Question about M-Audio Session KeyStudio USB Keyboard
I can't fingure out how to use the M-Audio Keystudio 25
I tried using the M-Audio Keystudio 25 keyboard with the different insturments but but the sound dosn't sound like it. Here is what I am doing: I clicked: Track>Add Track>Play and Record using Keyboard and selected an inturment but it wont sound like the instrument. All the instruments have the same ringing sound. How do I get it to sound like the right instrument?
SOURCE: Problem with "M-Audio 49e keystation"
The 49e has been a real pain--especially if you have previously used another M-audio controller on the same machine. I just spent 3 hours to get mine working on XP (with a Creative sound card). In summary--for my machine--Windows XP kept putting the old WDM driver back (vintage 2001), even though I installed the M-Audio. I had to finally use the 'Add New Hardware Wizard' and force it to install the non-certified M-Audio drivers that were supposedly installed when running the M-Audio installer. (Skip internet search, and browse to M-Audio folder in Program files, it will eventually find them.) There are two M-Audio USB drivers that need to be 'forced' via New Hardware Wizard. But Windows thinks its drivers are a better match and even though 'device is working properly' it doesn't get recognized in your software. After I go rid of the WDM drivers and replaced them with the 2 USB ones from M-Audio, my DAW finally recognized the keyboard. I even went through regedit to clean up all the M-Audio stuff so I could get a fresh install. I don't know if this makes enough sense, but good luck.
Posted on Oct 24, 2007
SOURCE: Working with Vista
M-Audio Session is looking for the USB device, e.g. "Micro" or "Fastrack"
Posted on Jun 27, 2008
SOURCE: M-Audio keystation 49e stopped working
JA user_offline.gif vbmenu_register("postmenu_31136", true); M-Audio Tech Support Join Date: Jun 2008 Location: Irwindale, CA Posts: 5,033 icon1.gif "I asked our repairs department and they said the problem is either the main board or the velocity board. You can order both boards from our repairs department and return the one that is not needed. The main board goes for $20 and the velocity board for $14. 626-610-2529, Mon - Fri, 9am - 5pm Pacific Time."
I just found this in the M-Audio forums. I've just called the number and left a message at M-Audio requesting a callback. I'm really hoping that tech support will have a solution for whatever is causing this malfuntion. . . I'll post here again when the parts come.
Posted on Apr 28, 2009
SOURCE: M-Audio KeyStudio is connected using the USB cable
Soltion is to download the software for Micro USB from M-Audio website and connect the USB of the Micro USB to your computer with headphones and mic connected to it and connect the USB cable from the M-Audio KeyStudio keyboard to the computer and the Pro Tools M-Powered Essential software will work.
Posted on Feb 07, 2010
  • 115 Answers
SOURCE: Brand New Axiom 25 most keys do not play
use on screen keyboard and type your keys if this work then it is hardware problem if not then it is a virus scan it
Posted on Mar 27, 2010
Can get signal from UA-25 to computer... but no audio from computer to UA-25?
Here is one solution uninstall the default driver or roll back driver. Restart your computer. When you get into windows wait for everything to load and then plug in your audio device. If you have it plugged in when windows starts then it will install a driver. In automatic updates you can select to notify of updates, but lets you install the ones you want.
Thanks for using Fixya
SAM ANDERSON
Sep 29, 2008 | Edirol UA-25 External Sound System
Do not get MIDI signal via EDIROL UA25
Midi is data only, there is no actual sound to the midi tracks themselves. They need to be assigned to either a software synth or an external synth to actually make the sounds you want to hear.
For instance if you load a demo of a midi sequance you will need to add a software synth such as the TTS-1 or Roland sound canvas which are general midi compatable and will play the instruments sounds assigned to the demo's midi channels. Use the Synth Rack feature in Sonar to open one of them. Then you will need to assign the output of each of the midi tracks to that particular synth and you will get sound. Make sure to assing the synth's audio track to you UA-25 as its audio output.
I would suggest reading in the manual and following the tutorials included in the manual to get yourself familier with how this is all done. spacer.gif
May 25, 2008 | Edirol UA-25 External Sound System
M-Audio KeyStudio is connected using the USB cable and the keyboard is turned on, but I get the message NOT CONNECTED. And, Pro Tools M-Powered Essential (ver. 8.02) says that it is Unable to find a...
Jan 28, 2010 | M-Audio Computers & Internet
Bent prongs in USB port on the m-audio keyboard
Sadly, not too much can be done. You COULD try to get in there with a small tool and bend them back, but I don't know how extensive then damage is. If you really know what you are doing, you could find an old device with a USB port on it, de-solder that port off, and solder it onto the keyboard. But If you try that, I really hope you know what you are doing. If not- time for a new keyboard. Or- get yourself a USB 2.0 hub and place it next to your keyboard. I have one stuck to the side of my PC with velcro tape.
Apr 29, 2009 | M-Audio Session KeyStudio USB Keyboard
Everything sounds chopped and screwed
I had the same problem when I first got the program. I found that the program makes you use the provided USB adapter for both recording and playback.  Now, in order to let the program know that it is plugged in for playback(in your case,)  when the program starts, select the option for ASIO and select the one with the USB in the drop  down menu.  If the program starts without it, then go to options, audio hardware, and then this will pop up following one of the selections.  Now, mess around with some of the options in the ASIO settings(like I did) and eventually the lag will not be so bad, if that is your problem, I'm not next to you, so I can't help that much, but I hoped I helped a little.
Jan 13, 2009 | M-Audio Session KeyStudio USB Keyboard
Working with Vista
Jun 21, 2008 | M-Audio Session KeyStudio USB Keyboard
Will not recognize Midair 25 (drivers installed)
Sounds like a USB issue. Is the device self powered? Did you try plugging in a different USB cable? Is it plugged into a powered hub?
USB 1.1 devices and USB 2 devices can cause issues together on the same bus or port. Try keeping devices separate or plug in just the maudio device. I had issues with USB Network adapters not being seen all the way because there was a older usb 1.1 device on the same hub.
Feb 15, 2008 | M-Audio Audiophile USB Audio and MIDI...
M-Audio Session KeyStudio USB Keyboard Logo
89 people viewed this question
Top M-Audio Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
John Bolton
Jim Goldsmith
Jim Goldsmith
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
