Question about Nintendo DS Lite Console
Ds lite pins
Pins in my ds lite are not staight so it wont read cards how to straight them???????????
  • Anonymous Jan 24, 2009
    i have same problem but i cannot find pliers small enough another way to do it
    Novelist:
  • Nintendo Expert
  • 127 Answers
From outside is pretty difficult to straight the slot 1 pins as it is small and you need very thin pliers and light source plus lots of patience.
With a plier you can straight the bent pins to its right position, but make sure the pin is not out of its place as all the pins are V wedge shaped and the pin comes from the slot bottom, the edge fits in a small hole then goes up to make contact with the game cartridge contacts. No one stay out when inserting a cartridge or you'll have a bigger problem.
If there are many bent pins I find more easy to open the DS, desolder the damaged pins and pull em out of the plastic enclosure to repair it, put it in again and re solder. No one option is easy... Sorry...
Posted on Nov 18, 2008
  • 210 Answers
My recommendations for do-it-yourself repairs of this problem:
1) Replace the main board (difficult enough, but the easiest).
2) Remove the slot-1 port cover to gain better pin access.
3) Remove the damaged pins from the slot-1 port to straighten.
4) Replace the slot-1 port.
All of these recommendations require disassembling the DS Lite using a specialized triwing (or Y) screwdriver and a lot of patience. The following video will help in disassembly: http://www.youtube.com/watch?v=HQlTpTLUyFQ.
Recommendation 1 is the only one that does not require solder work. Recommendation 2 requires solder work for 4 solder joints, 1 at each corner. Recommendation 3 requires solder work for up to 17 solder joints, one for each damaged pin. Recommendation 4 requires solder work for all 21 solder joints, but not a bad option if you are good at soldering and like it.
Posted on Jul 10, 2009
Nintendo ds lite comes on but doesn't read inserted game
Please have a look at the game slot and if you see any bended pins try to make them straigth , or your game card slot needs to be replaced , Thanks
May 20, 2010 | Nintendo DS Lite Console
DS Lite Console: my nintendo ds lite won't read game cards...
try compressed air.
more then likely its a hardware issue. try getting an R4DS card and download games from www.filestube.com if you dont want to repair it.
you can have 50+ games on an sd card and not have to lug around all those games anymore
May 06, 2010 | Nintendo DS Lite Console
Ds lite is reading system date error
Known problem with the NDS Cards but here is a temporary fix:Take out the NDS cards and start up DS without them
  • Tap the symbol in the middle of the screen at the bottom that looks like a DS.
  • Tap the blue box with a calender and clock in.
  • Change the date a month or two back.
  • Restart DS with NDS cards in.
Even though this is temporary the people at NDS are working for a solution. But until then you might just have to keep putting the date back.
Apr 15, 2010 | Nintendo DS Lite
Have two ds lites they wont load the games it just says to insert the game but they r in ,any ideas?.Thanks
There are possibly 3 things wrong.
1.) Your games are bad, since this is happening on both DS Lites.
2.) Check your pins inside of the DS. If they are bent, they wont read, but if they are slightly bent, you could actually straighten them yourself with a long skinny tool.
3.) The memory on both your ds lites are blown.
My solution: I ask that you place alcohol on all of your games and insert them and remove them 5 times to lubricate the pins, then on the 6th insertion, cut the game on to see if it reads.
I hope this helps :)
Apr 05, 2010 | Nintendo DS Lite Console
Why wont it read a game it says insert card
Check for bent/damaged pins or reinsert card several times b4 turning on might fix it
Mar 22, 2010 | Nintendo DS Lite Console
MY NDS lite wont read DS games but will read
there might be something wrong with the card reader. Or something wrong with your card. Try cleaning them with something (not a tissue, that will make it worse). If that doesn't work, it's probably something wrong with the internal wiring and such, so there's not too much you can do about it
Jan 17, 2010 | Nintendo DS Lite Console
DS light wont read the cards
may have problem with the pins in the cartridge slot that reads the game data
Apr 07, 2009 | Nintendo DS Lite Console
Nintendo ds wont read ds games
did you try to clean the pins (carfully) this sometimes works for me, their is no one i know of that sells the slot reader, as for replacing it you will need to desolder and resolder the 18 pins plus the 4 that hold the shell down
Aug 04, 2008 | Nintendo DS Lite Console
Nintendo ds lite won't read card
had this problem, i looked into where the game goes and one of the little metal teeth was bent, so i took a long toothpick and gently pushed it back over now it works fine. Be careful that you dont break it off though.
Feb 08, 2008 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
1,835 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
