port - > Standard TCP/IP Port - > Next port
        •Now you can ready to print implies stop the troubleshooting. Still get the same issue mean you need to connect the printer customer support via +1-800-836-3987
Jan 08, 2016 | Office Equipment & Supplies
Says disconnected but it isn't
I have put together a couple off guides for troubleshooting different offline printer issues for Windows XP, Vista and 7. I would recommend checking them out here: http://www.refreshcartridges.co.uk/igloo/how-to-make-your-offline-printer-online/
Hope they help.
Apr 12, 2013 | HP Photosmart C6280 Printer
HP photosmart printer is offline- how to correct
Click Start and then go to Printers and Faxes (XP), Printers(Vista), Devices and Printers(Win 7)
1. Right Click on your printer Icon 2. Click Open or See What's Printing 3. Click the option that says Printer on the upper left corner of the window that pops up. 4. Make sure the only thing that is checked under that menu is Set As Default Printer. 5. If Use Printer Offline or Pause Printing has a check mark. Uncheck it.
Try printing again. I hope this helped.
Jan 02, 2011 | HP Photosmart D7260 Printer
My HP Officejet 6210 All-in-One printer goes offline whenever I don't use it for about 15-20 minutes, and when I put it back online, nothing happens. Looking at the printer from the control panel, I see...
HP Printers have common behavior of going into sleep mode if not used for a while. If this happens every-time the printer goes to sleep mode and you find printing issue, try this simple step below
Disconnect the power cable from back of printer
While holding the # and 3 button, connect the power cord to printer.
*Note this is partial reset and doing so you may loose fax logs and other fax related setting you have setup on printer.
Click the link below to know how to resolve the print job stuck in queue issue.
Link
Oct 23, 2010 | HP OfficeJet 6210 All-In-One InkJet...
I can't get my photodumb D7260 to print. i have in the past but i have had nothing but trouble with it. i have completely given up on using the wireless option and use USB instead. i had it disconnected...
You could try the following:
1) Unplug the USB cable from the back of your computer
2) Reboot your computer
3) With the printer power on, reconnect the USB cable
You may need to troubleshoot even further by:
1) Checking that your D7260 is the default printer.
2) Checking that your printer is not "offline" - find your printer listed in Control Panel. Right click and choose "Use printer online"
Dec 20, 2009 | HP Photosmart D7260 Printer
Hp 5610 all in one printer, cartridge error, will not print
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
abdsf17
Aug 10, 2009 | HP Officejet 5610 All-In-One InkJet...
Printer status- error offline
first go to services.msc refresh the spooler service. then insert the printer disc in to the computer . do a level 2 uninstallation .
restart the computer then again again reinstall the software issue will resolved
Aug 03, 2009 | HP PSC 1210 All-In-One InkJet Printer
PRINTER ONLY WORKS ON ONE SIDE OF COMPUTER
your printer is working offline. try to change settings from control panel > printer and faxes..
Jan 10, 2009 | HP Photosmart D7260 Printer
My hp photo d 7260 wont print from my computer
double click printer icon.. inactivate printer > work offline..
Dec 27, 2008 | HP Photosmart D7260 Printer
HP Photosmart D7260 Printer Logo
1,920 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
