Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Banging washing machine on spins
I have a hotpoint aquarius wma58 washes lovley when it goes on spin it shakes, bangs and walks across the room. Its like theres something loose. When i touch the block its very loose.
  • Hotpoint Master
  • 3,463 Answers
Hi. I don't know if your problem has been sorted yet, if it has not ,then it sounds to me llke the concrete balance weight is loose or broken
There are 2 of them, one in the top of the m/c, and one at the bottom, if either of them are loose, then that is your problem.
If loose, can be tightened up, if broken away from the drum then you have a major problem
Posted on Nov 23, 2008
Hotpoint Aquarius WMA58 (about 16 years old) is leaking, seemingly from under machine (back looks dry), and leaving clothes wet after spin cycle. Door seal seems sound.
no not worth repair at 16 years old
its got issues with aging worn motor
not spinning fast enough
door seal if you can buy one
may not be the water leak fix
time to replace the washing machine
Mar 06, 2017 | Hotpoint Washing Machines
Hotpoint Aquarius WMA58 washes, spins but won't drain water away !
I would check the filter assembly and the drain line to see if there is an obstruction visible or twist in the line that you could smooth out. The drain solenoid valve could be faulty and just isn't opening any longer. It's an electrically operated valve that makes a rather loud "click" when it energizes to open the drain and let the water flow out.
Dec 28, 2016 | Hotpoint Washing Machines
I have a front loading samsung wf337aa, when it goes into the spin cycle it shakes so bad that it walks across the room. What would cause this?
Is the washer new? I had same problem it walked all over the room,then i found out it had some long shipping screws in the back that i had never removed,they needed to be taking out before first use, i believe it was 4 long maybe 5" long and each had a plastic spacer also meeds to be removed..good luck.
Sep 13, 2012 | Samsung WF337AA Front Load Washer
Hotpoint WMA58 working but will not spin - drum rotates but will not speed up.
It sounds like your belt is loose and needs to be replaced..
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
heatman101
Apr 12, 2010 | Hotpoint WMA58 Front Load Washer
Hotpoint wf740 aquarius 1400 v noisy banging during spin = dust
It could be a broken drum restraint spring, or a worn or broken. or loose shock absorber.
To check the springs, remove the top cover, and you will see the springs.
Another possibility is the concrete weight could be broken or loose.
You need to remove the lower rear panel of washer to check the shockers and concrete weight.
Please rate my solution.
Thankyou.
Jan 31, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint aquarius banging about when spinning
hi take the top of the machine and check the brick at top or bottom of the machine they sometimes come lose .
Sep 30, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Is it possible to change bearing on a Hotpoint Aquarius WMA58? and if yes, can i do it my self? thx
You can do it your self, but it is a very involved repair, and I would not recommend that you attemt it, unless you are conversent with washing machines, it involves a complete strip down.
Thanks.
Aug 05, 2009 | Hotpoint WMA58 Front Load Washer
Hotpoint aquarius wma58 1400. Full of washinh. Full of water.
pull your washer out. put near door if poss then put the waste pipe down to floor level to empty the water. if there is to much water in the drum it will not spin try your pump
Jun 21, 2009 | Washing Machines
Hotpoint aquarius 1100 bangs while spinning
Several possible reasons for this. M/C not level, causing it to move about.
Overloading of m/c.
Loose concrete balance weight, there is one at top and one at bottom.
Suspension spring broken or unhooked.
Suspension leg loose or broken.
Main drum bearings worn, to check this, turn drum by hand and if it feels noisy or rough , then bearings have gone (expensive repair).
There are other possible causes, but these are the main reasons.
Plz rate my solution.
Thanks.
Dec 29, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint WMA58 Washer won't do proper final spin
I ve come across this problem many a time... my job is recondtioning these models of machines for the last 3 years..
This problem has three solutions..
the first one is the control board,, very unlikey but has been known,
secondly the wiring loom unlikey but has happend.
Thridly the motor itself ....This is the most common remedy to this problem.
Dec 23, 2007 | Hotpoint WMA58 Front Load Washer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
300 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
