Question about Logitech Cordless Desktop EX110
EX110 Keyboard: Some Keys don't work
A friend of mine took his keyboard apart to clean. (By clean I presume he spilt something on it, so he took it apart to dry it.) Now some of the keys don't work (A,S,D,F & J,K,L.) I've had a look but cannot see anything wrong, gave it a clean with Isopropyl Alcohol, but it still won't work. Any clues, as to what I can do to fix it?
    Sergeant:
  • 207 Answers
GandalfUK,
What can be done depends greatly on WHAT was spilled on the keyboard, AND what your experience with electronics is.
All of the keys you indicated are on the same key row as each other. The way a keyboard works is that there is a grid pattern of electronics traces(lines) that run below the membrane (Rubber or plastic seal) just below the keys. The controller determines which key you push by checking for what column connects with what row.
Well since all of the keys you have indicated seem to be from the same row, I would say that something damaged the trace for that row.
Which leads me to believe that what he spilled was something acidic (Soda, orange juice etc..)
If you have experience with electronics you can remove the control board from its casing, be sure to remember where EVERYTHING came from (Draw yourself a diagram if you have to) then inspect the board for damage. You should be able to SEE the grid patter of contact pads. there are several rows, the one you want is 3rd from the bottom. If there is OBVIOUS damage your in business. clean it up and you can buy whats called a trace pen from an electronics specialty store. This is much like a ballpoint pen but instead of ink it has metal flakes suspendend in an electrically conductive epoxy. Draw in the gap in the trace with this pen and let cure usually 5 minutes but follow the curing time on the pen if different. then you can reassemble.
If you don't see any damage then you have to use a multimeter to narrow down the location. If you don't have a multimeter or the experience to track the trace to an open. Then it would likely be cheaper to just purchase a new keyboard. Not sure what they cost in the UK but their about $30 USD which if the exchange is what I remember is about 12 Pounds.
Hope this helps
Dave
Posted on Nov 17, 2008
Testimonial: "Very useful information, it helped me correct the problem & is now back in use again. Thank you."
Spilled drink keyboard
ifixit dot com sells the screwdriver you need for the bottom plate (and pics of how to take it apart)
Aug 26, 2014 | Apple MacBook Air
I have a gateway keyboard ku-0833 and its working fine but I spilt a little coffee on it and a few of the keys are stiff to push. Is there a way I can clean it, tried using cotton swabs around the keys but...
You can pry out the keys using a butter knife and use rubbing alcohol to clean the underneath.
if the coffee got into the connectors you might be out of luck.
**THE FOLLOWING IS NOT RECOMMENDED**
When i spilt mt dew on my keyboard i took out the battery let it decharge for 5 minutes. I put it in a pan and poured rubbing alcohol on it and let it sit for 5 min. While it was sitting i swished the alcohol around a little bit so it could flow. took it out and let it dry for about 1-2 hours and it worked perfectly. this is orta used as a last resort
Nov 24, 2010 | Gateway 2520915 Keyboard
My HP pavillion had pepsi spilt on keyboard and now has 2 keys atleast that don't work. I have a spare PC and have cleaned underneath the keys, but the problem appears below that into the board underneath....
There is one other options before you decide to take apart your laptop.. if you have an extra keyboard that either hooks up to a usb port, or even a regular ps/2 mouse and you can get a usb adapter for this which is just called a ps2 to usb adapter, they are about $2. You can hook this up to your laptop and use this in the mean time. Just thought I would give a suggestion before you decided to take apart your laptop, especially if you are not too familiar with it
Oct 17, 2010 | HP Pavilion dv7-1132nr Notebook PC
Certain keys are creating double letter combinations e.g. typing "y" yields "hy", "i" creates "ki", "r" "fr", and "o" brings "o9". the shift key has stopped working. replaced batteries. took off key caps...
i think maybe some of your keys are stuck together. have you spilt something on it or is there a load of debris underneath keys if so just give it a wipe to clean it or blow on the keys to remove debris
Sep 26, 2009 | Dell 0Y3740 Keyboard
My tab and delete button are not working
take the keyboard, flip it over, bump it on something, NOT TOO HARD, maybe some garbage is in between the keys, shake it a little to see if something comes out, don't worry about keys, springs, whatever, keyboard won't fall apart :) sometimes stuff gets in.
Sep 15, 2009 | Logitech Cordless Desktop EX110 Keyboard
Keys are sticking the keyboard. Can i clean underneath the keys?
Depending upon how sticky the keys are, it might be easier to buy a cheap replacement keyboard.  Trust me, it takes a whole lot of patience and a steady hand to take apart the keyboard key by key and then put it back together.
Mar 09, 2009 | Toshiba Computers & Internet
Wireless Keyboard not working
sensor are on but keyboard is not working
Jun 18, 2008 | Computers & Internet
The "@", "2" key on a wireless 3000 won't respond
some keyboards you can pop the keys off. There may be a crumb lodged. I had this problem before and thats what it was. If not...I don't know then. If you take your keyboard apart make sure you payattention to where everything goes back to gether. I took mine apart but mine is an older one.
May 24, 2008 | Microsoft K5100141 Keyboard
Keyboard
take keyboard apart. or wait for it to dry out. put keyboard in front of a fan. wait a day or so, try it again. if you cant get it to work, try taking it apart and checking the pads under the keys for damage.
Feb 07, 2008 | Logitech Cordless Desktop EX110
Viewsonic Tablet PC keyboard issue.
Try reseating the cable that connects the keyboard first.
If that doesnt help there may be liquid around the connector and it needs to be cleaned off to keep the circuit from shorting out. You will need to find someone with the appropriate chemicals and may have to take the laptop further apart to clean it all up.
This is why when anyone gets a liquid spill i recommend getting it torn down right away and cleaned up, as it can damage things you cant even see. If the liquid has been in there too long it may not be repairable.
Dec 21, 2007 | HP Pavilion dv4000 Notebook
Logitech Cordless Desktop EX110 Logo
706 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
